jdog
    2
Everything posted by jdog
  1. jdog
    1JFT26E6KL494279
    Pete and eaglescout526 have been working on a list
  2. I believe the screws are under the black cover, right at the door
  3. jdog
    1JFT26E6KL494279
    The 4 digit codes? If so those are Chrysler codes and will only mean something in chrysler computers
  4. jdog
    1JFT26E6KL494279
    vin: 1J7FT26E6KL494279 build: 12/9/88 body: tl61 selling dealer: CONRAD JEEP-EAGLE Lexington, Ky *X2 DESCRIPTION NOT AVAILABLE -YY DESCRIPTION NOT AVAILABLE CBAP Straight Back Bench Seat DBBC All Manual Transmissions DCK DESCRIPTION NOT AVAILABLE EAAC All Engines EAFC I4 MPI Engine EPD DESCRIPTION NOT AVAILABLE GRVP Left Manual Mirror MBJ Black Bumper PY7 DESCRIPTION NOT AVAILABLE RAAC All Radio Equipped Vehicles RCAP Audio SBA Power Steering TAAC All Tires TPF P205/75R15 BSW All Season Tires YGBA 1 Additional Gallons of Gas YGGA 9 Additional Gallons of Gas Z01P Rear Spring Group I Z56P Left Front Spring Group Vi Z75P Right Front Spring Group V 5ALA DT-Vehicle Family APAS Monotone Paint BAQS 115 Amp Alternator BCXS Dual 700 Amp Maint. Free Batteries BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CKJS Black Vinyl Floor Covering CSRS Passenger Assist Handles CUMS Mini Floor Console DMDS 3.55 Rear Axle Ratio DRJS Dana 35 Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror GUAS Open HCDS Do Not Use - See HCA JAAS Instrument Panel JAZS DO NOT USE - See JP, KA classes JBFS Instrument Panel Black Bezel JCAS 85 MPH Primary Speedometer JKBS KDCS DESCRIPTION NOT AVAILABLE K3ZS STRIPE/BADGE/MOLDING/COLOR LAFS Seat Belt Alert-Driver Seat only LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS Fender Flares MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMJS Molded-In-Color Fender Flares NAAS Federal Emissions NBAS Underground Calibration NBKS EVAP Control System NDAS Catalytic Converter NF2S 18 Gallon Fuel Tank QY7S DESCRIPTION NOT AVAILABLE RACS Open SCBS Steering Whl SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels WMCS Open XBSS Pickup Box XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating 1AAS U.S. Dealer Retail 141S Zone 41-Cincinatti
  5. jdog
    CC cookbook
    been down with rona, need some dish to help get straighten back, i've got chicken, any suggestions
  6. Here's to a speedy recovery
  7. Looks like the Chrysler diagnostic connector
  8. jdog
    Minitrucks
    Safe travels
  9. jdog
    Push start
    https://comancheclub.com/topic/53244-evolution-88/page/11/?tab=comments#comment-678638
  10. jdog
    Push start
    That's jeep drivers Comanche iirc
  11. jdog
    CC cookbook
    Been a while since if had that, I think I have almost everything for it as well. Thanks for the cold evening dinner
  12. jdog
    Recommend Me A Car
    Grand Marque, or a crown vic would be my suggestion, and that's just cause you seem like the person that would drive them. They would be right around the time frame your looking for, but I don't know fuel mileage on them. With that said I Daily a legacy but my drive is a lot shorter then yours but have close to 200k and has been a reliable driver. The Volvo is a decent car, we had them at work around that time, don't remember any issues with em. They are generally good cars that hold their own and would be a good choice.
  13. Does the mechanic have a scan tool to see live data?
  14. Post a picture of them and we can explain if they are good or bad
  15. How are the plugs? Vacuum lines?
  16. Check the bolts to the manifold
  17. Check for voltage at the fuel pump, also check that the hose didn't come off the fuel pump
  18. You're not the only one, just had the sullivan show on last night and he showed up
  19. https://youtu.be/eAjTxQ9hkTY
  20. Can you post a picture of the smog report?
  21. I didn’t think the ho had a egr any ho guys wanna correct me?
  22. Location? 4 or 6 cyl Nox? 2 more posts and the classifieds will open up for you. You can always put your Vin in the registry
  23. While your there check for power on the red wire
  24. So you replaced the ignition switch and the starter relay? Did you adjust the ignition switch? Do you have power on the red wire
