Big Dan
1 Follower
    Bloomfield, KY
2337 profile views
Big Dan's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. Mopar ones are still available, as well
  2. IIRC, seats through 94, from an XJ, will be an easy swap of brackets. 1995 plus are more involved, but doable.
  3. I've still got one as well.
  4. What else is out there besides General Spring and Hell Creek?
  5. Same. The clunking that I have is the tail gate. Worth looking into, OP.
  6. Thread revive here - I know the "throw away the Luk bearing" (or insert brand of composite bearing) is always said. I'll put one in for the camp of the provided bearing. I haven't had any issues with the Luk one. Currently going on 3 years. When I did my external slave swap, I actually bought a timken, and a national bearing, to compare to the provided one. National was gritty and off center. Luk and Timken looked fine. I ended up just trying the Luk. Point being - anecdotal, but, just check out what you have and make your decision from there.
  7. I'm behind in seeing this. Prayers for his family. This is terrible to hear.
  8. Awhile back I saw you comment about using a 2-3-10391x spicer slip yoke on a 2wd ax15 swap, well I tried that one and it seems like the output shaft seal is too large for the OD of the slip yoke, I’m going to replace the seal but didn’t know if there was one with a smaller ID you would recommend. Trans is from a 96 Dakota as well.
  9. GOODMARK GMK2111749681 will work for j-bolts. Available on rockauto.
  10. Anyone have any luck locating a source?
  11. I was not so lucky. I had a Bosch O2 sensor that lasted about 6 months. I was able to find a NOS Mopar sensor, ran that, and havent had issues. That's, obviously, only one case.
  12. 84-96 Sent from my Pixel 4 XL using Tapatalk
  13. It's not made. I bought xj hoses and cut them to length. It will work. Sent from my Pixel 4 XL using Tapatalk
  14. That's it. Glad it was found. He's a good guy, I've had no issues with transactions. Sent from my Pixel 4 XL using Tapatalk
