eaglescout526
Administrators
    13
  1. There was something in the FSM regarding this actually. I would have to find it unless someone beats me to it.
  2. Probably the early ABS I think.
  3. Like the speedo gear itself in the trans? That gear is supposed to be changed out when you go up in tire size.
  4. Kinda sounds like a blown head gasket. I had that issue where it would idle fine (IE going into open loop mode) then it would go back into closed loop and it would suffocate itself from the coolant intake.
  5. I always have my work do AC stuff for me. Now I’d really like to learn and do it all myself for when my family has issues that way I don’t have to play the vehicle shuffle with them.
  6. They should be Pack Con III terminals.
  7. Most folks leave it in power. Basically all it does is it switches a wire in the TCU to change when the trans shifts. So in comfort you won’t feel the trans shift hard. It’ll shift sooner than it would in power mode.
  8. Ball joints have been replaced, Last time was 2018 if I recall. I honestly have no idea if it has helped with my steering issues since that little accident. I definitely had to replace the tires due to increased wear on the inside edge of the tire. I do see an improvement in camber but if this doesnt help then I will have to swap 2wd axles around and hope that fixes the issue if the front axle is slight bent. Orrrrr I can swap knuckles around for the knuckles that have the split rings and get camber adjust split rings. But if the axle was bent I would have castor at this point rather than camber as I can't imagine something heavy dropping on the axle to cause this issue. Old ball joints did feel odd compared to the new ones so I can only hope. At some point I will have to get an alignment again. Oh well, 30+ year old Jeep issues. What can ya do? Guess Ill find out with the alignment. Brush guard next and then an alignment. Or vice versa.
  9. *X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 154 Zone 54-St Louis 1AA U.S. Dealer Retail 5AM Largo Tracking APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMF 4.10 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS EPD ENGINE - 2.5L I4 TBI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRC GUB Power Mirrors-Base HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JJA Cigar Lighter JKB K2X STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED PRIMARY PAINT - HE4 QE4 COLORADO RED SECONDARY PAINT - HE4 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA Audio SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAD HIGHWAY TREAD TBC Compact Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YEA No Optional Sales Codes YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z56 Left Front Spring Group Vi Z75 Right Front Spring Group V Build date 5/8/89 Body code TM61 Sold by ABSHER-ARNOLD MOTORS, LLC, MARION IL
  10. Lol no not yet. This one I want to do over a two day weekend, just in case something wonky happens. Not sure what would happen but anything could.
  11. It’s OEM. I have an OEM transcooler I’m trying to sell so yes it was a factory or dealer add on.
  12. If you have fog or the cargo lamps, swap the switch around and test it. If it works, the switch is good. If not well the yes the switch is bad. Rarely do these switches fail, I had one but the prong came off from the back from weak soldering but even then the switch still worked. Does your trans shift at all?
  13. No. I had to work yesterday.
  14. 84-85 for that cowl panel. Those are rare and hard to find not broken up b
  15. *X1 -YY 3LX AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHB HVY.DTY/AUX TRANS OIL COOLER NHQ Transmission Heater NMB ENGINE COOLING - STANDARD DUTY PE4 Colorado Red QE4 Colorado Red RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 9/17/87 Body code TM61 Sold by CLOVERLEAF CHRYSLER DODGE JEEP, DECATUR AL
  16. vintage NEW OLD STOCK JEEP WAGONEER STEERING WHEEL maroon burgundy 1984? | eBay Not a bad starting price. Worth it if someone is looking for an upgrade.
  17. No light probably means bad ground. The switch is the same as the fog lamp switches.
  18. Ah haha I had a feeling. Sounds like you have an 86 by the sounds of it. But it takes time to get it clean and neat. I’ve seen worse 2.5Ls that just were a block of sludge and under the sludge somewhere was an engine lol. But at least you have an example to go off of. I kinda didn’t when I first started.
  19. I did read in one of the older posts that the factory power steering shaft has some sort of rubber vibration dampener in it, I suspect mine being the original is probably long worn out as with the u-joints. Seems like going new is a good idea. That being said has anyone tried out any other shafts like a ZJ or a GM one for some beef?
