2
Everything posted by jdog
AX15 Swap and Identification
jdog replied to VagaBond Comanches's topic in MJ Tech: Modification and Repairs
That sucks, but that's why you ask for photos -
I don't know about that, they had some decent vehicles once Mitsubishi got involved, but then again that's a whole norther era of Chrysler
1986 Comanche No Start Condition
jdog replied to wclegere's topic in MJ Tech: Modification and Repairs
https://comancheclub.com/topic/48710-diy-projects-writeups-master-search-index/ -
Can't tell you to just replace with out testing it first -
87 SporTruck, Dodge City, KS- $5,999
jdog replied to NHMJXJ's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Looks like the same dealer too -
A picture would help clear up the confusion, I'm thinking it's the idle solinoid that is unplugged -
Another random electrical problem
jdog replied to rsmecham's topic in MJ Tech: Modification and Repairs
That connector is stock, but it is for the tag lights and does not connect to gather, no a bad nss will not cause a short in the park lamps. But make sure that connector you are holding isn't plugged into each other -
Glad to hear you got it fixed
Ah then yeah it's time to break out the ohm meter and check those wires
If you can set up a new ground from the wiper motor
APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CDBS Reclining Front Seats CKBS Floor Carpet CKVS Cargo Area Storage CLES Front Rear Floor Mats CSAS Spare Tire Cover CSCS Cargo Compartment Cover CSRS Passenger Assist Handles CUFS Full Length Floor Console DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DHSS Floor Mount Automatic Shift Lever DJHS Dana M30/181MM Front Axle DMDS 3.55 Rear Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GECS Front Left Side Sliding Window GEDS Tinted Rr Drs/Qtr/Liftgate Glass GFAS Rear Window Defroster GNAS Rear View Day/Night Mirror GNBS Driver Side Illuminated Sun Visor GTBS Power Heated Mirrors HGAS Hood Insulation JAAS Instrument Panel JAYS DO NOT USE - See JP, KA classes JBES Instr. Panel Diamond Weave Bezel JCAS 85 MPH Primary Speedometer JGBS Digital Clock JHAS Var Intermittent Windshield Wipers JHBS Rear Window Wiper/Washer JJAS Cigar Lighter JKBS MOPAR Hood Lock KKES DESCRIPTION NOT AVAILABLE K3SS DESERT SAND P/C - FENDER FLARES LAFS Seat Belt Alert-Driver Seat only LAJS Headlamps On Warning Chimes LBBS Courtesy Lamps LBCS Glove Box Lamp LBDS Ash Tray Lamp LBES IP LED Ambient Light Pipe LCDS Map/Dome Reading Lamps LDBS Cargo Compartment Lamp LDHS U/Hood, Removable/Rechargeable Lamp LHDS Headlamp Off Time Delay LMAS Halogen Headlamps MB3S Bright/Body Color Front Bumper MB7S Bright/Gray Mist Rear Bumper MCAS Front Bumper Guards MCBS Bronze Fascia Applique MFMS Grille-Black/Bright MHBS 35 Tire Body Color Fender Flares MMCS Rear Qtr Solid Window Insert MMGS Belt Moldings MMJS Molded-In-Color Fender Flares MMPS Bright Day Light Opening Moldings MTAS Rear Fascia Skid Plate Applique MWAS Roof Rack NAAS Federal Emissions NBAS Underground Calibration NBKS EVAP Control System NDAS Catalytic Converter NFAS 20 Gallon Fuel Tank QS3S Sapphire Silver Blue Met Clear Coat SBAS Power Steering SCGS Leather Wrapped Steering Wheel SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBCS Compact Spare Tire TBLS Inside Mounted Spare Tire WJMS 15X7.0 Chrome Wheels XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z5BS GVW Rating - 4900# 1AES BUX Contract Assembly 155S Zone 55-Milwaukee 4FMS Fleet Option Editor
Cruiser54.com has spots for the blower motor and dash ground, not sure about the wiper ground
Don't you mean I6? Or did they swap a v6 in
1988 MJ wingvent & sideview configurations
jdog replied to EUREKA's topic in MJ Tech: Modification and Repairs
Yep -
Vent windows were optional, as were the mirrors you can swap both out with any from 87-96 -
Ax15 swap troubles and questions
jdog replied to Jesse J's topic in MJ Tech: Modification and Repairs
It might be easier with the flywheel off, that way your not fighting two holes -
The knob connects to a switch with a connector on it, it is behind the dash and hard to see -
Check the headlight switch, and add eaglescout526 stated that fuse controls the park lights and the dash lights -
I believe you are correct, all depends on what size his trans input shaft is -
https://www.amazon.com/Timken-PB77HD-Clutch-Pilot-Bearing/dp/B000BZ6YFY this is what most folks have luck using, and can be had at the auto parts stores
