eaglescout526
Administrators
    13
  1. What are the head lamp relay stickers ? These ones that I made:
  2. I mean I already have an original NOS set, usually I am the first to hear about his projects. Hopefully once these are set and ready, I will see those headlamp relay stickers I made last year. I wonder why he took these on first and didnt finish the body molding project.
  3. I saw that too. I am surprised I didnt hear about it first from him directly.
  4. That would make it an 86. Double check the one on either the front radiator support(86 only) or the firewall(87-92) to see if the VIN matches. It is possible someone swapped dashes around and not the VIN plate for the dash.
  5. So what’s the last 8? The last 8 can tell us the model year. As for AMC, AMC owned Jeep from 1970-1988. 86 is a weird year but some are labeled as AMC and others as a Jeep but it’s still a Jeep. So no need to be concerned there. Feel free to gander the registry as well. GT is 86 HT is 87 JT is 88
  6. Yes, some people want to do away with it in favor of the metal one just because the bottle is plastic and 4.0L guys can use it as an upgrade and move away from the closed system.
  7. He’s got a 2.5L so it’s gonna look a bit different for him.
  8. Welcome!
  9. I fixed this issues actually. I just put a bolt through the other side to flatten that alignment hole and I haven’t had any issues. Also it helps if the tailgate is pushed toward the drivers side and everything is lubed as they should be. Then you’ll get quiet closing and latching results.
  10. If you’re gonna pull everything out related to the emission system, I would experiment with unplugging the solenoid and just leaving the vac line attached just in case the engine doesn’t perform as well as it should. Granted it should still run just fine with or without but I would do it like that just so that way it’s an easy quick reversible mod if it doesn’t work out. Now as far as the bolts in the aluminum, they should still come out but I can’t imagine them being seized or “welded” together.
  11. NLA. Discontinued two years ago and no one in the country has it.
  12. They also can be cleaned if you’re a dime short on change. I had some sticky issues with my drivers side and simply unscrewed them and gave them a good wire brush scrub. And popped a fuse along the way lol.
  13. Fixed.
  14. Is you’re E-brake on? That’s the only other thing that would keep the light on.
  15. *B1 TRIM STYLE B1 - CLOTH &&&& VNL BENCH SEAT -SA Charcoal 171 Zone 71-Los Angeles 1AA U.S. Dealer Retail 4AF 5AL ADH Heavy Duty Electrical Group ADL Skid Plate Group APA Monotone Paint AWE BA1 100 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K3Z STRIPE/BADGE/MOLDING/COLOR KDA STRIPE/BADGE/MOLDING/COLOR LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAE California Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank NMC Heavy Duty Engine Cooling PA2 STERLING SILVER M CC PRIMARY PAINT - HA2 QA2 STERLING SILVER MC SECONDARY PAINT - HA2 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA Audio SBA Power Steering SCB Steering Wheel SFD Front Extra HD Shock Absorbers SGD Rear Extra HD Shock Absorbers SUA Tilt Steering Column TAA All Tires TAE TBB Full Size Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XEA Tow Hooks XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 1/22/89 Body code JL61 Sold by CANOGA JEEP-EAGLE, CANOGA PARK CA
  16. *X4 -YY 3LX AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PYA QYA RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL YJP NEW VEHICLE SERVICE - WINDSOR Build date 12/10/87 Body code TM61 Sold by ANCIRA CHRYSLER JEEP DODGE, SAN ANTONIO TX
  17. *X1 -H9 3LU AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBF REAR BUMPER - STEP TYPE (BRIGHT) MD8 Delete Front License Plate Bracket MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) PXB Olympic White QXB Olympic White RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT TBL TIRE CARRIER - INSIDE WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 5/27/87 Body code TM61 Sold by JASPER JEEP-DODGE-CHRY-PLYMOUTH, JASPER GA
  18. Yup! Plan is to get these done tonight.
  19. PO must’ve not liked that original color.
  20. Ooo ok. CB is the paint code and it’s Buff Yellow. That’s an uncommon one. That makes more sense since we are seein the bigger picture.
  21. So on the bottom row of the VIN plate should be the paint code. I can’t tell if it’s the 33(which isn’t right) or the 6VT or YT. Would you mind seeing what is all on that plate? There should also be some letters before the 33. But I think that paint might be sterling metallic.
  22. Thats fantastic to know actually. I am curious about the pound and a half of R134. I got some mixed performance from just 2 lbs but yet added an extra ounce and got way better cooling. Wonder if theres less capacity in the V6 set up.
  23. Ah crap. I knew I could’ve knocked something out today.
  24. Damn. AMC had quite a few. Ugh if only I could’ve bought their entire inventory.
  25. Welcome! Highly recommend a build page for your MJ. Hardly anyone looks in the registry at other MJs.
