Dogote,
I have the same setup, currently searching to see if anyone has bypassed this already, mine is still stock with the valve, pic on the left , the yellow star with blue outline goes to the water pump, then another line from the water pump runs in front of the engine to the intake manifold, off the rear of the intake manifold the line goes behind the engine and is pictured as the red star with yellow outline. If your running without the heater valve let me know, mine has a small leak in it and I was thinking about ditching it. pic on the right shows routing of lines, yellow line from the water pump to intake manifold, then red line behind engine to HVC, and front red line tube running from water housing back to HVC pump as blue star with yellow inside.
