RustyRodder
    2
1891 profile views
RustyRodder's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. No idea! I took it apart in november, then moved, then just finished. I would guess something knocked it while moving
  2. Nope, the base. I investigated a bit more after work(did that on my lunch break. Pun no intended)- was a bolt! Anyone know a source of a new one?
  3. Hey all, I just finished reupholstering my comanches bench seat and found the backrests latch on one side broke. Is this bolt that i could extract and replace? Or a stud i could weld something onto? Or is the frame trash?
  4. best bet seems to be cutting the blockoff plates- Ive been looking at the same thing, only other options for rockers are the ones that replace the clock pod, or mount to the console.
  5. Thanks! I seem to be missing most of that- i wonder why it wasnt leaking before this?
  6. Hey all, I replaced my fuel pressure regulator and injectors recently. The FPR is leaking where the line comes in, pictured. I did rob the O-ring from the original, as there was not one in the replacement. Should there have been a second? Or where can i get replacement size specs if this ones flattened/worn down?
  7. Dumb question time with background- on mustang cobras, its a known issue that the fuel rail pressure sensor diagphram can blow out, allowing fuel into the oil. Is there a route that something similar could happen with the regulator on the 4.0s?
  8. Excited for these! Ive been delaying pulling my dash so I don't have to do it twice.
  9. are you talking JT Gladiator or J-Truck?
  10. I need bench, not buckets
  11. Thanks for the heads up- did not know that!! Also wish i had known what a pain it would be to track down parts when I swapped bench to buckets, and tossed things like seatbelts.
  12. Looking for some parts to swap my bucket seats to a bench. Still need a grey pair of seatbelt female ends, and a mini console in grey (Or any color- I'm talking to my cousin about 3D printing these). Thanks
  13. I dig this- especially because the same base can be kitted as a truck, wrangler-like open air suv thing, closed suv, and slantback.
  14. Is there a list of cars that these can be sourced from somewhere?
  15. I saw 15's planned for mid next year on the ko3 when they were announced
