3
Engine Technology
dasbulliwagen replied to Worlds Fastest Comanche's topic in MJ Tech: Modification and Repairs
MOPAR no longer makes or carries the performance cams for the 2.5. I checked with our dealer parts dept to see if anyone had any laying around on the shelves around the country, NOPE! The only other place Ive found to list a cam for the 2.5 has their website saying they are closed down temporarily... like till 2012. They are in Vancouver somewhere. can't remember the name right now... have the info on the comp at work though if you want it. Another consideration for a newer 4 banger is the 2.4 that came in the Wrangler for a couple years... same engine as the Neon, and TONS of performance parts available.... and you could just swap the trans from the wrangler too. The Chevy 4, 5, and 6 bangers Ive heard nothing but bad things about them.... from GM dealer tech! I would stay away from those. Not sure about the power and torque from the 2.4, but can't be any worse than the original 2.5! Slap a cam in it, and a header.... who knows. You could even swap in a turbo. Have you ever driven a Neon or Caliber SRT4???? SCARY FAST! ( mostly because of horrible torque steer) Good luck. Let us know what you end up doing! -
That is whats left of a relay.... to what I have no idea. Could be for fog lights if you have them or if it was equipped in the past and being in the front end. There is supposed to be a plastic cube like cover over the wire winding you see.
How bad broken is this?
dasbulliwagen replied to Rymanrph's topic in MJ Tech: Modification and Repairs
Looks to me like a broken mode door shaft. If so, youre pretty much screwed. If you have the unit out of the truck, pull the unit top off and check the mode doors there. At the very least, youll need a new door put in, at most you might need a whole new housing. Good luck -
Ive been thinking about doing something similar to the 86 if I ever build it but using steel electrical conduit, making a faux bar, and tire mount. can't be any worse than rolling a truck witout a roll bar. They are built from the factory to withstand a roll and not crush all the way down allready, so a rollbar is just added insurance, and ANY extra support, be it actually structural, or just for looks will help distribute the roll impact more than just a cab. It has to look better than one of those ugly back racks. I say go for it. If youre happy with it, thats all that matters. Make sure you send in pics of the process an when its done! Good luck.
Youve been bitten, its already starting to infect you. Once you get to drive it around some it will only get worse. It starts with a few little upkeep upgrades and progresses from there, two years from now, youll own at least one more MJ, and probably another non running XJ that you want to keep for "parts", but secretly want to fix them up also. Its only a matter of time..... :brows:
To the guys that have gone thru a divorce with kids......
dasbulliwagen replied to Chico's topic in The Pub
I'm not sure if this helps or not, but the movie, "War of the Roses" with Michael Douglas, Cathleen Turner and Danny Devito is a good cautionary tale. Mostly saying to just let her have everything and start yourself over clean. But with kids I'm sure it different. There is no easy answer.... just time. Good luck. -
smokey cab, where can it be coming from?
dasbulliwagen replied to lostissues's topic in MJ Tech: Modification and Repairs
If the fan was off, the resistor should not have gotten hot at all, I thought that too, but then he said the fan was off. I can't see the heater core getting hot enough to smoulder mouse house stuff either, but who knows.... definitely need to clean out what you can from the housing. Remove the fan and see what you find. When I swapped HVAC housings in my truck to add AC I had to remove all kinds of crap. If you can't get rid of the smell, that may be your only option (to pull the dash, remove the housing, and open it up to clean it out). Good luck. OH and buy a good fire extinguisher! -
Ralph Nader??? Theres a name that could go away.
It would be easy for me to tell you to just not drink, but then again, I myself just don't like it that much. If you do like it, like I assume you do, then its much more difficult than that. All I know from what Ive seen others do in the past, is that you have to want sobriety bad enough to make yourself want to quit. If you don't want it bad enough, it isnt going to work. Your priorities have to be in the right place, and your willpower has to be strong enough to be able to tell you you don't need it. And think of all the money youll not be spending on alcohol that you could put right into your MJ! Though that doesnt always work either... I don't really drink, and I still don't have money for the MJ! And by "don't really drink" I mean I don't drink to get drunk, and I rarely have any beer in the house, and usually if I do, it goes bad before I have the want to drink any. A couple of drinks while out to dinner is all I need or want usually. And no hard stuff....just don't need it. I wish you all the luck in the world with this, and hope you reach your goals.
My sister called me one day asking me about changing her stratus back over from synth to dino, as the quickie oil change place had told her and who knows how many other people that the engine needed to be flushed out before she could change oil types (she was trying to save money). I told her all those oils were perfectly interchangable and could be mixed, and that she didnt need to spend$79.95 to have her engine flushed. Bunch of frickin rip off artists they are. Taking advantage of peoples ignorance on the subject. Its just wrong. MIX IT!
