3
Hes actually a 40 something (I think) back to school, hes had the truck for several years and is on a TINY budget. I asked him about the 3.4 option, but he didnt seem to think he could afford that route, so he did what he could do. Hes got a kid getting ready to drive, and is need of another vehicle so the kid will take his XJ, and he'll drrive the MJ.
97+ xj rear bumper swap?
dasbulliwagen replied to Walkenvol's topic in MJ Tech: Modification and Repairs
I think if I were doing it, I might try for a smoothed and painted to match original MJ rear flare, probably your best option. -
Went back to second night of inspection class tonight, and saw the owner of the Comanche and spoke with him. He said he had checked us out and does have plans to join and start a build thread. He also had the rebuilt 2.8 ready to fire up! I wish him luck and hope he finds this place to his pleasure.
I have done little to nothing to the MJ lately, but I need to, because I'm starting to get an itch to get back into air cooled VW's, and I just can't do that right now, so I guess Id better get busy, and finish my rear shackles, my front end alignment, finish my trailer hitch build, start my bodywork so I can paint the rockers, polish the rest of the truck so I can add the stripe tape I want to put on to cover the holes left over from the wagoneer trim parts that were removed, and find some white Herculiner to do the bed next year. And I have that wagoneer parts vehicle I need to figure out what I'm going to do with, and a spare 2.5 at my parents house in michigan that needs to come back to North carolina so I can start a rebuild on it to have it in case anything happens to my current one---- Knock on wood!
Not directly. The distance from the edge of the wheel well to bumper end would have to be measured to see if it would even be the same distance... if not the bumper end cap/ rear lower rocker would either need lengthened or shortened, not sure which as Ive never measured. Also, the whole lower bed edge may need to be cut off to make room for the bumper end cap. And then youd also have to make adapter brackets to mount the bumper to begin with.... I made my own brackets to mount a 96 XJ bumper on the back of my 87 MJ... Just look for "Comanche Limited" in the projects section to see pics. I still havent figured out a permanent way to mount the plate, but I think a front plate bracket will bolt to the bottom of the rear bumper as a place for a plate and then run a pair of LED lighted bolts for a plate light.... I have done that, but have yet to update my build thread and pics (The bolt lights thats is). If you do it it will be a lot of work to make it look right, but might be worth it if youve done the front conversion already. Good luck. Edit.... the rear flares will definitely have to be modified as the opening arch on the Mj is much larger than an XJ. -
Anyone recognize this roll bar?
dasbulliwagen replied to Incommando's topic in MJ Tech: Modification and Repairs
Looks like it fits nice, who cares what it came from! :thumbsup: -
88 mj backfires at WOT
dasbulliwagen replied to ComancheGurl's topic in MJ Tech: Modification and Repairs
O2 sensor could cause this too if its bad. My 2.5 would act like that sometimes while accelerating. I tried several things with the fuel system hoping to get it to go away, finally put a new O2 sensor in it just because, and as soon as I took it out on the street, it smoothed out and has been running great ever since. But like the other posters said, check the EGR valve for proper operation and closing ( it would cause a vacuum leak if it didnt close all the way), Vacuum lines, fuel pressure, fuel filter, check that the intake manifold bolts are tight... My 258 I had in My Grand Wagoneer would do this, tightening them regularly would keep things working properly. But I don't think the 4.0's had much of a problem with this. Good luck! -
Understand new Missouri Replacement of a motor law?
dasbulliwagen replied to streetjeep2.5's topic in The Pub
How many people or even mechanics EVER see serial numbers of engines or tires to be able to register them so they can be taxed??? Especially in rust belt states!!! I'm not even sure California is that strict, but then again i could be wrong. I do know that when I was into VW's there was a big to do in California about air cooled VW engine blocks and what ones could be used for certain years as a replacement block as required to keep emissions regulations straight. The Blocks themselves had nothing to do with emissions, and I think they fought and won the right to use blocks not from their year of manufacture, and the allowed use of non numbered replacement blocks being manufactured in South America for replacement purposes. I know it doesnt apply specifically to Jeeps, but just goes to show that the system can be fought and changed. And remember what is behind all this..... The Director of REVENUE!!! Its all a money racket. Nothing more. -
If its an 86, theres no way it would have a 44, if it were metric tonne, it would have the even rarer M20..... 86 only!
