eaglescout526
Administrators
    13
  1. I will get a pic this evening. It’s over on the passenger side tucked behind the battery. But I imagine by the 87 model year the connector for the headlamps changed.
  2. *X2 TRIM STYLE X2 - VINYL BENCH -SA Charcoal 167 Zone 67-Charlotte 1AA U.S. Dealer Retail 4EA Sold Vehicle 4HC Special Scheduling Condition III 5AL Low Series Tracking APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed Manual Transmission DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB K3Z STRIPE/BADGE/MOLDING/COLOR KWW T: BRILLIANT WHITE - NAMEPLATES - W LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PX6 CLASSIC BLACK CLR CT PRIMARY PAINT - FX6 QX6 CLASSIC BLACK C CT SECONDARY PAINT - FX6 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Build date 11/1/88 Body code TL62 Sold by SPARKIE'S CHRYSLER DODGE JEEP, FOREST CITY NC
  3. *X3 -Q8 AGC APA MONOTONE PAINT PACKAGE BCQ Battery - Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DGW Transmission - 4-Spd. Automatic DSA LIMITED SLIP DIFFERENTIAL DTA ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS HAA AIR CONDITIONING - FRONT JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBG Bumper - Rear Step, Painted MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHQ Transmission Heater PWB QWB RAC RADIO - AM/MTR SBA POWER STEERING TBB CONVENTIONAL SPARE TIRE WJD WHEELS - 15 X 7.0 STYLED STEEL XPF PROTECTIVE COATING AND REMOVER Build date 3/20/88 Body code JL61 Sold by COURTESY PONT-JEEP-EAGLE, HONOLULU HI
  4. Weather pack should be just as good if not better than the metri-packs. Now the lock solenoid is its own connector and I’m not sure if that connector is around or not but it might be. I haven’t had to look for that one specifically.
  5. For having down just power locks, all I can say is, get a enough length of wire, set up the system outside of the truck to ensure you have it all wired right and I recommend OEM connectors but you can choose which ever you like.
  6. I saw a guy use some sort of powder once on a ground nest and it made them spaz out from the poison. He then later at night went and drowned the nest and put a screen over the hole just so that way none came out.
  7. Theres a 7.5 amp fuse on the block that believe it or not runs the power from the switch on the trans to the reverse lamps. I am pretty sure that fuse is in the "Trans" slot. Also the switch on the trans could be bad or stuck.
  8. Sounds like you might want to do some ground cleaning/upgrades. Also that fuse does control the lamps as well. And if you havent, the front headlamp harness upgrade is a must.
  9. Sounds good! I looked in the digital catalog and got nothing.
  10. Do the rims or caps have a part number anywhere?
  11. Hmmmm I can do some digging on the older Chrysler cars and see. Very interesting choice by them.
  12. Gotta see that engine bay but the valve cover is always one for me, the radiator if original is another. AC stuff is a must for some. I know @carolinajeepman is after AC stuff to get his done.
  13. Of course! I love me some 2.5L parts.
  14. Still absolutely pretty cool. Course I guess you could just add in your own screen to the grill these days. But it is better to have an OEM part.
  15. Thats pretty awesome. Wonder why no one makes those.
  16. I have both styles of that cover in the same color Anti chaff? Where at the grill?
  17. This connector is cheese. Damn you non existent Pack-Cons!!
  18. What’s wrong with the body?
  19. I know. Just testing something here.
  20. That’s pretty awesome! The one I have still has the original dealer sticker on it and the company still exits at the address on the sticker!
  21. Yeah it’s a marvelous machine I will say. My great grand mother had it since new according to my grandmother. It’s enjoyable to use oddly enough.
  22. All but one set of florescent lamps have been converted to LED. Found out that one of the garage ballasts leaked pretty damn badly and the other one was starting to fail. Glad I changed them out. And how many of you can say you had to do repairs/fixes to a 50+ year old Kirby vacuum? Had to change out the dual speed switch on mine after the originals 54 year run gave up on the floor setting but I now can finally use the hose again after the switch being stuck on the floor speed.
  23. *C1 TRIM STYLE C1 - CLOTH &&&& VINYL BENCH SEAT -SA CHARCOAL 174 Zone 74-Denver 1AL U.S. State/Local Bid 3AC Price Protection - Code C 4EA Sold Vehicle 4FA Special Bid-Ineligible For Incentive 4FM Fleet Option Editor 4KA Special Bid Handling ALA APA Monotone Paint BAP 75 Amp Alternator BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRK Dana 44/226MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer K3Z STRIPE/BADGE/MOLDING/COLOR KWX EAGLE/SUMMIT DECALS BL LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAF High Altitude Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PW7 Bright White Clear Coat QW7 Bright White Clear Coat RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFB Front Heavy Duty Shock Absorbers SGB Rear Heavy Duty Shock Absorbers TBB Full Size Spare Tire TBM Tire Carrier Winch TRP Tires TZA Goodyear Brand Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGA Without Billable Fuel Z01 Rear Spring Group I Z58 Left Front Spring Group Viii Z5B Payload Rating - 1800# Z77 Right Front Spring Group VII Build date 11/19/90 Body code JL62 Sold by POLLARD JEEP OF BOULDER, BOULDER CO
  24. I recommend dropping Apple vidoes into say the onedrive and drop a link here or convert the file but CC can only host a certain size for the video.
  25. I’ve been doing some digging on those too. I think the problem with these connectors not being remade is they are rebuildable which is a smart idea but bad if one melts or breaks completely.
