garyweb3
Everything posted by garyweb3
  1. So I picked up a pair of buckets from a 2 door 95 Cherokee from a salvage yard.These seats have 2 separate pedestals per seat unlike the ones in the diagrams. Has anyone used these type and what would need to be done to get them to work?
  2. Thanks for your quick reply.That's what I kind of got from the circled pictures but wasn't sure.
  3. So will 2 door Cherokee buckets swap in with the brackets they come with or will I have to modify them in some way?
  4. Picked one up in a local yard.Thanks for your replies.
  5. I'll have to check that out.
  6. Thanks .I'll keep you in mind.
  7. No,I did not.
  8. I'd like to replace mine too. Does anyone make an aftermarket one for Comanches?
  9. Thanks for the reply dustyinthedirt. I'll keep you in mind if I can't find a black one.
  10. Just the part that clips into the door and has the lock cylinder in it.
  11. I need the latch from the glove box.Prefer black.This is for a 1987 Comanche.Not sure what other years or if Cherokees will fit.
  12. I've had the same thing happen to mine numerous times. I just glue it back together.
  13. Yes I'm interested. Not sure how to PM you.
  14. Wanted: Factory speaker brackets that are for the speakers behind the rear seat in a '87 Comanche.
  15. Yes,my brackets look like the two in the picture. The holes on the far left don't line up.
  16. I purchased a new after market bumper last fall After getting it painted I didn"t get it installed because the factory bumper brackets will not work with the new bumper and the bolts holding them on are so rusted the heads just round off.It got to late for me to attempt it last year so it got put aside.It looks like I'll have to grind off the old bolt heads,drill out the old bolts and probably retap the existing captured nuts.I got started today and ground off 4 of the 8 bolt heads.When I put the new brackets up against the existing one the holes in the new bracket don't seem to line up very well.It looks to me like I have to use the front 3 of the 4 but only 2 of the 3 on the new brackets line up.Has anybody installed this bumper and did you have the same problem? Did you redrill the bracket holes? Any tips and past experience would be welcome. Thanks.
  17. Thanks,hornbrod.
  18. Try www.theamcforum.com.You might have better luck there.
  19. I also have an '87 but with the 2.5. I picked up a guage cluster a while ago but haven't got around to installing it yet. My question is: it presently has after market guages(temp,volts,oil) and tach. Will the after market sending units work with the factory guages?
  20. Thanks for your input. Looks like I won't use C2C.
  21. Has anyone installed replacement floor pans from Sherman Parts or Classic2current? Fit/quality?I'm specifically asking about Comanches.
  22. jeepsticker.com has the taiigate Jeep stickers. I just bought some.
  23. I see he also offers Sportruck stripes but only in silver.I need black.
  24. I.m in Wisconsin
  25. jmaxj are you willing to part with one?
