3
MMMMMMMMMMMMMMMM!!!!!! Turkey!!! :drool:
I don't get it.... whats so funny? :hmm:
The axles will bolt right in, but be sure to keep all the original brake stuff from whatever axle you swap in. I think your gearing will be 3:55, not sure if thats any better than what you have now or not. The front axle will be vacuum disconnect too, so you may want to just lock it over in place and then not worry about it anymore. The yokes should be the same, but if not you shouldnt have any problem swapping them over from the original axle.
Only leather got the heated seats.... and the heated seats have been subject to 2 recalls, the second one is a recall of a recall! I can have both front seats out, apart, and the elements replaced and back into the Jeep in 45 Minutes! The elements break in spots and start burning into the seat foam.... if some customers saw exactly what was happening with these elements they would freak out, but Ive never seen one catch fire from it, so thats good I guess. They are pretty decent trucks except for the fact that they are not XJ's. They just seem heavy by comparison. The 4.7 is a decent motor and I wouldnt turn down getting one because it has it. Good luck with your search!
Cam and crank sensors could be the culprit, or if it isnt getting fuel are the most likely problems. Ive never done a fuel pump in one so I really don't think that would be your problem. Ive done several of the sensors though. The cam sensor is on the right side cylinder head toward the front bottom. The crank sensor is down on the side of the block, I'm thinking near the starter. If its a bad cam sensor unplug it then try to start it, and youll know its that sensor, but that won't help you with the crank sensor... we usually replace them together weather it needs both or not. There should be a schrader valve on the fuel rail, take the cap off and push the center in, if you get a little squirt of fuel, you likely have fuel pressure. Its a decent engine, but nowhere near the reliability of the 4.0. And they sound great with flowmasters on them! Good luck and keep us updated!
Preferred Oil for our "older" engines???
dasbulliwagen replied to ComancheKid45's topic in MJ Tech: Modification and Repairs
:agree: -
Grrrr 2.8L gave up the ghost
dasbulliwagen replied to TheYeti1775's topic in MJ Tech: Modification and Repairs
Search for a good used 3.1/3.4 engine instead of buying a rebuilt... that should save you a ton right there! :thumbsup: -
I researched all the oil threads last night and went to wally world... found the only one really listed as SL was Mobil 1 High milage... I bought a bottle of 10/40 and plan on changing the oil today. It also has the ACEA A3 rating which was supposed to be the best for us as well. Though I wasnt planning on switching the 'ol girl over to synth though.... Ill just have to see what happens if the leaks get any worse or not. Changed it last time with Castrol GTX high milage dino which hasnt given me any problems. Good info here! -
Installing the 3.4 would not be trying to get one over on her, it is simply the updated version of that particular engine that did away with the problems inherent to the 2.8. Simple as that! Now saying that you NEEDED a 350 in there would be trying to get one over on her. Saying that you can't install a 350 without adding a 4.5" lift kit would be getting one over on her! Saying that the new lift kit will need 33x12.50x15 tires to make everything correctly proportioned would be getting one over on her! Just tell her all this, and the 3.4 will be let right in the door! Good luck man! Youre gonna need it! -
Willys pickup! NICE! Probably has a 4cy flathead engine, but I really don't know for sure.
What are you going to do with the parking brake? Or are you just leaving it out? Just curious! Nice work!
My new donor cherokee has the A904 trans in it with the NP228 TC. Does anyone have any opinions one way or another if this trans is worth keeping for a future project? Is it as reliable as the AW4 or is it junk? Just trying to work with what I have if its worth it. And also... from a previous thread question... Will the NP228 bolt up to and be usable on an AX5? Thanks for the help guys!
