Kaiserman
1 Follower
1068 profile views
Kaiserman's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. The wheels on my 87 XJ are a mix of US and W. Germany. I didn't notice the minor differences until after I had them powder coated.
  2. CJ 258 egr's are the same as the 87 4.0l. The PN on my original crossed to a CJ part. I've been running it with no issue. Could always put one on the 88+ instead of blocking it off.
  3. So my used one was melted as well. Just not bad enough to be obvious when it was still on the switch. If anyone is interested in knowing, the plug is the exact same as the 63-7? full size Jeeps. I happened to have one right on my bench in the garage. It was only very slightly melted. Almost like this is a common thing with Jeep, right?
  4. Kaiserman
    Bug shield
    They are just flat stainless pieceswith a couple of bends in them. I took pics of the ones on my 87 when I installed it.
  5. Kaiserman
    Bug shield
    I have a new clear one marked for XJ/MJ but it's missing the brackets.
  6. I ended up with a used one. I was curious if a 79-86 FSJ plug would fit. All of my FSJ' plugs are for the older 63-78 switches though. I'd still like to find a new one just to toss on the shelf. Hoping to run the winter with just a new plug before upgrading to the relay set up for the lights.
  7. Any chance you have a PN? I can't find any listed for 91 and older.
  8. Can't hurt to have some wires with it. Mine look ok but I was wasn't able to get a great look at it last night. Need to pull the lower dash for better access.
  9. Sorry, yes that should have read headlight switch plug. I changed the title. No one lists a connector for 91 and older. I had read online the 92+ are a little different.
  10. Plug melted on my 88 and I lost parking/tail/gauge lights. Did a quick look around and can only find 92+ plugs. Does anyone have a good PN for the 91- connector? Thanks.
  11. I'm in Orange MA. Doesn't need to be perfect, it's going on a plow rig/winter driver. Mine is missing.
  12. Looking for a red wiper cowl. For an 88 if it matters for color shade. Thanks.
  13. No, I bought this from a Jeep dealer in New Hampshire.
  14. What part of RI is Dead Jeeps in?
