dasbulliwagen
    3
  1. Or pull it out, and take it to the car wash and hit the whole thing with the pressure washer after spraying it down with a color safe degreaser. Then if you have any wierd color spots you can touch it up with a spray dye in a similar color.... a guy i know just did this to his Ranger V8 project, and it turned out nice!
  2. I guess I don't know Jeeps like I thought I did, so I have a question.... what is an LJ????
  3. Just read an article at www.allpar.com that shows the new rams have very high ratings when it comes to reported problems. I would go that route myself, but then again I'm biased toward them anyways.
  4. Just looked it up, there appaears to be a seperate oil pan gasket section for the bottom of the timing cover, so you might want to get that gasket too, and a new front crankshaft seal that installs in the cover.
  5. Alldata shows to remove harmonic balancer, and then goes right to remove cover. Does the oil pan overlap the bottom edge of the timing cover? I'm not sure, but the directions sound easy enough. Good luck.
  6. After looking at the VIN's on the registry pages, I was wondering if the Comanches serial numbers were all for Comanches or if they were just thrown in with the XJ's? Because looking at the VINS serial part, we know there werent that many Comanches made. Has anyone looked into this before?
  7. 1988 Jeep Comanche Pioneer Olympic Edition SWB No pic 4.0 AW4 NP231 30/35 186,484 miles as of 6/10 All stock, no rust, Blue bench seat interior, white exterior Located in Asheboro, NC Owner: Jerry B. (for sale for the right price)
  8. I bet if you walk in there with $3000 CASH youd probably get it. :thumbsup:
  9. If youre gonna swap in a 4.3, why not make it a 305, or a 327, or a 350, or a 383, or a 400???? Same amount of work, and chances are, youll have overheating issues with the 4.3 as well as any of the others. Now if you kept it down to a 3.1, or a 3.4, they would bolt up to your existing transmission. And there are ways to keep the injection with them as a stand alone system. A 4.0 would be easier than the 4.3 as you know all of what it would take to do the job, and everyone here would be able to help out, as its been done many times. The 4.3 has also been done, but its nowhere near being a bolt in and go situation. Good luck and let us know how it goes!
  10. Found out this morning that I still have DW. Though its not as bad as it was before. I ordered some factory front caster shims yesterday to prepare for setting my front caster where it should be, the dealer is the ONLY place Ive seen them being sold, as I really don't feel like making my own, and picked up my second new right outer tie rod end from autozone... hopefully this one is made right. And my buddy is looking for the rear chevy drop shackles he has so I can install them as well. Ill get my new rod end in, and the rear shackles, then I can set the caster and re align the front end again. Hopefully this will help the DW.... if not, its time to go shopping again for more parts.
  11. My truck also has two sets of plate wires, one for a single light setup for use with no bumper, and two more for dual lights on a step bumper. Theyve been unhooked for twenty some years, just leave them alone!
  12. FOUR THOUSAND DOLLARS!!!!!!!!!?????????? HOLY MOLEY! I wonder what he'll ask after he does more mods, because theres no way hes gonna sell it like that, for that price! People (in general) are idiots, especially when they are either uninformed, or overinformed....like this guy, whichever one he is. His attitude oozing from the ad doesnt help things either. Good luck buddy! :nuts:
  13. Did those have a mechanical fuel pump? If so, go get a can of starting fluid, spray a little in the carb, and start it. Its possible you lost fuel prime, and the slow cranking isnt enough to pull fuel up fast enough to get gas in the carb. Once you have it running a little on the starting fluid, the engine will turn over faster, and the fuel should be pulled up and into the carb where it SHOULD then run on its own. It might take a few tries to get to the point it will run by itself. Good luck, let us know what happens.
  14. Get the VIN for the registry.
  15. This brings to mind the old adage " Be careful what you wish for.... it might come true." Good save Jim! And thanks for thinking of us Mike!
  16. The painted windshield trim is original from the factory, mine is doing the same thing. I pulled a set of unpainted trim from a CFC Wagoneer and will install it soon. Not sure how easy it will be to remove the original paint. Good luck.
  17. And....... :needpics:
  18. dasbulliwagen
    Marine
    :USAflag: You better start working out right now to get in shape for boot.... get a gym membership, and tell them what youre doing and have them whip you into shape before you go, watch "Full metal jacket" 100 times and get your mind ready too. :thumbsup:
  19. :clapping: :clapping: :clapping:
  20. The mirror adjuster is not in that switch, it is usually mounted in the center console. I need a 2 door switch also, but I'm in no hurry, as the 4 door one works just fine.
  21. :popcorn: I can't wait to see how this turns out!
  22. 1987 Jeep Comanche Chief No Pic 4.0 AW4 NP231 30/35 SWB Build date: illegible Current Location: Asheboro, NC Status: Daily driver, single family owned Notes: All stock, blue bucket seat interior, white exterior Current owner: Tommy L. 104,000 miles as of 6/10
  23. With no codes and a running problem, I might look at fuel too. Sounds like it might be getting pressure on startup, but maybe the fuel pump slowly slows down till it can't push enough fuel to keep it going. When it starts sputtering after running for a while, jump out and hammer on the bottom of the fuel tank, see if it comes back to running OK. If it does, then you know you need a fuel pump, either that or theres a bunch of crud in the tank building up on the pump filter sock, restricting flow enough to cause this problem. Then after it stalls, the stuff falls off, and starts over. Good luck!
  24. I'm not sure, mine were on an 86 wagoneer, I just took the whole doors, as they were the same color, had the vents, power locks and power windows, and power mirrors. Mine are really the only ones Ive ever seen, but it is likely that you would find them on XJ's from 1984-1996....probably the earlier the more likey it would have them.
  25. Find a cherokee donor in the junkyard that has them. From what I hear they were pretty leaky, so most people got rid of them. I just installed Cherokee (Wagoneer) front doors with them and mine don't leak yet, so I guess it would depend on if the seals look like they are any good or not. Good luck.