Also the 3.1 from same vehicle, though I don't know the years for them. I have 2 86's now and am entertaining this as a future project as well. The 3.1/3.4 swap would be the easiest, quickest way to get you going again. As Jeepcomj says you may want to look into keeping the fuel injection from whatever donor you get... somehow possible to wire it up standalone and do away with the horrid 2.8 carb setup. Good luck -
What should I expect from my 2.5?
dasbulliwagen replied to rnobles's topic in MJ Tech: Modification and Repairs
You and me both! -
A cherokee bumper will not bolt up to an MJ without custom made brackets and trimming of the end caps. Though I havent tried it the MJ brackets if you still have them may bolt in place of the XJ brackets and allow it to be bolted up with trimming of the endcaps... though I really don't know for sure. I made brackets to mount an XJ bumper...
M715????? Oh please be an M715!!!!! I want one sooooooooo bad! Or maybe an FC150 or FC170?????? I can't wait to see what this is! :popcorn: :popcorn: :popcorn:
I got my 2.5 under similar circumstances... been sitting mostly for several years. I tuned it up, put several bottles of fuel system cleaner through it, and it helped little by little. The thing that helped it most was a new O2 sensor, and its run great ever since, realtively speaking. As for what to expect.... don't expect too much and you won't be dissappointed. Anything you do for performance ains are going to be marginal at best, but your best bet would be to go to 4:10 axle gearing assuming you are going to stay stock height. Your auto may have better gearing already.... I think car-part.com listed 4:10 as an axle choice for 86... that should have come on the 5 speed manuals, but it could be under the auto as well, youll need to confirm this though. There a several ways to do it. But ways to pick up a little peformance are to do away with the engine driven cooling fan and replace it with an electric unit and controller, some say throttle body spacers work, cold air intake, Gut the cat converter..... but this could cause problems with loss of backpressure though I have experienced no problems with it myself, high flow muffler, header- from various sources, cam- if you can find one, Clifford performance make an intake for it for an aftermarket fuel injection setup or a carb, port and polish head...... if you REALLY REALLY want to keep the 2.5 those are your options, but for the low cost of a donor cherokee, you could have a complete 4.0 driveline... but wheres the fun in that??? Jeep ran 2.5 equipped Comanches in SCCA sucessfully for many years, so theres got to be some good to hopping them up. Feel free to ask any questions here, and ignore all the naysayer that just tell you to swap to a 4.0... unless you really want to! -
That sounds like him... diesel fuels class...great guy...tons of experience... one of those walking encyclopedia guys whos been there and done that... TWICE, and can back up whatever he says... the kinda guy you like to keep around to bail you out of shiznit!
All should be the same as previously posted except the transfer case like Pete said, NP231, and could be a short bed, if its a 5 speed AX5 then 4:10 gears, if its a 4 speed AX4 then 3:55 gears, Long bed with a 23 gallon tank, short bed with 16 gallon tank.
who taught that class, Frank Dixon? I'm horrible with peoples names, so I really didnt pay attention to his name, but it does sound familiar. Training was in Charlotte, NC on tuesday and wednesday this week.
I just got done with Chrysler level 3 Diesel training, and from what they were saying in class, the 2.8 is a much better engine than the 3.0 v6. They say that the 3.0 injectors like to let carbon past the injector seals and literally cement themselves into the cylinder heads after a while! You could attach a cherry picker to one of the injectors and lift the whole engine before the injector would come out of the head.... and the complexity of that engine is just ridiculous! For a chrysler tech there is no rebuilding of this engine.... only complete replacement! AT $25,000 for a long block too. Mercedes build them for $4000, sells them to Chyrsler for $16,000, and Chrysler sells them for $25,000... Thats called Matrix pricing! The 2.8 is an actual industrial engine, more reliable, and much less complicated and (relatively) inexpensive.
:needpics:
A stainless flowmaster 50 series would be close to the sound you want, but I don't think anything will give you the rumble you are expecting merely because its going onto a 2.5. Ive got the Flowmaster 50 on my 2.5 with a gutted cat and its still pretty queit, but has a little growl under load. A 40 series may be too loud though, but will still sound like a 4 cylinder.
Jeepcomj called those parts before I even looked at this Jeep.... it funny that it does have them and the seats are in pretty good shape.... but too, I'm considering a blue interior for my 86 Comanche if I ever build it. Either way, nothing is going to happen anytime soon, but I have it on record here that you are interested! :thumbsup:
