Everything posted by mikekaz1
1991 short bed metric ton DD build
mikekaz1 replied to mikekaz1's topic in Member Projects: Your Comanches
no hands were too dirty. but instal was very straight forward. Flat stock welded directly to the inner floor/ flat part of the inner rocker I left it about 1/4" above the factory rocker pinch weld, pretty much pressed right against the lower seat belt bolts and then leveled across.. Then the rear frame cap. Then wleded the front frame cap onto the outter rocker. And tacked it in. Made sure everything looked good and burnt it in. I cut about flush with the lower door edge and straight acrossthe cab corner. Seam sealed everything, a little skim coat of bondo, and then some bedliner and all done. -
went over and saw Joe at http://spadanoenterprises.com/index.html and checked out some of his awesome military trucks and projects. While there I picked up a set of his bare ROCKersliders as my factory rockers were toast. Nothing but quality. Cuts and bends were perfect and I was able to adapt them with little issue. Got them welded up and painted and I think the final product turned out great! -
Does anyone have a diagram, pictures or just half a clue on how the 1/4" gas vent tubes get routed? Mine are all dry rotted, broken and hanging and id like to replace them.
Catalytic Converter Heat Shield
mikekaz1 replied to Rymanrph's topic in MJ Tech: Modification and Repairs
does NC require emissions still? why not just delete the cat. -
Bunch of Comanche Questions
mikekaz1 replied to TheDirtyJeep401's topic in MJ Tech: Modification and Repairs
I have the older q9000 winch, I like it, no complaints. -
http://www.tirerack.com/tires/tires.jsp?tireMake=Firestone&tireModel=Winterforce+UV&sidewall=Blackwall&partnum=27SR6FWFUV&tab=Sizes I ran these on my old XJ, my current WJ and the LT version on my work van. I absoluetey love them. quiet and fantastic traction. I average 30-40k on a lifespan. and at only $85 a tire you can't beat the price!
when I redid my floor I omitted that upper brace, 2 years strong with hauling multiple heavy loads and not one ounce of issue here. if you want to replace it though, the flanges are roughly 6" apart, id get a piece of 1/8" by 6" and weld it in flush.
I dunno... :dunno: seems I'm the minority here. I prefer standard sealed beams. I love my silverstars and relay harness. being in the north east, ive experienced way too many snowstorms where they ice up to ever want to experience it with something that produces effectively zero heat.
full dash is just an oil pressure switch that's it. -
Krustyballer Fabrications
mikekaz1 replied to shelbyluvv's topic in Vendors- members making products for MJs
I think that would be fine. simple, effective, easily matched to whatever front flare you want to run.- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
I have a factory electric fan and a aftermarket 10" instead of the clutch fan. I run consistently cooler all year with the full electric setup. Only issue I still have is with the plow in the fully raised position, temps still creep up to ~240. Unless I keep it slightly lowered.
Assistance needs in the glove box department
mikekaz1 replied to jdritchey98's topic in MJ Tech: Modification and Repairs
I just went out and looked at mine... its dark out but it appears that that whole assembly/door is plastic welded together. With a dual pin style catch on the dash itself. Id say just try yanking on it. Worst case it breaks and its just a couple 10mm bolts to pull it off and get a junkyard replacement -
Hmm what did you have in mind? I was imagining a ~3" flat/tube fender set up or something.- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
I like to feel like in driving a midsize dump truck
theres still no "gap". theres just no body panel/flare behind the end caps and the wheel well gains clearance. I can take a photo when I get home if wanted.
why wouldn't the bumper fit?
I'm not sure what you mean. Picture maybe? like take a pipe/tube with a similar radial profile and quarter it to use as the connecting radius between the side and rear of bed.- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
I know its added work but what about doing a pipe slice to form the corner radius? shouldn't be too hard to slice and angle the two together to form the lower body angle- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
I like what you did with the sides, but id have to call a pass on the rear cap. I gotta agree with 500mj, far too large of a space to harbor faults.- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
yeah that's pretty easy to debunk, all shocks (atleast all decent ones) should come engraved with p/n origin ect...
November 2016 ● joester1908's '90
mikekaz1 replied to neohic's topic in Comanche of the Month (MJOTM)
Very nice! not too many of us still running a wagoneer nose! -
2wd to 4wd conversion
mikekaz1 replied to That_Creepy_Guy_In_The_MJ's topic in MJ Tech: Modification and Repairs
Do yourself a favor and skip the factory linkage and get a bostwerks or similar stand alone linkage. -
Are you doing custom flares? Or open for plastics?- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
I used the same thing don used. I think mine were #12 and for reassurance I coated them with some RTV also
