garyweb3
Everything posted by garyweb3
  1. The plunger on my ISA never moves in either direction on my 2.5. What is supposed to control the action?
  2. Boots usually stay with the caliper.
  3. These are the best pictures I could get. The number stamped on the pulley is 8953003805. Hope this helps.
  4. Where did you get the renix engine monitor?
  5. The PS pulley on my 2.5 is 5.25"diameter X 1" wide. Maybe the OP can measure the one he has to confirm it's the same.
  6. That is not an idler. The idler is smooth with no grooves. The assembly looks like the bracket that holds the PS pump on my 2.5. The only thing that confuses me is the pulley should be attatched to the pump. Unless that is still attatched to the bracket also.
  7. I bought the available ones that are larger and drilled out the holes that the clips insert into.
  8. I'm in northeastern WI.
  9. I have the pump and the steering box. Both from a 87 Comanche 2.5. $50 for the gear and $25 for the pump plus shipping and the gear is heavy.
  10. Thanks. I'll check that out.
  11. Did you use the 46003 or the 46004?
  12. I have a 1987 Comanche and it says this part will not fit. Is there one that will fit an 87?
  13. I run 215/70/R15 Radial TA's on my 87 Comanche with the same driveline as your truck. They're on the factory alloy wheels. Been on the truck for over 30 years. Not the same tires the whole time.
  14. Sounds like the wire to the horn is grounded somewhere.
  15. So is this just for the 4.0 and not the 2.5?
  16. I had the same problem on my fog lights.
  17. I'm glad you clarified that I didn't get that from the previous posts.
  18. CPS is crank position switch correct?
  19. There was a guy on this site that was looking into getting rear slider windows made.
  20. I made my slots wider with a Dremel.
  21. I traced the hoses today and the one that goes to the VAC port does indeed go to the intake manifold in a round about way and the other ports hose goes through the firewall into the cab.
  22. I blew into both ports. The one labeled VAC must have the check valve because I could not blow into it. The smaller port I could blow into. So why is the port that I could not blow into labeled VA? I haven't traced out the hoses yet.
