dasbulliwagen
    3
  1. After living in Michigan most of my life, I am now very thankful that I'm in the south with rust free toys! And you know that if you want to keep that truck like that, you won't drive it in the winter! I used to have to find a winter beater every year so I could put my nice VW's away for the winter to keep the rot off them. Nice find though, and I look forward to the build!
  2. If you only get adjustable lower control arms, youll mess up your caster, and your front axle pinion angle. Wheels with a more stock backspacing might not rub though, bringing the rim further in, thus maybe missing the edge of your fender, but possibly rubbing on the control arm. But then again, more lift is always fun!
  3. I don't have much atv experience, but the one time I did ride, I wished it had power steering. That would be a must for me.
  4. Just about every factory original airbox is more of a cold air intake than anything you could put in there, as the airbox usually draws air in through the fender, or directly through the core support. I think though that the thing that the new ones do is smooth out the airflow coming in making for easier breathing.
  5. The previous owner of my truck had Jasper put in a new engine for him.... that was 200,000 miles ago and shes still runnin strong. Just call around to local shops and get some prices, or go to Jasper website and see who is reccomended by them in your area. As far as a rebuilt longblock cost I think Jasper is pretty much right in line with everybody else. That will at least give you an idea what youll need to save. If you don't mind the 2.5 power, then just seak out anther 2.5. Thats the simplest solution.
  6. The shock bolts broke, but the brake hose held on? WOW! Need to start using brake hoses as limiting straps!
  7. WOW that thing is ugly! Looks like somethingk that would kome drivingk out of old Soviet Unionk.
  8. HUuuuuuuuuuuuuu????????????? sorry I do not understand 4bt what is that?????? and if u are saying need more to be true haaaaaaaa you will see the pic's when I pick it up sunday and frankly I don't care if you think its not true or not... I do not understand why you would think its not but what ever... :cheers: Cummins 4BT 4 cylinder turbo diesel engine. Nice diesel engine upgrade. Hell, its a full size, why not shoehorn in a 5.9 24 valve 6BT! Nice find. I had one the same color, same interior. Loved that thing. Most comfortabble vehicle I ever owned.
  9. MY DREAM TRUCK! I WILL have one someday. Prices are still pretty cheap, relatively speaking of course.
  10. That was a waste of 2 minutes.
  11. There is also a procedure for opening and closing the valves. If you don't do it correctly, you will let all your refrigerant right out into the atmosphere. Same goes for your vacuum. I always have to look it up when I'm doing it, just saying you need to be careful with that.
  12. There is NO source for tail lights other than Junkyards, or used ones for $300 on ebay. There are a few other MJ specific parts that that is also true for, such as the cab vents, the rear fender flares, the parking brake mechanism, and the seat tracks. If youre looking for stock parts, most any auto parts stores should be able to fix you up on common stuff, Crown is a good source for parts, but they only sell through dealers. Other than that, just search the internet to find what you need. Good luck with the new MJ and welcome to the club.
  13. The uber rare 21 slot grille! :drool: :bowdown: Ive never seen one of those in person. They are rarer than the Waggy grilles! What you have there is exremely sought after. Wanna sell?
  14. I hope you realize how difficult it is to get pics of these events. And your word should be your word if you want this thread to go anywhere. Yeah, pics would be great, but thats not always possible, especially if the car is going the opposite direction from you, which is how you would usually see a car like that. :fool:
  15. The factory wiring runs as one harness all the way to the other side of the dash usually terminating at the pass side kick plate where the antenna wire hooks up, and then again at the heater/AC controls on the HVAC housing. I'm not sure if its possible to pull the whole harness out or not wiithout removing the dash, but if youre sucessful, let us know!
  16. I am thinking that if you want a complete uncut harness, youll need to pull the entire dash out to get the harness out intact, and replace the whole interior harness just to get the radio plug. I agree with nicely repairing the original, maybe get some of the fully insulated male and female spade connectors with the shrink ends to make a clean repair, and plug it all back in real nice. It all depends on how much work you want to do to get it like you want it.
  17. You need to go back to that yard and get the waggy front to put on your truck!
  18. WTF! :fool: :nuts:
  19. I don't think it counts if it has a Chevy engine in it.... it aint a Comanche anymore....in my opinion.
  20. Bosses truck, 88 MJ 4.0, AW4 4x4, all stock. While accelerating it seems to surge up and down enough to rock you back and forth while driving it. It does it some too while steady driving, but not as bad. He also said that sometimes it will bog out if you try to get on it hard. Not sure if related or not, but I'm having vacuum issues on it too to the point of it constantly changing the AC vent settings from vent to defrost and back depending on how far you are into with the gas pedal. I know that the farther open the throttle the less vacuum is available, but following the vac lines to the bulb and back there does not appear to be any breaks or issues anywhere. Same goes for the vac lines to the EGR and the air box thermostatic bypass. Any ideas? Id greatly appreciate it, and gain more brownie points with the boss.
  21. Certified Chrysler Dodge Jeep dealer tech, and in the process of getting my Mazda dealer tech certification. Formerly a household plumbing and electrical service technician, and before that I was in building maint. and housekeeping for a private college, and a county school.
  22. I did a 42oz steak challenge at the Grille House in southern Michigan. I had 2 beers, 3 glasses of water, 2 bowls of salad, the 42oz steak, a baked potato, and a large slice of cheesecake. Afterward I felt suprisingly fine! Drove home even! Good try though, you might have to practice up, and go try again!
