3
I was excited to think they could be collectible, but then had this thought. A 195X Jeep Willys Pickup was at a swap meet I went to, Farm truck, no rust, but hard worked, popped up in the rust belt. Ran, drove, and zipped around still. They wanted $2500. I don't think anyone should be picking these things up if they plan on a financial investment. It might be awhile before you see a return. :rotfl2: Rob L. I did say "maybe"... but in all truth, its a probably not. Thats OK, maybe they will continue to be in most of our price ranges... meaning cheap.
for 86 the bolts were made into the header panel, and later they were made to the fenders, if youre trying to remove the nuts from the back, youll need to remove or pull back the inner fender liner, then you can get a 10mm and some long extensions up in there to get at the two top nuts. Now if your new header panel doesnt have the studs, youll need to drill your fenders where needed and put a nut and bolt through to bolt it on. Hope that wasnt too confusing.
da man's pickin on me...now:I fought the law, and *I* won :)
dasbulliwagen replied to Pete M's topic in The Pub
I don't think Pete's neighbors are the problem.... -
exhaust / brakes
dasbulliwagen replied to SchneiderFishing's topic in MJ Tech: Modification and Repairs
Clean rotors, new pads, and stainless braided brake hoses will really make an improvement... the brake hoses themslves should give you better pedal feel by themselves. -
:USAflag: :clapping:
I'm not here to defend adoption agencies, but after working with one for several years, they do have their reasons for being very wary of people. Ive seen too many horror stories of animals getting adopted and then being mistreated or abandoned after the owner decides they are tired of taking care of their new pet. Sometimes the people would do the right thing and return it to the agency, we had a no questions asked return policy. But most times they would just get dumped to fend for themselves. So it makes the adption people very persnickety about who they give their animals to. To the point I guess that it can go too far.... any little thing they think will make you a bad person, weather real or perceived will make them sway toward not adopting to you. I was never one of the interviewers but saw it all the time as it was often one of my foster animals that was in question for adoption. Stereotyping people is just part of the job, because you are usually correct about it. But in persoanl experience, the ones youre wrong about on first impression often end up being the best people. I'm sure thats case with you, and I hope you find what youre looking for. Good luck!
should i chance the drive?
dasbulliwagen replied to mike87mj's topic in MJ Tech: Modification and Repairs
Another thing that should help with heat is some water wetter added to your cooling system.... supposed to help heat transfer by breaking the waters surface tension.... all the drag racers use it to cool the cars off faster between runs. There are several brands of this, just do a search. -
Ive never seen rattle can exhaust paint that really lasted any length of time, but then again, Ive never done the curing method either. :doh: But like you said, if its gonna rust anyways....
I know its sad, and they may be rare, but they are not collectors items.... at least not yet. Our trucks are as much a collectors item as a Cadillac Cimmaron is a collectors item! Its like the early mid 70's cars are now collectable, maybe our trucks will be in another 10 years. But not right now.
Almost 200 pictures of a rallye Comanche... I think he may be a member here, but I'm not sure... here's the link! http://picasaweb.google.com/sureshot007
I still think youre wired wrong.... just my 2 cents.
Is it a waggy with the solid read rear tails? Rob L. I didnt know it was a waggy because the front end and fenders are gone, and the rear hatch, bumper, and lights are gone,,,,like I said... not that it matters. Would have been nice to have spares for my front end on the 87!
