13
Chunk, A 1984 XJ
eaglescout526 replied to eaglescout526's topic in Member Projects: Other Cool Stuff
Indeed! Hmm. I don't know. I guess I didn’t pay enough attention with the excitement I had for the fog lamps working. I’ll have to take a look and see. -
89 MJ No Turn Signals
eaglescout526 replied to Barnes2001's topic in MJ Tech: Modification and Repairs
I would definitely suggest what Pete said and make sure the right bulbs are installed or arent burnt out. Also clean the grounds if that hasnt been done yet. -
What do you mean? Our MJs are wired that way so the brake light in the rear gets overridden to blink while braking. Otherwise the person behind ya might not know what youre doing. Now if your front stops blinking while youre braking then there is a problem and could point to a crossed wire. -
2.5L electrical fan
eaglescout526 replied to eaglescout526's topic in MJ Tech: Modification and Repairs
I want to revisit this. I think I might be able to try to rig a 4.0L fan in front of the condenser. I see plenty of space in between the grill support and condenser, but my question is this. The only reason I am considering such is just because 1.) I have the fan and 2.)sitting idle in some place for an extended amount of time in the summer say the drive-in would help and allow me to run the AC in the cab while sitting. So my question is this, under normal wiring the fan pulls air from the flat side but if I have it in front of the condenser and wired it regularly it would pull heat and blast it out the grill. If I reverse the wiring it would pull more air in and assist the mechanical fan. Which would be the smart way to approach this? Blast the heat out the grill or assist the mechanical? -
I call that era, “Iacocca’s terrible decision”.
1986 Comanche No Start Condition
eaglescout526 replied to wclegere's topic in MJ Tech: Modification and Repairs
The ISA is completely rebuildable and serviceable. Thought the manual doesn’t say. I have rebuilt one or two with success. -
I mean it will run. The ECU has default readings to get the engine running but as soon as you throttle it the engine sputters and dies due to the demand and the ECU can’t compensate with no TPS. I’ve tried it before but Nick definitely does need it plugged in and adjusted per the factory specs. -
Painting the instrument cluster bezel
eaglescout526 replied to schardein's topic in MJ Tech: Modification and Repairs
Oh yeah. I absolutely love it actually. I thought I was gonna hate it but it actually blends quite nicely in my truck. -
Try this epic. -
What sucks is if I had known there was value in wiper motors, I would’ve snagged a XJ whole cargo area of them.
Just the change over from when Chrysler bought out AMC. Basically what happened was Chrysler made the Eagle until they ran out of parts in 88. Then they keep the Eagle brand until 2001ish till they did away with it. But otherwise it’s just a name change and what the dealer sold.
*Q7 Cloth Low-Back Bucket Seats -SA CHARCOAL 142 Zone 42-Detroit 1AA U.S. Dealer Retail 3V5 Customer Preferred Discount ADA Light Group ALR GTS Interior Package APA Monotone Paint ARM Radio AM/FM Cassette BAF 130 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CUF Full Length Floor Console DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHS Floor Mount Automatic Shift Lever DMD 3.55 Rear Axle Ratio DRJ Dana M235 Wide Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNC Sun Visors w/Illum Vanity Mirrors GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3D STRIPE/BADGE/MOLDING/COLOR KLT KWD LAJ Headlamps On Warning Chimes LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE IP LED Ambient Light Pipe LDA Underhood Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LNJ Front Fog Lamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MCA Rear Body Color Applique MDA Front License Plate Bracket MFK Body Color Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PS7 Dark Silver Metallic QS7 Dark Silver Metallic Clear Coat RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBB Full Size Spare Tire TBM Tire Carrier Winch TRM P225/75R16 BSW On/Off Road Tires TZA Goodyear Brand Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z78 Right Front Spring Group VIII Build date 1/23/91 Body code TL61 Sold by BILL FOX JEEP-EAGLE INCORPORATED, ROCHESTER MI
*Q7 Cloth Low-Back Bucket Seats -SA Charcoal 142 Zone 42-Detroit 1AA U.S. Dealer Retail 5AS Dodge City Tracking 5KR Midland Corporation ADA Light Group ALR GTS Interior Package APA Monotone Paint BAY 105 Amp Alternator BCX Dual 700 Amp Maint. Free Batteries BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUF Full Length Floor Console DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHS Floor Mount Automatic Shift Lever DMD 3.55 Rear Axle Ratio DRJ Dana M235 Wide Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GNB Driver Side Illuminated Sun Visor GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA HW1 JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K2B STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KLH LAF Seat Belt Alert-Driver Seat only LAJ Headlamps On Warning Chimes LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE IP LED Ambient Light Pipe LCJ DOME/READING LAMP B-PILLAR LDH U/Hood, Removable/Rechargeable Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LNJ Front Fog Lamps LPE Cargo Lamp MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MCA Rear Body Color Applique MFK Body Color Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED PRIMARY PAINT - HE4 QE4 COLORADO RED SECONDARY PAINT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TMR 275/40R22 BSW A/S Tires WJH 15X7 Aluminum Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z78 Right Front Spring Group VIII Build date 1/8/89 Body code TS61 Sold by SOUTHWYCK JEEP/EAGLE INC, TOLEDO OH
*E1 Cloth Bench Seat -Q8 142 Zone 42-Detroit 1AA U.S. Dealer Retail 5AM Largo Tracking 5KN Metro Cars of Detroit ALN Body Color Bumper Group APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Dual 700 Amp Maint. Free Batteries BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHT Elec,Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ Dana M235 Wide Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA HW1 JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K2X STRIPE/BADGE/MOLDING/COLOR K3W STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PWB PEARL WHITE PRIMARY PAINT - HWB QWB PEARL WHITE SECONDARY PAINT - HWB RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TAE MUD &&&& SNOW TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TMW P265/60r18 BSW A/S All Terrain Tires WJM 15X7.0 Chrome Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Build date 6/6/89 Body code TM61 Sold by SOUTHWYCK JEEP/EAGLE INC, TOLEDO OH Interesting. Chrysler for the 87 you found has them listed as a A/J/R dealer. This time they are listed as a J/E dealer.
