mikekaz1
Everything posted by mikekaz1
  1. The Renix and HO pulley mounting plates are not even close. Look it up. For the 4.0: 87-90, 53002904, BRACKET, Idler Pulley Mounting - w/o Air Conditioning 91-93, 53006551, BRACKET, Idler Pulley Mounting - w/o Air Conditioning when I swapped engines from my factory 91 block I was able to swap it onto my replacement 88 block...
  2. I'm sincerely jealous of having 240 acres at your disposal.
  3. one of my MJs had vinyl ones, also had the extended length that went above the mirror too.
  4. 91 delete mount will fit on a 88 block.
  5. my opinion, just buy the floor panel, they are like $30 a side, and if you don't need it all, you can just cut out the sections you need. and theyre already in the basic shape you need. $30 for half the work, or $15 for double the work?
  6. I'm good friends with the guys over at the Canton MA crown. great group of people and always good on parts.
  7. ive never had an issue with crown. fwiw
  8. its my understanding that all eliminators were 6ft beds and all pioneers were 7ft beds. Thats not true, Pioneers came in short and long beds. I have a short bed pioneer. ah, ive only ever noticed long bed pioneers. in any event, eliminators were definitely short bed only.
  9. its my understanding that all eliminators were 6ft beds and all pioneers were 7ft beds.
  10. There is two sets of bolts/studs on either side. One that hinges the back of the bench and one that locks it in place. Does anyone know if there are replacements of these? And/or does anybody know the thread size/pitch of these?
  11. Nice!...what wheels and tires are u running if u don't mind me asking? BFG KO2 33×10.5r15 tires on TUFF A/T wheels. Model T01 I believe.
  12. Gamblers. Everything Adam has is clean. He pisses me off. :) ah darnit. Thats right.
  13. Wow those are a clean set of ramblers!
  14. ugly, but not bad. pretty typical really.
  15. older picture, but still lookin good.
  16. 3" with flares and 33s
  17. They arent beers.... they are road sodas.
  18. MJ floors are angled back much steeper then the near dead flat XJ floor. It might work but still not just a drop in. Also XJ seat brackets are 100% different then MJs
  19. the replacement pans are only about 75% effective. they still take some work to make perfect and they are just the flat sheet metal. no inclusions or provisions for bracing, seats or anything
  20. I'm not big on the lightbar scene but I have two of the nilights pods on my back rack and they are ridiculously bright. I like them a lot and tey were only like $20 for the set
  21. If I'm not mistaken the dash harness is also necessary if you plan a full HO swap.
  22. 3" would probably be the smallest lift you could do. And even then would probably rub slightly at full lock.
  23. Factory there is about a 2" rake to the truck. And 33" tires will fit on the rear with no lift. Id try focusing on the front first and tweak the rear if necessaey after.
  24. Its pretty easy to remove the entire rear harness. I found this easier then trying to splice installed under the bed. Also lets you better inspect all the wiring for cuts and faults.