  20. So I did a search and came across a few topics, some wanted, some wanting to know where to buy and some as to what to do. and the newest was I think a couple years ago or so but I want to get a general idea as to what yall think we (as our MJs age and the less serviced parts need to be addressed)should do. Should we get them serviced or should we bite the bullet and just simply replace aging parts as the newest XJ is now 20 years of antiquity and even if its low miles, who knows how long it has been sitting or if its better or worse than new. Honest opinions and ideas welcome. I think its time to replace mine as I go through another steering debacle.
  21. Lol. Either Sunday or the following weeked.
  22. Here is where all the interior based parts for XJs and MJs will go. Remember, ALL parts will be CLEANED before shipping. *Shipping for smaller parts is $6. Larger parts may very. Clock Delete plate. $5. Fits all years. 4 on hand* Seat belt guide covers. $5* I think I have two garnet left Grab(OH $#!&) Handles and pieces. $15 for a handle, $3 for the little covers, $5 for the little hook. 2 Cordovan Sold.* Auto trans shift handles. $10* Glove box light. $10* 1 in stock Head lamp switches. $15* 3 in stock Command-trac bezels. $10* Auto trans floor shift indicator. missing the indicator portion but it seems this bezel can come apart. $10* Ash trays. $15* 97-01 XJ dash switches. $15* Garnet passenger side visor and will include an MJ only harness. Lights do work. $50 Charcoal pass visor. Mirror seems to have fallen out of place which is a new one by me. Will include an MJ only harness. If it’s for an XJ let me know. $50 Glove box door. $25 2 in stock Seat adjuster handle knobs. $5 ea. 2 on hand.* B-pillar MJ seat belt. Only the passenger side left. $40 Upper half of a limited XJ vinyl seat cover in what looks like charcoal. I spent a few days restoring this seat back to its color(no painting, only vinyl cleaner was used). The way I see it, this cover it probably only good for material use I.E. repairs to an already existing complete seat. I would hate to just toss it the wayside as it can provide use somewhere. $30. (looks to be from a 90 XJ) XJ limited charcoal vinyl headrest. Spent a couple days restoring the color(no painting involved) of this headrest with vinyl cleaner. I think it turned out great. Perfect to replace your damaged head rest or paint over it to replace any other color headrest. $20. (looks to be from a 90 XJ) Bucket seat foam wings possibly from a 90 XJ bucket seat. These are in great shape. Perfect to replace your worn out ones. $25. MJ Bucket Pass side rail cover. $20. 89+ Seat belt guide cover bolt plug NOS(have 2). $10* Oh and a rubber grey one as well. Upper half of a pass side black power seat. It has the reclining handle and it has been cleaned as well. Vinyl looks to not have aged well but is in pretty good shape. $150. Cig lighter socket $5. All are untested, most are in good shape with minimal rust. Not sure why in the hell I have them(and the lamps and brackets)but they are perfect if your socket isn’t working or destroyed.(13 in stock). I also have two that don’t have the mounting hole for the lamp.* Cig lighter light. $5*(7 in stock) these all have been tested. All work but some have a couple burnt out bulbs. Cig lighter plate/bracket. $5. (17 in stock) these will be cleaned before leaving my possession. GM chime module. Tested, it works for the keys in but not seat belt. Pin out could be different for that but hey it’s not a buzzer. $20 High beam switches. All look to be in good shape. $10 ea. These are for 84-88 less flash to pass feature. They are genuine. weather they work is unknown. Maybe I will test them when I get the chance. Black shift handle. $10 Brake switch, Renix era, non cruise, $7 Chrysler era GM RA5 key ignition switch, very used, key is worn but not severe. $20 HO era Jeep chrome door handle bezels. $20 for ones with switches, $15 for ones without. #1 #2 #3 #4 #5 #6 HO era Jeep chrome woodgrain door handle bezels. $25 #1 #2 HO cluster. Parts only. Here’s an update on how it sits currently. Throw me an offer on the parts you need. Tach gone. Idiot light clusters. White one is HO and blue is 84-86 Renix. Make me an offer, I know these aren't desirable in any way but I can part them out or sell whole. Honestly, theyre just good for extra bulb sockets. HO speedo. $25. Yes I know the needle is broken. Probably can be swapped with any other needle. Chrome door handle bezels. $10 a piece 1 2 3 4 5 Door handle assemblies of various conditions. $20 or can part out. I have numerous of both sides available. None of the lock buttons paint remains on them.
