mikekaz1
Everything posted by mikekaz1
  1. can that open up rear or front facing?
  2. might be possible to contact z&m and see if they can send you a CAD drawing of their bed sides.
  3. ive had good luck with napa sensors personally
  4. just a question, why the "obsession" with a chryco factory vs generic?
  5. doesn't look half bad to me I would rock them if I was looking for a highway tire with a mild look to them
  6. I feel that lower piece is damned if you do, damned if you don't. would it be sweet? absolutely. would people buy it, yes. but as that gray one shows also, most "hardcore" guys trim off that lower body line anyways, at least mainly behind the wheels which I assume and from what you say is the hardest area to create
  7. My 1991 still had the old style calipers. But the switch was mid year 1991 if I'm not mistaken.
  8. I always assumed its for the diesel as the nozzles are larger.
  9. rear cab looks like the worst of the damage, the tow bar definitely saved the nose from worse, the hood is still straight, so theres no lasting frame damage. will it be totaled... yes... is it fixable... yes.
  10. I ran 235/75r15 on stock steelies for years, not a single issue in any aspect.
  11. fwiw, gas doesn't expand that much... you would have to be REALLY topped off for it to expand out on even the most extreme days. .069% per degree if you want to get technical.
  12. those i5s were actually pretty decent.
  13. id offer $5k and haggle till $6k.
  14. 4.7 weren't that reliable.... I get wanting to be different, but you really can't beat the availability and reliability of a chevy engine.
  15. Spencer is great to do business with. I would message him vs straight ordering as he can often do alot more then he lists on the site
  16. Id keep it, even if you just leave it open and not powered
  17. If youre not using a TCU and will be having a baja "manual" shifter. I don't believe the TV cable would be necessary. But thats a pure assumption
  18. ive found the replacement of the inner brace not 100% necessary for reassembly, but if wanted the frame rails are ~6" wide, flange to flange, you could get some 1/8"x6" flat stock and weld it flush against the floor pan/ frame flange. I see this as easier and stronger then the awkwardly raised 18ga floor brace originally there. other then that, its pretty straight forward, cut bad out, weld new in, try not to overlap too much, and use some seam sealant after over all the welds helps keep further rust away too.
  19. https://www.amazon.com/1984-96-Cherokee-Wagoneer-Comanche-Front/dp/B004GAX2G4/ref=sr_1_1?ie=UTF8&qid=1477081036&sr=8-1&keywords=comanche+floor+pan
  20. I got mine through keystone, but amazon has a bunch for ~$45
