jdog
    2
Everything posted by jdog
  1. jdog
    1J7FJ36L3LL163574
    Body: jl61 Build: 10/17/89 ( Happy Build day to you) Selling Dealer: SPRINGFIELD JEEP-EAGLE Springfield, MO *X1 DESCRIPTION NOT AVAILABLE -YY DESCRIPTION NOT AVAILABLE ARL BAYP 105 Amp Alternator BCYP 95 Amp Battery CBAP Straight Back Bench Seat CKAP Carpets - Floor and Cargo Area DGB All 4-Speed Automatic Transmissions DHTP Shift-on-the-Fly,P/Time T/Case EAAC All Engines EAFC all engines ERB 4.0L I6 MPI Engine GRCP Entire Fleet Key Alike (FREQ 7) GUBP Power Mirrors-Base HAA Air Conditioning JHA Var Intermittent Windshield Wipers JJAP Cigar Lighter KKGP DESCRIPTION NOT AVAILABLE K2XP STRIPE/BADGE/MOLDING/COLOR MBJP Black Bumper MDAP Front License Plate Bracket MFGP Body Color Headlamp Bezels MHAP Black Windshield Moldings MMKP Lower Grille Surround-Painted Silver PY3 Classic Yellow Clear Coat RAAC All Radio Equipped Vehicles RABP AM/FM Radio RCDP 4 Speakers SBAA Power Steering SCEP Steering Wheel SUA Tilt Steering Column TAAC All Tires TPFA P205/75R15 BSW All Season Tires WJDP 15X7.0 Styled Steel Wheels WLYC All Steel Wheels YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z66P Left Front Group XV Z85P Right Front Spring Group XIV APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes CSRS Passenger Assist Handles DGSS 4-Speed Automatic AW4 Transmission DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMDS 3.55 Rear Axle Ratio DRJS Dana 35 Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror JAZS DO NOT USE - See JP, KA classes JCAS 85 MPH Primary Speedometer K3TS STRIPE/BADGE/MOLDING/COLOR LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps MB1S Black Front Bumper MMCS MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF2S 18 Gallon Fuel Tank QY3S SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 152S Zone 52-Kansas City
  2. jdog
    1JTMW6451JT127668
    Body: ts61 Build: 1/29/88 First one I've seen this on, Kinda surprised there isn't more Selling Dealer: BUDGET RENT A CAR Santa Maria, CA *Q7 Cloth Low-Back Bucket Seats -SA Charcoal ADA Light Group AGD SXT Plus Group APA Monotone Paint CAC Low Back Bucket Seats CGW Next Generation Front Air Bags** CKA Carpets - Floor and Cargo Area CUF Full Length Floor Console DDJ DESCRIPTION NOT AVAILABLE ERB 4.0L I6 MPI Engine GAC Tinted Glass Windows GEC Front Left Side Sliding Window GFD Rear Sliding Window GTZ Manual Remote Mirrors JFH Tachometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K60 STRIPE/BADGE/MOLDING LAP Shift Indicator Warning Lamp LDA Underhood Lamp LMA Halogen Headlamps LNJ Front Fog Lamps LPE Cargo Lamp MBJ Black Powder Coated Front Bumper MCA Rear Body Color Applique MCB Bronze Fascia Applique MDA Front License Plate Bracket NAE California Emissions NHQ Transmission Heater NMB Standard Duty Engine Cooling PX6 DESCRIPTION NOT AVAILABLE QX6 DESCRIPTION NOT AVAILABLE RAF AM/FM Cassette Radio SBA Power Steering SCG Leather Wrapped Steering Wheel SUA Tilt Steering Column TBB Full Size Spare Tire WJH 15X7 Aluminum Wheels 3LY DESCRIPTION NOT AVAILABLE
  3. yep that's the accumulator for the crappy abs system
  4. jdog
    No axles
    I don't know if i would trust those, maybe these
  5. They're just jealous they don't have a comanche
  6. Try disconnecting the linkage at the t case and see if the linkage moves freely thru the gears, if so see if you can shift the t case manually.
  7. Cat or 02 sensor (especially if you haven't replaced it yet)
  8. jdog
    CC cookbook
    have jalapenos need recipe
  9. jdog
    1JTML6511HT155811
    welcome that's quite the bumper there body: jl62 Build: 5/4/87 Selling Dealer: LANDWEHR MOTOR COMPANY INC Enid, OK *X1 DESCRIPTION NOT AVAILABLE -YY DESCRIPTION NOT AVAILABLE APA Monotone Paint BCQ Maintenance Free Battery CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating DDQ 5-Speed Manual Transmission ERB 4.0L I6 MPI Engine GAC Tinted Glass Windows GPB Blind Spot,Pwr,Fold Pursuit Mrrs HAA Air Conditioning HCC Do Not Use - See HCA JHA Var Intermittent Windshield Wipers LAP Shift Indicator Warning Lamp LMA Halogen Headlamps MBJ Black Bumper MD8 Delete Front License Plate Bracket NAA Federal Emissions NFA 20 Gallon Fuel Tank PE4 Colorado Red QE4 Colorado Red RAC Open SBA Power Steering TBG Compact Spare Tire TBL Inside Mounted Spare Tire WJD 15X7.0 Styled Steel Wheels
  10. bump
  11. Mileage and smoke from tailpipe, they are known for dropping valve seats iirc. Other then that my sis has one she's driving the wheels off atm
  12. Front Axle vent
  13. Yes, but iirc you have to route the belt differently or find the delete pulley
  14. You could always move the heater switch to the radio slot and put the double din below. I have not heard of people using just the dash, it's usually a full swap but I bet it could be done. But it will probably take some custom gauges.
  15. You can but you'll need to pull the inside harness as well as all electronics
  16. At least pull the motor for a back up or a builder
  17. Your cutting the bed?
  18. jdog
    ouch...
    @Pete M Any update?
  19. Which style of cluster? I might have a parts one laying around
  20. Because there different then what most people drive now a days