rear brake proportioning valve
dasbulliwagen replied to shawn's topic in MJ Tech: Modification and Repairs
:huh???: Something doesn't sound right. The main brake line to the rear goes into the valve section of the rear valve, the second line going to the rear is for emergency stops, and will send braking to the rear bypassing the valve... both should have full fluid in them, and t-ing them together just makes you have two fluid lines going to the rear, one that will provide pressure when the pedal is used normally, and one that provides presssure in a panic stop, T-ing them together and then going out to the axle just eliminates the rear valve, and full pressure goes to the rear brakes all the time instead of just in a panic, and will be doubly used if there is a panic. Does that make sense? Maybe I can draw it up in paint if I need to. This way you don't have to mess with the front valve or eliminate any lines, or block anything. Works fine too! -
1989 MJ Elimanator
dasbulliwagen replied to Old man with MJ's topic in MJ Tech: Modification and Repairs
Most likely internal, sorry! And yeah, while its out, do the clutch too.... can't hurt. For the slave though, spring for one from the dealership....should ne much better quality and shouldnt give any problems any time soon. -
As I was installing my 4x4 front axle for the conversion, I noticed that my front brake hoses were in terrible shape, so I replaced them today with some YJ stainless hoses I bought a while back. I can't beleive that between the new hoses, new pads, and new rotors how much better my brakes feel! Its great.... I wonder how good the brakes would be if the rear valve was disconnected? Or if I had the WJ master that I want to do! How much better can it get?!?! And my DW problem is still there, it happened to me twice today, so up on the lift it went with a guy inside... the TJ trackbar I installed when I put the front axle in will move 1/4-3/8" each direction at the axle connection...like the rubber bushing is way too soft or something. And I couldnt notice it by looking, but my outer tie rod ends are slightly loose, I can feel it moving by putting my hand on it when I try to push the wheel back and forth. I'm sure thats not helping things either, but the trac bar bothers me, so I went and bought a 5/8" drill bit so I can install my new Pro comp adjustable trac bar. I ran out of time to install it today, but Ill get it tommorow. And I guess its time to keep an eye out for better, or new tie rod ends! Oh also found out that my new parts XJ is actually a Wagoneer XJ, not that it matters, but I found out that the front axle is a non disco! Still can't read the tags on it, maybe Ill take some sandpaper, a flashlight, and a piece of cardboard to lay on to look at it tommorow to try to figure out what gears it has.... COME ON 4:10's!!!
^^^^^ I got to see a Concorde land and take off once, in Battle Creek, MI.... British air was sending a bunch of its pilots to school at Western Michigan University's Battle Creek Pilot traing program..... friggin shweet! That was obviously before the Concordes were retired..... what a great way to get to school though! Battle Creek has an ANG base... Ft Custer.... A10 Warthogs fly around town every weekend! I love them things! Great lookin Air show though, where was it at?
What I did with the Boss's truck is T the two lines together at the rear that would have went into the prop valve, take the third line off the T to the flex line to the axle..... same basic principle, one of the lines was emergency braking to the rear, the other was normal braking to the rear through the valve.... they both start out at the same point, I just ended them at the same point. Simple. -
The Nissan deal fell apart when Chrysler went into bankrupcy, but it wasnt Chrysler buying Nissan, it was just Nissan getting the rights to rebadge a Dodge fullsize. I too am glad it didnt go through, but because I can't stand Nissans. The current Nissan full size is not selling well, and they were hoping to save money by getting a good platform that is already being made elsewhere to help thier truck line. Its bad enough that Mitsubishi is taking the already ugly current Dodge Dakota and making it even uglier! There were also rumors very recently that Hyundai was looking at Dodge trucks to rebadge for Hyundai trucks to expand thier lineup. But there seems to be no truth to that one, so far. This is off topic isnt it...... sorry.
Arent they already actually building those for overseas military? I think they are.... so its not like they couldnt give it to us if they wanted to.
dude, you can't post that without some type of explanation or a link or something?? supercharged 4.0? Sorry, I didnt even think about a link. So here's a turbo 4.0 to go with it.... second link, lots of pics! http://naxja.org/forum/showthread.php?t=1020769 http://www.naxja.org/forum/showthread.php?t=1031285
clutch pedal needs to be "pumped" ??
Internal seal leaks at either the slave or the master sounds like. Youll probably need to replace both.... it should be external slave, so should be no big deal.... you won't need to pull the tranny!
