13
Oil pan issues
eaglescout526 replied to ComancheLover90's topic in MJ Tech: Modification and Repairs
NLA. Discontinued two years ago and no one in the country has it. -
Euramtec cargo lights
eaglescout526 replied to Whitaker717's topic in MJ Tech: Modification and Repairs
They also can be cleaned if you’re a dime short on change. I had some sticky issues with my drivers side and simply unscrewed them and gave them a good wire brush scrub. And popped a fuse along the way lol. -
Brake light on dash
Is you’re E-brake on? That’s the only other thing that would keep the light on. -
*B1 TRIM STYLE B1 - CLOTH &&&& VNL BENCH SEAT -SA Charcoal 171 Zone 71-Los Angeles 1AA U.S. Dealer Retail 4AF 5AL ADH Heavy Duty Electrical Group ADL Skid Plate Group APA Monotone Paint AWE BA1 100 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K3Z STRIPE/BADGE/MOLDING/COLOR KDA STRIPE/BADGE/MOLDING/COLOR LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAE California Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank NMC Heavy Duty Engine Cooling PA2 STERLING SILVER M CC PRIMARY PAINT - HA2 QA2 STERLING SILVER MC SECONDARY PAINT - HA2 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA Audio SBA Power Steering SCB Steering Wheel SFD Front Extra HD Shock Absorbers SGD Rear Extra HD Shock Absorbers SUA Tilt Steering Column TAA All Tires TAE TBB Full Size Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XEA Tow Hooks XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 1/22/89 Body code JL61 Sold by CANOGA JEEP-EAGLE, CANOGA PARK CA
*X4 -YY 3LX AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PYA QYA RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL YJP NEW VEHICLE SERVICE - WINDSOR Build date 12/10/87 Body code TM61 Sold by ANCIRA CHRYSLER JEEP DODGE, SAN ANTONIO TX
*X1 -H9 3LU AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBF REAR BUMPER - STEP TYPE (BRIGHT) MD8 Delete Front License Plate Bracket MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) PXB Olympic White QXB Olympic White RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT TBL TIRE CARRIER - INSIDE WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 5/27/87 Body code TM61 Sold by JASPER JEEP-DODGE-CHRY-PLYMOUTH, JASPER GA
Yup! Plan is to get these done tonight.
PO must’ve not liked that original color.
- 43 replies
Ooo ok. CB is the paint code and it’s Buff Yellow. That’s an uncommon one. That makes more sense since we are seein the bigger picture.
- 43 replies
So on the bottom row of the VIN plate should be the paint code. I can’t tell if it’s the 33(which isn’t right) or the 6VT or YT. Would you mind seeing what is all on that plate? There should also be some letters before the 33. But I think that paint might be sterling metallic.
- 43 replies
AZ Overlander - '86 4x4 longbed
eaglescout526 replied to bruceb's topic in Member Projects: Your Comanches
Thats fantastic to know actually. I am curious about the pound and a half of R134. I got some mixed performance from just 2 lbs but yet added an extra ounce and got way better cooling. Wonder if theres less capacity in the V6 set up. -
Ah crap. I knew I could’ve knocked something out today.
ISO cylinder head
eaglescout526 replied to Strokermjcomanche's topic in MJ Tech: Modification and Repairs
Damn. AMC had quite a few. Ugh if only I could’ve bought their entire inventory. -
Welcome! Highly recommend a build page for your MJ. Hardly anyone looks in the registry at other MJs.
Steering column OEM parts
eaglescout526 replied to knever3's topic in MJ Tech: Modification and Repairs
Go GM with the column parts. -
Actually on the 360 but yes I have both copies on the PS2 as well.
Oh yeah, we have been listening on and off. So far my favorite is still Try To Understand by The Seeds from what we have listened to but there been a few gems we have found. These are the 45's we have liked so far Little Bitty Pretty One/Next To Me, By Clyde McPhatter Bella Dalena/Out Of Limits, By The Marketts You Make Me Happy/My Souvenirs, By Val Martinez Material Things/Back In Love Again, By L.T.D. Yellow Balloon/Noollab Wolley, By The Yellow Balloon. This one is unique as it is the same song on both sides but obviously one is completely played backwards which is really cool. Classical Gas/Long Time Blues, By Mason Williams Band Alfie/Window Wishing, By Dionne Warwick Scratchy/Fire Fly, By Travis Wammack Dirty Water/Rari, By The Standells Sam Hill/Wolverton Mountain, By Claude King. Ill post some more in a bit. Buddy wants me to kick his butt at the original Star Wars Battlefront
No the antenna wire is the same regardless of power antenna or not. Should be easily found in any XJ.
Find an old outback to beat up.
Yeah the printed circuits are known for that. I think the tachs have been weird probably due to cheap resistors on them. That’s my guess as I installed a NOS tach and it works just like the later years. I'm more or less also doing this for guys who want full blue face but can seem to only find the 6cyls around but can’t find the 4cyl tach. But I’d like to roll with eagles idea and add a pot to them for adjustability.
I might make an attempt to do just that. The tach that was in Chunk now has a bad resistor I’m going to replace. I think the one resistor that went bad is what controls the pulses as the tach just pegs out wayyy past 7k. So I might give that a shot.
Anyone have any knowledge on them? I am starting to toy with them and so far they are resistors and two chips. I’m gonna try to see if there’s a difference in the resistors to make future conversions possible for 6 to 4 cyl engines.
Chunk, A 1984 XJ
eaglescout526 replied to eaglescout526's topic in Member Projects: Other Cool Stuff
Now that’s an idea Pete! -
Chunk, A 1984 XJ
Probably would bring in a decent buck. I also never paid attention to the oil pressure gauge until last night when I saw it said 60 in the middle and 120 for the high. I’m wondering what kind of Frankenstein cluster this is. I mean I’ll hang on to it unless someone needs it.
