jdog
    2
Everything posted by jdog
  1. I don't think he's used to having it home
  2. jdog
    1JTHW6613GT055988
    pete wants the bed, @CoastChief might want the bug gaurd
  3. Bearing is pilot bushing/bearing iirc
  4. Picture of big chunk What are the measurements of the hole and the bushing
  5. Yes The zj steering components will also fit are a bit beefier
  6. jdog
    1JTHW6613GT055988
    With a 2.5 hey @eaglescout526 you need any parts
  7. How much fuel did you have? Stupid question I know, but I'm wondering if your not running out of fuel. Also how's the ground at the dip stick tube, you could be moving the tube just enough to complete the ground. The only other thing I have is check the air filter and see if it's coated in oil
  8. Side projects are great, they break up the monotony
  9. His only post are to post this
  10. Check for power on both sides of the turn fuse with the fuse in, if power there, is there power at the turn signal flasher
  11. Sounds like either a bad ground, bad turn signal switch or bad sockets
  12. Was just gonna post they are patriot compass steel wheels
  13. Also year would be helpful
  14. What don't they do?
  15. Just making sure, glad you got it going
  16. What flywheel did you install?
  17. soooooo whens this coming home?
  18. Cam position sensor I haven't got a clue if any of them are good
  19. I mean how its way past full, that usually means the sender side is grounded out IIRC, which is why I was wondering how you plugged it in.
  20. jdog
    1J7FJ26S8NL136861
    build:September 23, 1991 Body: JL62 Selling Dealer: PETERSON AUTOPLEX Boise, ID *C1 DESCRIPTION NOT AVAILABLE -SA Charcoal ALAP SE Decor Group CBAP Straight Back Bench Seat CKAP Carpets - Floor and Cargo Area DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission ERH 4.0L I6 Power Tech Engine GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZP Manual Remote Mirrors JHAP Var Intermittent Windshield Wipers JJAP Cigar Lighter KERP DESCRIPTION NOT AVAILABLE MBJP Black Powder Coated Front Bumper MDAP Front License Plate Bracket MHAP Black Windshield Moldings MMKP Lower Grille Surround-Painted Silver PS7 Dark Silver Metallic RAAC All Radio Equipped Vehicles RAFP AM/FM Cassette Radio RCDP 4 Speakers SCGP Leather Wrapped Steering Wheel SUA Tilt Steering Column TBB Full Size Spare Tire TRN P225/75R15 OWL Wrangler AT Tires TZAP Goodyear Brand Tires WJHP 15X7 Aluminum Wheels WLZC All Aluminum Wheels YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z65P Left Front Group XIV Z84P Right Front Spring Group XIII 2TCA Customer Preferred Package 2TC 25C Customer Preferred Package 25C 3VNA Customer Preferred Discount 4BJA Wheel Credit 4HA Special Scheduling Condition I 4M1P Retail to Bid Diversion Tracking 4UAA SCA Tissue North America LLC APAS Monotone Paint BAPS 75 Amp Alternator BCCS Maint. Free Batteries BGAS Power Front Disc/Rear Drum Brakes CUMS Mini Floor Console DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMMS 3.07 Rear Axle Ratio DRJS Dana M235 Wide Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass HCDS Do Not Use - See HCA JAZS DO NOT USE - See JP, KA classes JCAS 85 MPH Primary Speedometer KWRS STRIPE/BADGE/MOLDING/COLOR K3ZS STRIPE/BADGE/MOLDING/COLOR LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MMCS Rear Door Solid Window Insert MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF5S 23 Gallon Fuel Tank QS7S Dark Silver Metallic Clear Coat SBAS Power Steering SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBMS Tire Carrier Winch XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 172S Zone 72-Portland
  21. The fuel gauge on both look funky, on the 3/4 it looks like it didn't get plugged in straight, they are a bit finicky to get it plugged in straight.
  22. Never assume, it'll bite you in the end