*X3 -H9 AGC Black Ram 1500 Sport Group APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS HAA AIR CONDITIONING - FRONT JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHQ Transmission Heater PWB QWB SBA POWER STEERING TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 11/24/87 Body code TL61 Sold by JACK MILLER JEEP, KANSAS CITY MO
*B1 TRIM STYLE B1 - CLOTH &&&&&&&& VNL BENCH SEAT -H9 AGC APA MONOTONE PAINT PACKAGE BCQ Battery - Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HAA AIR CONDITIONING - FRONT JHA WINDSHIELD WIPERS - DELUXE K60 BODY SIDE MOLDINGS - VINYL LMA HALOGEN HEADLAMPS NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NHQ Transmission Heater PYC QYC RAB Radio - AM/FM SBA POWER STEERING SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJM Wheels - 15 x 7.0 Chrome Build date 5/26/88 Body code TL62 Sold by SHOEMAKER'S JEEP INC, ALLENTOWN PA
*A6 Seats - Vinyl High Back Bucket -Q8 3LT AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDJ 5SPD MANUAL TRANS A881 (JA-41) ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBF REAR BUMPER - STEP TYPE (BRIGHT) MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) PXF QXF RAC RADIO - AM/MTR SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 10/29/86 Body code TM61 Sold by SOUTHWYCK A-J-R INC, TOLEDO OH
*X1 -Y1 APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DDQ Transmission - 5-Speed Manual EPD ENGINE - 2.5L I4 TBI GAS GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MD8 Delete Front License Plate Bracket NAA ESA W/CATALYST (EXC CALIF SYSTEM) PE4 Colorado Red QE4 Colorado Red TBG SPARE TIRE - COMPACT Build date 1/5/87 Body code JL62 Sold by MOTOR CITY A/J/R INC, WARREN MI
Please tell me you grabbed that dash bezel!?? *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE AJZ APC TWO TONE PAINT PACKAGE - II BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGF H D A904 AUTO TRANS DMN 4.78 Axle Ratio EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I MWF BOX SIDE RAILS NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL NHB AUX./H.DTY TRANS OIL COOLER NHM AUTO SPEED CONTROL NMC MAX ENGINE COOLING RAB Radio - AM/FM SBA POWER STEERING SUA TILT STEERING COLUMN Build date 10/8/85 Body code JP62
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR DGZ Transmission- 4-Spd. Automatic,MT643 EFB ENGINE - 2.8L GM 6CYL HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NMB ENGINE COOLING - STANDARD DUTY Build date 6/16/86 Body code TL62
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ CGX Head Restraints-Outboard Seating, RR DDJ 5SPD MANUAL TRANS A881 (JA-41) EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAE EMISS CONTROL TESTING &&&&&&&& LABEL NFA TANK - 20 GAL FUEL RAC RADIO - AM/MTR SBA POWER STEERING Build date 10/2/85 Body code TL62
Wiper + Washer Debugging
eaglescout526 replied to acfortier's topic in MJ Tech: Modification and Repairs
He’s done that in his build which still has me concerned about resistance in his wiring. -
Definitely check for resistance everywhere including ground post to body on the MJ itself. Sure it shows you getting full 12v but as soon as it calls for a load, the voltage won’t be enough to meet the demand. -
Have you checked for any melted plugs or any resistance in the wires?
