garyweb3
1534 profile views
garyweb3's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. The plunger on my ISA never moves in either direction on my 2.5. What is supposed to control the action?
  2. Boots usually stay with the caliper.
  3. These are the best pictures I could get. The number stamped on the pulley is 8953003805. Hope this helps.
  4. Where did you get the renix engine monitor?
  5. The PS pulley on my 2.5 is 5.25"diameter X 1" wide. Maybe the OP can measure the one he has to confirm it's the same.
  6. That is not an idler. The idler is smooth with no grooves. The assembly looks like the bracket that holds the PS pump on my 2.5. The only thing that confuses me is the pulley should be attatched to the pump. Unless that is still attatched to the bracket also.
  7. I bought the available ones that are larger and drilled out the holes that the clips insert into.
  8. I'm in northeastern WI.
  9. I have the pump and the steering box. Both from a 87 Comanche 2.5. $50 for the gear and $25 for the pump plus shipping and the gear is heavy.
  10. Thanks. I'll check that out.
  11. Did you use the 46003 or the 46004?
  12. I have a 1987 Comanche and it says this part will not fit. Is there one that will fit an 87?
  13. I run 215/70/R15 Radial TA's on my 87 Comanche with the same driveline as your truck. They're on the factory alloy wheels. Been on the truck for over 30 years. Not the same tires the whole time.
