3
Thats one of the first things I did when I got mine. I set it up in the woods in the backyard two years agoi. And last fall, a neighbor comes by and asks if he can buy it if it would fit his F150 Lightning stepside. I told him that if it fits and he can use it, he can have it! It was gone three days later, and I saw it on his truck as we left out to head north for christmas. I guess he just wanted it for when he takes long trips south, to keep everything protected. Whatever works!
possible purchase of a 92
dasbulliwagen replied to blusteve's topic in MJ Tech: Modification and Repairs
still worth $700!!! Those items are minor, and the hinge is a common repair. As long as it runs, its worth it! -
All that matters is if you like it. Just remember that! I personally, now that I see what youre doing....hate it. Sorry. I applaud you for trying it though!
Has anyone done this swap ? WJ Knuckles ....
dasbulliwagen replied to DJM/78's topic in MJ Tech: Modification and Repairs
I'm curious about this too, as I have a bad WJ dana 30 sitting under my bench at work. It still has all the steering stuff on it, but not the brakes. I thought it would be a good swap for if I ever put a lif on it. This would raise the drag link up where it is supposed to be for correct steering angles ( I think ), and the brakes would be a nice upgrade, though I'm not sure it could still use 15" wheels. Time will tell! -
In England, Japan, or Australia do they have left hand drive Jeeps as mail cars? Just wondering.
When I added dual horns to mine from a wagoneer, There was 2 wires to the horn that were both together to the horn terminal. I didnt think much of it till I noticed a same color wire not attached to anything on the other side of the front end. It was the other wire from my original horn. I noticed this after making a wire and mount for the second horn both on the driver side!.... so it was already wired for two horns.
questions about engines
dasbulliwagen replied to charte07's topic in MJ Tech: Modification and Repairs
Its best to use your original, that way you know it will work with your trans.... It won't cost much of anything to have a machine shop neutral balance yours, and surface it at the same time! -
Removing factory Pin-striping/trim stickers
dasbulliwagen replied to Darren's topic in MJ Tech: DIY Projects and Write-Ups
Where it says don't exceed 4000 rpm... they mean it! I had never used one before and this other guy at work mounted one in a die grinder.... you know, the 10000 rpm ones! He showed it to me and I hooked it up and grabbed the trigger.... it spun up and disintegrated into a thousand peices including some larger chunks that really could have hurt someone if they had hit them... those peices flew across the shop, bounced off the walls, and I slunk into a nice hiding spot for awhile! I have one of my own now and am in the process of doing this same thing on my sportruck stickers and wagonner donor woodgrain! Ill have pics when its all finished! NICE JOB TOO! -
I thought the same exact thing when I saw that pile.... see if the manche will make it!!!! And send pics!!!
You don't know bad till youve gone on I 94 in metro Detroit! If youre not doing 80 plus, youre getting passed! Gotta love it!
What the aych ee double hockeysticks is 1952 Packard? :hmm: :waving: And don't do digital cammo, just looks like a crappy custom paintjob, do it like traditional cammo.
so if i were a new stereo head unit...
dasbulliwagen replied to mrsinister's topic in MJ Tech: Modification and Repairs
I for one can say that the 87 harness is the same as 86, as Ive recently swapped in a 86 unit into my 87 and it plugged right up. -
Ive seen POR 15 at a few parts stores on the shelf, I think NAPA was one, call around and see if anybody has any, you can get it in pints and quarts too, or Eastwood sells it in their catalogs.... they have restoration tools and products... lots of good stuff, look them up. I think if I was planning on keeping it for a while, Id spend the extra and gfet the POR15.
What Color Primer for Red Paint?
dasbulliwagen replied to runner6's topic in MJ Tech: Modification and Repairs
red will allow you to cover in fewer coats, and if theres show through the red will be less noticeable.... I assume youre talking about laquer primer, but if youre using urethane primer, have it tinted as close as possible to your final color. -
Ive ALWAYS loved that body style... and theyre making a comeback too, getting more and more valuable! AND... she is the original Eleanor... from the original 1973 "Gone in 60 seconds" That last chase scene is unbeleivable! They wrapped that car around a pole, and the stunt guy boke his leg when that happened, so they stopped production of the movie, 3 months later when he was better, they got right back in that car, fired it up, and finished the movie! Love it man....keep up the good work!
Turn signals don't work but flashers do
dasbulliwagen replied to terrawombat's topic in MJ Tech: Modification and Repairs
:agree: Had the same problem recently on my boss's comanche, the 4 way flasher and TS flasher are seperate, swap them and see if it make the TS work if so, youre all set... get a new flasher, I think theyre 2 prong. You may still have socket problems, but this way at least youll know if you can get the TS to work. -
motomotard's 92' manche 4x4 build
dasbulliwagen replied to motomotard's topic in Member Projects: Your Comanches
The PS mount is different because the intake manifolds are different between the renix you got the pump from and the HO youre putting it on. If youre going to swap parts, they should come from same era as the original. -
Backroads MJ 86 4x4 longbed 4 banger
dasbulliwagen replied to Backroads's topic in Member Projects: Your Comanches
Your axles are 4:10 geared already so make sure if youre gonna replace to get 4:10 or better. The front axle disco isnt really a big deal, juts lock it over in place and forget about it, not like youre gonna break it with that 4 cylinder. Good find though and welcome to the club! -
valve tap? burnt valve? something making noise
dasbulliwagen replied to 702_MJ's topic in MJ Tech: Modification and Repairs
if it sounds like an exhaust leak, maybe its an exhaust leak. These engines are well know for busting the rearmost and frontmost intake exhaust manifold studs, could just be leaking at the exhaust manifold gasket. Take a look and see if the studs are still in place and take a section of heater hose and see if you can narrow down where the noise is coming from. The simplest explanation is usually the correct one. Good luck! -
Isnt JBHills slammed bagged MJ a RHD?
Yes thats true, you have to special order them but they are available new to anyone who wants one, we service several of them at my dealer, mostly TJ's and JK's, but I have seen one XJ with the steering like in the original post, kinda funky!
Driveway Tranny Drop...any tips?
dasbulliwagen replied to ParadiseMJ's topic in MJ Tech: Modification and Repairs
Isnt there a couple of torx bolts at the top of the bellhousing? Someone else should be able to chime in and tell you what size. Drain pan for when you pull out the driveshaft and oil runs out the back of the transfer case and the oil cooler lines. Shop rags and hand cleaner so you can wash your hands and clean up spills. Ace bandage for when you drop the assy on your arm as youre laying under the truck. A bottle of saline solution to rinse the dirt out of your eyes that falls in while laying under it. A roll of electrical tape so you can make nice shop style manyly black bandaids for when you smash your fingernail when your wrench lets loose of its bolt. An extra shirt for when you dump tranny fluid on yourself trying to wrestle it to the ground. Cardboard to lay on. Am I missing anyhting? -
Yes 3M, don't use the adhesive glue meant for emblems, at least not on your own vehicle. The 3M emblem adhesive I used to use when doing body work was good stuff, but don't screw it up as it will eat into your paint job... part of what made it hold so well I guess! At least with the tape, if you screw it up, you can pull it off, and re do it if needed.
