13
Sounds like a plan!
*C1 TRIM STYLE C1 - CLOTH &&&& VINYL BENCH SEAT -SA CHARCOAL 169 Zone 69-Phoenix 1AA U.S. Dealer Retail 3V2 Customer Preferred Discount 4XA Air Conditioning Bypass ALM APA Monotone Paint ARL BAP 75 Amp Alternator BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Performance Data &&&& Video Recorder JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3W STRIPE/BADGE/MOLDING/COLOR KKS STRIPE/BADGE/MOLDING/COLOR KWS STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAF High Altitude Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PW7 Bright White Clear Coat QW7 Bright White Clear Coat RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBB Full Size Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires TZH Michelin Brand Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z77 Right Front Spring Group VII Build date 10/10/90 Body code TL61 Sold by RENO JEEP CHRYSLER, RENO NV
*B1 TRIM STYLE B1 - CLOTH &&&& VNL BENCH SEAT -SA Charcoal 152 Zone 52-Kansas City 1AA U.S. Dealer Retail 4HG Central Scheduling Block 5AL Low Series Tracking APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JGB Performance Data &&&& Video Recorder JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB K3Z STRIPE/BADGE/MOLDING/COLOR KDB STRIPE/BADGE/MOLDING LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PS3 DOVER GREY MET CL CT PRIMARY PAINT - HS3 QS3 DOVER GREY MET C C SECONDARY PAINT - HS3 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA SBA Power Steering SCB Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII Build date 11/7/88 Body code JL61 Sold by ELLENA JEEP-EAGLE, LAWRENCE KS
*X3 -SA Charcoal AGC APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PE4 Colorado Red QE4 Colorado Red RAC RADIO - AM/MTR TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 7/20/88 Body code TL61 Sold by JIM TESTA JEEP-EAGLE, KINGS MOUNTAIN NC
Ah yes. Let’s just throw good vehicles away in the current vehicle shortage. That’s fuel to the fire.
I’ll get you some pics. I was working on an 86 this evening actually to get it back up and running to conquer the roads Lol was working on an 86 and had some other things this evening. I am currently rebuilding one. The last two prongs on the ISA are the motor, put power and ground to each one and see if it does anything. If not, it will need to come apart for a possible rebuild. But the screw for the ISA does absolutely help, just the ISA internal motor has to be working in conjunction. So if it isn’t properly adjusted it’ll either run rough or run way to high of RPM.
Steering nuckle spindle
eaglescout526 replied to Everett's topic in MJ Tech: Modification and Repairs
Year and 2wd or 4wd? -
NP231 to NP242 - BA10/5
eaglescout526 replied to howeitsdone's topic in MJ Tech: Modification and Repairs
That should be an easy matter of taking the sensor out and dropping in your old gear adaptor for the cable drive. -
You’re thinking of the 2.5L diesel the XJs over in reichlandia got. That’s a completely different 2.5L.
Need help replacing TPS on 2.8L
eaglescout526 replied to Nat's topic in MJ Tech: Modification and Repairs
TPS? 2.8L V6 is carbureted. Not fuel injection. Unless it’s been swapped. -
Usually everyone on here contacts me and gets a price. And the newer ones are skinny and should fit right where that sender is.
Wellllll in theory you could have two, you would just need two ports and have one sender and one gauge if you have a damn good know how and wire in a lamp into the info center of the cluster if you have gauges. Now if your swapping from the idiot light to the gauge, you’ll need the bigger one to swap in place of the smaller switch. but otherwise we can only have one at a time, not both. The ECU does not need oil pressure as info for it to operate. The one in the original post is the only location for the sender/sensor I highly recommend Mopar sensors as we can still get them and not at such a ridiculous price too
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ CGW Air Bags - Front, Next Generation** DDQ Transmission - 5-Speed Manual EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL RAB Radio - AM/FM SBA POWER STEERING Build date 8/25/85 Body code JL62
*X1 -Q8 3LV 2010.5 Fleet Loyalty Bonus AGJ Driver Assistance Group AGP Limited Decor Group APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT &&&&&&&& REAR DGW Transmission - 4-Spd. Automatic,44RE ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHQ Transmission Heater PQ9 QQ9 RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT WJN 15" Aluminum Wheels Build date 1/17/88 Body code JM62 Sold by JERRY'S JEEP, MANASSAS VA Jerrys Jeep, I love it.