31"s fit under no lift with no rub?
dasbulliwagen replied to case5412's topic in MJ Tech: Modification and Repairs
I feel special being called a smart guy. Thank you, there arent many people whove ever said that to me. I'm just trying to help out. There are a few grumpy old bastards on here (no offense guys) that don't take the lack of info very well. The more info we have the better we can help you... thats all.... just makes sense. And I agree that the 30" tires would be much better. You may still get some rub with them as well. You could swap your lower control arms for WJ grand cherokee ones, or adjust the stops as mentioned. I scored a free set of 235's off of a wrangler because they didnt like the rubbing, but they don't rub on my 2wd MJ. The rubbing won't hurt anything, all the ones Ive seen do this barely show any marks on the tire from where this happens, its just a bad sounding annoyance. Good luck with your build, and keep us updated! :thumbsup: -
Project "Grandpa Jeep" (the anti-build)
dasbulliwagen replied to jpnjim's topic in Member Projects: Your Comanches
don't forget to add the 1" reflector tape stripes down each side, and across the front and rear bumpers! ( Ive actually seen a grandpa truck done like that before! ) -
The madness continues.......$10k MJ on eBay
dasbulliwagen replied to WahooSteeler's topic in The Pub
Did some research... with the options on it, looks like it might have been an Eliminator... floor shifter, cargo light, lighted visors...etc. Was the eliminator available 2wd? -
Was auto with a floor shifter ever stock on a Comanche? Ive never seen one. And lighted vanity mirror visor???? I looked up the VIN through chrysler, it shows up, but the options list doesnt come up. Theyre really laying it on thick in that ad though! WOW. -
If I was them, I think I would have omitted the picture of the missing cat converter. "Rediscover trust!" FUNNY! -
Lightweight Flywheel?
dasbulliwagen replied to Craft86MJ's topic in MJ Tech: Modification and Repairs
I would only do a lightened flywheel if I was racing it, otherwise its not very beneficial in real world driving. Especially in a Jeep where you want to keep some low end torque, a lighter flywheel would ruin that. -
Interesting for 2.5-2.8 owners
dasbulliwagen replied to dasbulliwagen's topic in MJ Tech: Modification and Repairs
I forgot to mention, the PT cruiser fan assy comes with 2 relays mounted to the housing already. The fan plugs into the relays, and the relay harness has one connector that connects to the body harness. So if you had the whole harness, it would make a fairly easy wire up I think. -
Noticed recently that the electric cooling fan assy from a PT Cruiser is similar in size to the 2.5-2.8 radiator. Decided this morning to actually see if they would go together.... they are almost exactly the same size. With some trimming and creative mounting I'm sure it would be a fairly easy conversion. You would need a fan controller, and need to find out which wire is for the high speed fan, as this is a 2 speed fan, but otherwise might be a good option for those who would like to pick up a couple of ponies on their asthmatic engines. The low speed part could even be wired with a relay and dash switch, as it is the one used most of the time anyways... at least while the ac is on, or have it wired seperately to the ac if you have it, and the main controller wired to the high speed fan. Just thought Id throw this out there. The only thing I havent looked at with this is fan to water pump clearance, but it looks like it should fit judging by what I did to mine with the WJ fan I adapted.
This style wheel did not come stock on any 1986 Comanche. The premium aluminum wheel for 1986 was the 10 spoke. All of the other wheels that were available in 1986 were steel. I hope this info helps. Those same wheels were stock on my boss's 88 MJ Olympic edition, so maybe they were swapped onto my 86???? you never know, but I think we can agree, that black interior was not available after the 87 model year... unless it was swapped too. You never know what happens in a vehicles past.
To expand your search, you should also look at the Camoro 3.1 as well. They were out before the 3.4, and will work just the same. Good luck.
try unlocking the hatch door with the key, it might turn it off that way too, assuming the doorr switches are bad... seen it before.
Sportruck was available in 87, and 87 was last year for black interior. That steering wheel was base model wheel.... the interior is exactly like my 87 sportruck wheel and all, though I'm not sure about the wheels. I know those wheels were stock on my 86 Comanche X, so it is possible they were original, though Ive never heard of a sportruck limited.... maybe thats where the wheels come in?
'74(ish) VW Dune Buggy Build
dasbulliwagen replied to neohic's topic in Member Projects: Other Cool Stuff
Know what that engine needs???? DUAL WEBER 48 IDA'S!!!! :banana: -
They arent common???? There are twenty people on here at any one time that would love to get rid of their bench's and go to buckets, and if you don't have the gap in the middle the seat won't adjust. As for size.... its sized to fit the truck... what else do you want? If going custom, go for the Dakota swap, its a 60/40 split, you can solid mount the pass side so as not to interfere with the shifter and have adjustment for the driver. You need to be more specific when asking stuff here. it will help greatly for us to understand your needs. You just asked for a bench, you didnt say the mounting was screwed up... so easiest answer is MJ bench. I'm sorry if I sound like an azz, but its not always easy to understand what youre looking for without more specifics... that goes for everyone. We are here to help, and this place can be a tremendous resource, but we're not mind readers...sorry.
