13
New Cargo Light Option
eaglescout526 replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
Really? I’ve never had an issue with any of the ones I had in my hands. Ran them through a vinegar bath to help clean up the brass contacts and they all worked with no issue or loose pieces. Interesting that yours had issues. -
Done. Shame the dealer building doesn’t stand anymore.
AZ Overlander - '86 4x4 longbed
eaglescout526 replied to bruceb's topic in Member Projects: Your Comanches
Couples miles North of Grand Ave on Cactus. But yeah N Phx. -
Alignment Brainteaser
eaglescout526 replied to eaglescout526's topic in MJ Tech: Modification and Repairs
I’ll keep an eye on my tires and watch out for uneven wear. I am on a new set and since I went up in size, I probably need to adjust the shims accordingly anyways. I appreciate everyone’s help with this! I understand a bit more of what’s goin on. -
Man you were up in Wickenburg and didn’t stop by to say hi on your way back!? Looks like a fun trip though. -
So that’s where the passenger side high trim level charcoal went. Yeah nothing sucks more than installing one of those panels and having to surgically make the cuts to have the speaker, crank and screw holes for the speaker cover and map pocket. That was a fun hour spent.
I’m just trying to have everything in the steering department be correct and not chewing through tires before their lifespan. That’s all. I’m looking into getting some shims soon. -
looking for your Comanche literature
eaglescout526 replied to Pete M's topic in MJ Tech: DIY Projects and Write-Ups
The emissions book is pretty cool actually. I think I am gonna go hunt for that one. Yeah the library grows and will continue to grow. I think my favorite finds are the accessory books and the Jeep engine books. -
Thats exactly what I think it is as well judging by the wear but my thought was that our tires wear evenly from inside to out. Not sure now on that. I thought about those and tried that 1* adjuster kit and I couldnt and can't use them due to the 2wd knuckles being different in the 87-90 years than the early years. I still wonder why AMC made a different knuckle design for 2wd after 86 when it wouldve been cheaper to use the same setup. -
I think all mine are 1/32" shims. I didnt see anything thicker or thinner than each other. -
Absolutely fun! I wonder why the specs are like that? Let alone eating the insides of tires. Seems like I will have to stick with an aggressive rotation schedule. -
6 on the driver and 7 on the passenger. -
So if thats 7*-8* inward than do I need to remove shims? But it could also be worse from the increased tire size and who knows what all my grandfather did to the MJ prior to my ownership. -
If it did it looks like it brought the caster in by a degree judging by the print outs. The only other differing factor is I’ve gone up in tires size. 2017 was the original 205 size and still had the caster. Went up to 215 in 2019 and then 235 this year and caster is still bad. I’ve examined the frame and area multiple times for any sign of buckling or damage and I still can’t find anything. -
Yup! Twice. Once with polys(biggest regret) and again to replace the ploys back to factory rubber. Basically everything is new up front minus the axle and knuckles. -
So I requested some LCA shims recently and my issue seemed to have sparked some curiosity as to why I need them. I for the life of me CAN NOT seem to figure my issue out. Lets go back to 2017. I went to get an alignment and tech said, replace all steering parts and Ill do the alignment. Ok done. Drove straight and no issues. Suddenly 2018, tires went bald on the edge really fast. Was told they were the ball joints to cause this issue. Ok replaced them as they were the original ones from the factory and they were toast. Got an alignment and drove straight and fine with the exception of a pull from the right side. 2019 Got new tires, no issues. 2021, had that little accident(repairs performed) and tires went bald again on the edge fast. Ok I have seen this before. Got new ball joints and put them in. Alright, got an alignment and tech said caster is off by alot. He recommended shims to fix the issue or better correct it and prevent my front from eating up tires. I do plan on getting a new steering shaft to remove the remaining slop issue in my column. My stinking issue is, why is my caster so screwed up? I have replaced damn near everything except the front axle itself and the knuckles and the 1 piece rotor/hub combo. Any ideas? Here is all the print outs of the alignments I have had performed to Little Red: 2017: 2018: 2021:
Oh damn you’re right lol. Let me see what pics I’ve taken and take pics of what I don’t have. -
Fixed. Must’ve been an off day for me yesterday.
Nope and I’ve been battling this issue since 2017 according to all the alignment paperwork I have had. At some point I’ll have to suspect the 2wd beam has some metal fatigue but I honestly have no idea.
Need a PDF of those instructions if we don't have those some where.
Holy $#!&! Factory brush guard! *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ AJC CENTER CONSOLE PACKAGE CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL SBA POWER STEERING Build date 5/12/86 Body code JL62
*ZZ TRIM STYLE ZZ - BUCKET SEAT -ZZ ADB PROTECTION GROUP PACKAGE AGY Seating Group AHL HEAVY DUTY INSUL PACKAGE AJS AJY Popular Equipment Package APC TWO TONE PAINT PACKAGE - II BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DGX TRANSMISSION - AUTOMATIC EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS LNJ DUAL ROAD LAMPS MBJ Bumper - Front, Black MCA FRONT BUMPER GUARDS MCB MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I MWF BOX SIDE RAILS NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NMB ENGINE COOLING - STANDARD DUTY RAF RADIO - AM/FM/MTR SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE WJM Wheels - 15 x 7.0 Chrome Build date 2/24/86 Body code JM62