*X1 -SA Charcoal 3LV 2010.5 Fleet Loyalty Bonus AGJ Driver Assistance Group AGP Limited Decor Group APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT &&&&&&&& REAR DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HAA AIR CONDITIONING - FRONT JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NMB ENGINE COOLING - STANDARD DUTY PE4 Colorado Red QE4 Colorado Red RAB Radio - AM/FM SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT WJN 15" Aluminum Wheels Build date 11/16/87 Body code TM61 Sold by NEAL POPE CHRY-PLYM-JEEP, ATLANTA GA
*X1 -Y1 3LR APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MD8 Delete Front License Plate Bracket NAA ESA W/CATALYST (EXC CALIF SYSTEM) PE4 Colorado Red QE4 Colorado Red TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 3/25/87 Body code TL61 Sold by SPARKS CHRY-JEEP INC, CONCORD NC
I mean it seems to be but even from the buyers prospective(me) seems to have the same “ghosting” issue too. I’ve inquired about things on Facebook asking if they’re available before either going and seeing it or wasting my time with the person. I’ve had it to where I’ll ask and I’ll hear nothing and then the item is gone or I’ll get a couple words back and then the person will stop responding and never respond again. Lately I’ve had good luck with some folks over there cause life gets busy and I just check in showing I’m still interested. But I think eBay is the worst place right now. I’ll get folks who throw an offer out and I’ll accept and then they message me after I accept their offer asking about the part and I just end up canceling their order and tell them to do their research before buying parts willynilly. Now granted I am guilty of leaving some people hanging when selling parts and that’s entirely my bad as life gets busy. I do agree though, it sucks having time wasted on a potential sale. What’s more worse to that is say here at the dealer, I pull parts only for the driver to get to our customer to basically say “oh we cancelled that.” Apparently it’s hard to pick up the phone and say we no long need the part.
If your master is still the original nabco one, hang on to it and tear it apart. Those are the factory ones and are much better and worth a rebuild if the cylinder inside is still in good shape.
*X8 Cloth Low-Back Bucket Seats -Q8 167 Zone 67-Charlotte 1AA U.S. Dealer Retail 5AM Largo Tracking 5KN Metro Cars of Detroit ADA Light Group ADB Protection Group ADL Skid Plate Group ALN APA Monotone Paint BAY 105 Amp Alternator BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CAC Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CLA Front Floor Mats CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GNB Driver Side Illuminated Sun Visor GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB K2X STRIPE/BADGE/MOLDING/COLOR K3C STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LAJ Headlamps On Warning Chimes LAP Shift Indicator Warning Lamp LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE Ambient Light LCJ DOME/READING LAMP B-PILLAR LDH U/Hood, Removable/Rechargeable Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LPE Cargo Lamp MB1 Black Front Bumper MBJ Black Bumper MCA MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver MMP MOLDING - DOOR EDGE GUARDS NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon NHM Speed Control PQ9 DRK BALTIC BLUE M CC PRIMARY PAINT - HQ9 QQ9 DK BALTIC BLUE MCC SECONDARY PAINT - HQ9 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAE all-season TBB Full Size Spare Tire TBM Tire Carrier Winch TMW Tires WJM 15X7.0 Chrome Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z67 Left Front Spring Group XVI Z86 Right Front Spring Group XV Build date 4/21/89 Body code JM62 Sold by STUART-BOWMAN AUTO CENTRE INC, ASHEBORO NC
Don't Buy Valucraft Alternators - Shrapnel
eaglescout526 replied to jamcomanche's topic in MJ Tech: Modification and Repairs
Yeah, these guys are the reason why we don’t deal with them. Same customer kept coming in month after month about their power steering pump and they kept buying crap autozone pumps because they were cheap morons who didn’t want to buy a Mopar unit. -
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE AGR Appearance Group AGY Seating Group AJZ BAC 75 AMP ALTERNATOR BCQ Battery -Maintenance Free CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DDQ Transmission - 5-Speed Manual EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAF HIGH ALTITUDE EMISS CONTROL PKG NFA TANK - 23 GAL FUEL NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY RAF RADIO - AM/FM/MTR SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN Build date 10/15/85 Body code JP62
Knocking On Valve Cover 2.5L
Sometimes they pop up on here but salvage yards are your best bet. Maybe try the facebook pages as well. I used to have the ability to get the metal covers but that salvage yard closed down and scrapped damn near everything. -
I can still get a valve cover for them from Chrysler.
