13
Pete, mind double checking the VIN? Last 8 gives me an XJ.
Replaced my TPS with Mopar
eaglescout526 replied to KANTANKRUS's topic in MJ Tech: Modification and Repairs
The square four prong is for the transmission to read the throttle position for when to shift either up for down. -
Dang, looks like I need to change up my search terms. Great find! Great question actually...All I know is my caster is about 5* out from spec due to going to 235's and I was told by one of our alignment techs that itll take a good number of shims to get it correct.
Anyone have a stockpile of them? Theyre the shims that go between the LCA and the frame.
*X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 174 Zone 74-Denver 1AA U.S. Dealer Retail 4HB Special Scheduling Condition II 5KK First American Title Insurance CO. ADH Heavy Duty Electrical Group ADL Skid Plate Group ALA SE Decor Group ALK Italia Package APA Monotone Paint BA1 100 AMP ALTERNATOR BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRK Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KWW T: BRILLIANT WHITE - NAMEPLATES - W LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAF High Altitude Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PX8 Black Clear Coat QX8 Black Clear Coat RA8 Delete Radio SBA Power Rack and Pinion Steering SCB Perforated Steering Whl w/Red Stitch SFB Front Heavy Duty Shock Absorbers SGB Rear Heavy Duty Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TRP 225/70R19.5G All Pos Traction Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z58 Left Front Spring Group Viii Z5B Payload Rating - 1800# Z77 Right Front Spring Group VII Build date 8/10/89 Body code JL62 Sold by LITHIA COLORADO CHRYSLER JEEP, AURORA CO
Other than my network being crap while at work, CC loads fine just about everywhere. Has he tried clearing cookies and browsing history? Sometimes that can cause a clog up.
Aaaaand this is why you go OEM! Now this isnt original to my truck, I got it with another engine, but the fact it took this beating all because the bolt wiggled loose and still managed to start Little Red every day is GD awesome! I did check this only because I had a weird random stalling and starting issue. Now if this was aftermarket it wouldve failed right away, but this goes to show how crap everything is now-a-days. This is now a trophy while the new Siemens/Mopar sensor will take its place. Tighten those bolts and use only AMC|Jeep|Chrysler approved parts.
- 657 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
Effing Continued Effing Brake Effing Issues
eaglescout526 replied to NC Tom's topic in MJ Tech: Modification and Repairs
How new are your front rubber lines? The older they get, the less pressure they can handle. -
*X2 TRIM STYLE X2 - VINYL BENCH -Q8 174 Zone 74-Denver 1AA U.S. Dealer Retail 5AL Low Series Tracking APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB K3Z STRIPE/BADGE/MOLDING/COLOR KDB STRIPE/BADGE/MOLDING LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAF High Altitude Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PB3 QB3 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA Audio SBA SCB steering wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII Build date 10/24/88 Body code JL61 Sold by AUTONATION CHRYSLER JEEP WEST, GOLDEN CO
Yeah, a VIN would be nice. Then I can get you all the info about your truck that still remains in the Chrysler database.
Neat! All I have at the moment is just the shocks. Both front and rear. I can’t imagine this being too hard to find in the aftermarket world and rigging it up to work like factory. Maybe there’s one lingering back east.
I don't know Pete. I’ve been keeping an eye out and seeing if anything is out there.
- 657 replies
- pioneer
(and 2 more)
Tagged with:
Fuel pump bracket
eaglescout526 replied to ftpiercecracker1's topic in MJ Tech: Modification and Repairs
You mean 18 right? Since you have a short bed. -
Fuel pump bracket
What size tank do you have? I have one OEM one left that I’ve been tryin to sell for a while. -
Budget Rent a Car. Dang that’s an interesting one. They probably ordered a few and someone probably wanted to buy it right then and there.
The Jeep homestead
eaglescout526 replied to eaglescout526's topic in Member Projects: Other Cool Stuff
It absolutely does! Haha. Next is to get rid of parts and work on Chunk. Oh and brutally murder a dryer after I get the one from my grand parents. -
The Jeep homestead
New garage door is in wooo!! Granted the door isnt closed here but I got both Jeeps in and thats great! Now the door is really nice. No more opening by hand. Now it gets better. The motor I chose for the door, was discontinued. So I got an upgrade for it. Same with the springs. The springs I chose werent in stock so they gave me a 10 year labor warranty on the install for the door vs the single year they came with the install. -
Lol no biggie. You’re a busy man these days.
*C1 TRIM STYLE C1 - CLOTH &&&& VINYL BENCH SEAT -Y6 DARK SAND 172 Zone 72-Portland 1AA U.S. Dealer Retail 3VQ Customer Preferred Discount 4HA Special Scheduling Condition I ALA ALK APA Monotone Paint BAP 75 Amp Alternator BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRK Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KWW ST-DCL WHT "STLT R/T" LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PG5 Hunter Green Metallic QG5 Hunter Green Metallic Clear Coat RA8 Delete Radio SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBB Full Size Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires TZH Michelin Brand Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGA Without Billable Fuel Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z84 Right Front Spring Group XIII Build date 11/12/90 Body code JL62 Sold by GENE'S JEEP-EAGLE INC, FAIRBANKS AK HAHAHAHAHA. I love the giant Mopar Logo right in the middle of that plow. Thats hilarious.
*Q7 Cloth Low-Back Bucket Seats -SA CHARCOAL 167 Zone 67-Charlotte 1AA U.S. Dealer Retail 3V5 Customer Preferred Discount ADA Light Group ALR APA Monotone Paint ARM Radio AM/FM Cassette BAF 130 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CUF Full Length Floor Console DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHS Floor Mount Automatic Shift Lever DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ Dana 35 Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNC Sun Visors w/Illum Vanity Mirrors GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3X STRIPE/BADGE/MOLDING/COLOR KLT KWD LAJ Headlamps On Warning Chimes LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE Ambient Light LDA Underhood Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LNJ Front Fog Lamps MB1 Black Front Bumper MBJ Black Bumper MCA MDA Front License Plate Bracket MFK Body Color Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PX8 QX8 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBC Compact Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires TZA Goodyear Brand Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z82 Right Front Spring Group XI Build date 10/25/90 Body code JL61 Sold by AUTOPARK CHRYSLER JEEP, CARY NC
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE ADL SKID PLATE GROUP AJT RADIO PREP GROUP AJZ BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual DMN 4.10 Axle Ratio DSA LIMITED SLIP DIFFERENTIAL EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAE EMISS CONTROL TESTING &&&&&&&& LABEL NFA TANK - 23 GAL FUEL NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN Build date 2/6/86 Body code JP62
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ AWJ Visibility Group CGX Head Restraints-Outboard Seating, RR DDQ Transmission - 5-Speed Manual EPD ENGINE - 2.5L I4 TBI GAS GTZ MIRRORS - MANUAL REMOTE HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) Build date 5/20/86 Body code JL62
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MD8 Delete Front License Plate Bracket NAA ESA W/CATALYST (EXC CALIF SYSTEM) NMB ENGINE COOLING - STANDARD DUTY SBA POWER STEERING Build date 10/17/85 Body code TL62
