Location
Commerce Ga.
Interests
Off-roading, Guns, Fast cars, Building new things
759 profile views
Thorwon's Achievements
Can Spell Comanche (2/11)
Somebody bring me $1500 and come get this.
I have a 1986 Jeep MJ 2WD pick-up for sale. I have the title for it. I will sell the engine/trans and all supported wiring/computer for $1000. This Comanche is a project with a 1995 Chevy 5.7L (350) engine and a 4L80 transmission. The engine/trans and wiring harness came from a 1995 G20 van with about 65K miles on it. The engine starts and runs great. But the install is far from finished. It still needs a cooling system the exhaust and the driveshaft built. It will need the dash installed and probably a few other small things. It will need a front clip also. I have this listed on marketplace. There's a video of the engine running. https://www.facebook.com/marketplace/item/1964877190744398
1989 MJ XJ 4.0L 2 wheel drive manual transmission under hood wiring harness and computer. $200 This is the harness that doesn't have the 101 plug. This is the complete under hood wiring harness, as far as I can tell. From the fuse block to the head lights. There are no sensors or relays included. Wires are in good condition and all the plugs are usable. Some of the plugs will need cleaning but I think everything is there. I can ship, buyer pays shipping. I'm in Commerce Ga.
Take a look at my post in for sale, and see if the cable on that engine looks like yours.
I've got a 2.8L engine and 2 wheel drive trans from a 1986 MJ. They are still bolted together. They are setting on the ground but have been covered. I've never seen it run. The guy I got it from said the engine ran but had a blown head gasket. I want $150 for them. You will have to come pick them up. I have a way to load them. I'm outside Commerce Ga. 30530
I'm going to build it back to a 4.0, all I need are pistons. I have the rest of the parts.
What I didn't do was check the original 258 rod/piston assembly weight compared to the new rod/piston assembly weight. What I have found so far. The rod/piston assemblies are 124gr different from the original 258 rod/piston assemblies. The new rod/piston assemblies are lighter by 124gr. All new rod/piston assemblies are less than 1gr different in weight. This weight is including rod, piston, rings and bearings. The local speed/machine shop wants $375 + any heavy metal needed to check/balance the crankshaft.
The power steering pump and harmonic balancer are only things that were new when I put the engine in the truck. Everything else is from the engine I took out of the truck that I built the stroker from. No fan clutch or fan. I'm running three electric fans. The flex plate is from the truck. It's original as far as I know. I have two more in the shop I'm going to compare all of them today.
Well the balancer didn't help it. I guess I'll be pulling the engine, so I can remove the crankshaft. I've got to see if there's a shop local that can balance it.
Good article. I made a spacer for the extra length. My 6 x 18 Craftsman lathe comes in handy for things like this. My concern is the new balancer may be made wrong/unbalanced. I'm going to change it with a used one off a known good running engine.
I understand they are internally balanced. But if the new balancer is not right changing it should tell me. The torque converter bolted up with no issues. I was just wondering if the crank pilot bore may need a bushing for the AW4 torque converter. I don't think the AW4 was ever put behind the 4.2L.
It's the 4 weight crank. I have no pics of it. I'm going to change the balancer, if I can find the old one, to be able to rule that out. Can anyone answer this? Question for ya'll. I'm running a AW4 behind the 4.6, can anyone tell me what the pilot hole in the rear of the crankshaft is? I never checked to make sure the torque converter fit the crank.
Yes it makes it when parked and revving the engine. It's the non weighted crank. I've always just called it the light weight crank. I am positive the vibration get bad as the RPM goes up. Question for ya'll. I'm running a AW4 behind the 4.6, can anyone tell me what the pilot hole in the rear of the crankshaft is? I never checked to make sure the torque converter fit the crank.
The crankshaft was not spin balanced but all the other components were balanced. I checked every thing.
I've built a 4.6L short rod stroker. I used a 1988 Comanche block, the light crankshaft and rods from a 4.2L. SPEED PRO Hyper H802CP40 pistons. The camshaft is a Crane Cam H-260-2, .456 intake .484 exhaust. And a 7120 head. I put a new Dorman 594-018 Harmonic Balancer on it. It starts and runs great, but at about 2500 RPM there's a vibration and the higher the RPM the worse it gets. Idling it's as smooth as it should be. Everything I can think of is right. Anyone have any ideas what it could be?
