mikekaz1
Everything posted by mikekaz1
  1. picked up some custom stickers from Spencer over at jeepsticker.com
  2. just tried browsing, theyare still there, just have no attached price. id definitely call.
  3. Checked them out but they discontinued the MJ metric ton leafs. Know anywhere else to get them? I'm salvaging a bastard pack but if I can find a metric ton set I want to go with those. really? what a shame! I absolutely love mine. guess I got mine just in time. have you tried calling not just web browsing?
  4. Checked them out but they discontinued the MJ metric ton leafs. Know anywhere else to get them? I'm salvaging a bastard pack but if I can find a metric ton set I want to go with those. really?! have you tried calling? not just web browsing?
  5. if you feel like new, I absolutely love my hellcreek metric ton springs. they also carry standard weight lift springs also
  6. my old s10 if left in 1st/r would lock in place like nobodys business. could leave it for days on a steep incline and never worry.
  7. they've used in tank pumps for decades on millions if not billions of cars. if it was a bad design they wouldn't do it. external fuel pumps, even well done always seem like a hack to me.
  8. ha, I don't think ive ever had a working e brake in any vehicle ive ever owned. manual and automatic. just leave it in gear, she aint going anywhere.
  9. possible new are still available for a 2door XJ, which essentially is the same as MJ
  10. if I'm not mistaken, 4 door xjs had their seat belt retractors mounted right at the base of the B pillar. 2door Xjs and Mjs both had them mounted mid height as to not interfere with back seat/ behind seat entry. this would make 4 door seat belts ~1ft too long
  11. Actually he is right at a 29" tire (28.9") now. right! its the 225 that's the 27/28.
  12. the bigger you go the worse your gas mileage gets. that being said, many people can go up to a 31 inch tire without too much issue if at all. you have somewhere around 27/28 inch now
  13. dumb question..... if it was "so easy" to pull out 173/313 from your 96tdi.... why wouldn't you do that on your pickup? even if 130/230 is enough, why not give it the extra 40/100 and make it awesome?
  14. all the old trucks used coffee cans fwiw
  15. and they are at fault if anything screws up!
  16. hmm, sorry but this doesn't sound correct.... MJs most certainly can use a 4 pin standard harness. and a 5 pin is historically used for reverse trigger.
  17. crank doors will bolt right on with only modifications to the striker pin. dash will not, like frank said, without long, detailed, indepth modification
  18. id definitely dolly or full trailer it. no clue the condition of the truck to be picked up but flat tow and dolly still require sufficient maintenance of the tires and axles and whatnot. if its been sitting a long time theres a good chance those won't be too fantastic
  19. all canisters operate the same. try the junk yard first, good chance you can get a mint one for $5 or less. I believe all renix era 1986-90 had dual fitting canisters. but even if you can only find a single canister. you can buy the hose and T splice for probably $3 at napa
  20. I used to have an actual p71, they are very firm. but handle fantastic for a full size car. I could corner with the best of the tuners. even at 4000lbs
  21. I don't see how you would be able to install without loosing this charge. I believe its more for internal protection while in transit and storage.
  22. plug the vacuum line. replace hoses to two straight hoses or put hose menders in. done
  23. are those "backing plates" the inner rockers? that's what it looks like to me atleast.... didn't know those were available