Need some advice (engine issues)
dasbulliwagen replied to thedave360's topic in MJ Tech: Modification and Repairs
A general rule of thumb for oil pressure is 10 psi per thousand RPM, and 20 psi at 1800 rpm is within that spec.... especially for hot oil at driving speed. What type of oil filter are you using too. That has been known to cause issues with the 4.0L's especially if its a Fram oil filter. Some filters just restrict pressure too much. Get a WIX or K+N, or just something other than what youve been using and see what happens. -
At my state inspection renewal class tonight at the Community college, and while on break, went into the shop to look around. On a lift is a nice 86 Comanche X being rebuilt. No plate on it but looks like the 2.8 motor is about done, and tranny ready to go back in. Black with a burgundy bucket seat interior, 5 speed, dana 30/35, Np207. Couldnt get the VIN, but left a card on what I could reach of the steering wheel cover. Then I look around and on a table is a type 1 VW dual port motor, ready to be torn down! SWEET! Ill be back here again wednesday, and I know the instuctors, so I think Ill have to ask about these finds and the students involved with them. Just thought Id share.
In my 87 the jack mounts behind the driver seat.... just saying.
In my opinion, the BIGGEST problem with the bars is that the tube diameter is too large for the size of the truck. If the tube size was 1/2" or 1" smaller in diam, I think it would look better that way. Though I know its not possible to change that part, so I vote off.
I like my 2 spoke, but if you don't, you can find a different wheel from a similar yeared Comanche, Cherokee, or any GM product that has the same styled column. Will bolt right on!
chevy drop shacke part # ?
dasbulliwagen replied to shawn's topic in MJ Tech: Modification and Repairs
Some of the drop shackles for the Chebbies have several holes in them for adjustability. Id look for a set like that and then you can adjust the lift you want. Just go to www.summit.com and you should be able to find a set. I don't have the catalog in front of me otherwise Id look up the number for ya. -
If you have room to clean them up, soak them with PB, and then start with a 1/2" 12 point, as half inch is slightly smaller than 13mm, then go to 12 mm 12 pt socket hammered on if the half don't work. Good luck.
1998 2.5L wrangler valve cover
dasbulliwagen replied to 87Chief's topic in MJ Tech: Modification and Repairs
get the bolts from the new one too, as old style and new style are different..... just remembered, -
Comanche Club record breaker. now on for Sunday@10pm eastern
dasbulliwagen replied to Automan2164's topic in The Pub
I think maybe a sunday night might work best. Everyone is home (sober), getting ready for the new work week. Just my 2 cents. -
I don't think theres a demand, just one of those things that no one makes, and if you need one you won't find one, kind of thing. Just be good to have extras just in case.
I found this thread on Naxja, not comanche specific, but has a lot of ideas for MJ/ XJ upgrades and swaps from junkyards. It has 26 pages with a lot of fluff to sift through, but a lot of good ideas. http://www.naxja.org/forum/showthread.php?t=66012
Yes, just make sure you get all the PCV tubing and grommets to tie correctly into your existing airbox. -
Self etching or Sandable Primer?
dasbulliwagen replied to drase's topic in MJ Tech: Modification and Repairs
:agree: Get both, start with the self etching, and then top coat as many times as needed with the sandable. The etching primer has a kinda acid based thinner that allows the primer to bite into bare metal better. Most body shops if starting with bare metal, will put a coat of etching primer down first before the sanding primer. -
My 87 4cyl 4 speed 2wd (When I got it, currently adding 4wd and 5 speed) shows 345,000 on the clock... previous owner said he replace engine and trans at 140,000, so Ive got over 200,000 on a rebuilt Jasper engine. After talking to the previous owner, it probably didnt need a new engine, just new oil seals. He asked me recently about replacing the engine in his 2000 XJ with just over 100,000 on it because it was leaking!!! So Yeah the 2.5 is GOOD!
:hateputers: -
Engine Sizes, History, and Applications
dasbulliwagen replied to CaffeineTripp's topic in MJ Tech: Modification and Repairs
My thoughts with using the chevy injector is that the computer would tune down the injector to the point that it gets the correct mixture... thats the way it does it with the one injector by reading the O2 sensor. If the 02 sensor says its rich, then it turns down the pulse width modulation of the injectors allowing less fuel through till it gets the correct mixture, and fine tunes it from there depending upon speed and load on the engine.It wouldnt be like two regular injectors putting in their normal amounts at idle causing it to be super rich. Makes sense to me at least. Then when you put your foot in it, it richens up quicker, and can handle mixture better at higher RPMs.
