3
Pull the tires off the Grand, throw them in the back of the MJ, and then go get the Authorities at Wal-Mart mounted, if the rims are loose, they won't ask questions.
Vin Help----Somethings wrong
dasbulliwagen replied to JCole's topic in MJ Tech: Modification and Repairs
here's the options info for your truck. It does not specify which manual trans it has, but it is a late build model, so the AX15 would be original. Also be aware that not all the descriptions are correct as many have been recycled by Chrysler. Vehicle Service Information Year/Model: 1989 JEEP COMANCHE Last Odometer: 0 Miles on Body Style: MJJL61 In-Service Date: Engine: ERB-DESCRIPTION NOT AVAILABLE In-Service Odometer: 0 Miles Transmission: DDQ-5-Speed Manual Transmission Odometer Type: Miles Color 1: PWB-DESCRIPTION NOT AVAILABLE Car Line: XX Color 2: QWB-DESCRIPTION NOT AVAILABLE Build Date: April 8, 1989 Current Market Register: Hour: 17 Standard Equipment Code Description Code Description Code Description APAS Monotone Paint BAQS DESCRIPTION NOT AVAILABLE BCXS Nickel Metal Hydride Battery BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CKJS Black Vinyl Floor Covering CSRS Passenger Assist Handles CUMS Mini Floor Console DHNS Command-Trac Part Time 4WD System DJHS Dana M30/181MM Front Axle DMMS 3.07 Rear Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror HCDS Heater w/Instrument Pnl Ventilation JAAS Instrument Panel JAZS Analog Instrument Cluster JBFS Instrument Panel Black Bezel JCAS 85 MPH Primary Speedometer JKBS Inst Panel Mounted Hood Release KDAS DESCRIPTION NOT AVAILABLE K3ZS DESCRIPTION NOT AVAILABLE LAFS Key in Ign/Seat Belt Warning Buzzer LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LCJS DESCRIPTION NOT AVAILABLE LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS Bright Windshield Moldings MMCS Upper Door Frame Moldings MMGS Belt Moldings MMJS DESCRIPTION NOT AVAILABLE NAAS Federal Emissions NBAS DESCRIPTION NOT AVAILABLE NBKS EVAP Control System NDAS Catalytic Converter NF2S 18.5 Gallon Fuel Tank QWBS DESCRIPTION NOT AVAILABLE RACS AM MTR Radio SCBS 2-Spoke Steering Wheel SFAS Standard Duty Shock Absorbers SGAS Rear Shock Absorbers TADS DESCRIPTION NOT AVAILABLE TBCS Compact Spare Tire TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels WMCS Bright Wheel Trim Rings XBSS Pickup Box XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 141S Zone 41-Cincinatti Optional Equipment Code Description Code Description Code Description *B1 DESCRIPTION NOT AVAILABLE -Q8 DESCRIPTION NOT AVAILABLE CBAP Straight Back Bench Seat DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission EAAC All Engines EAFC DESCRIPTION NOT AVAILABLE ERB DESCRIPTION NOT AVAILABLE GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZ Manual Remote Mirrors PWB DESCRIPTION NOT AVAILABLE RAAC All Radio Equipped Vehicles RCAP 19 SPKRS SRT High Perf Audio SBAA Power Rack and Pinion Steering TAAC All Tires TNCA P195/65R15 BSW AS Touring Tires YEP Manuf Statement of Origin YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z65P Left Front Group XIV Z84P Right Front Spring Group XIII 4BX Employee Purchase 4EAA Sold Vehicle 5ALA Low Series Tracking Special Equipment Code Description Code Description Code Description No Special Equipment Available Dealer Installed Equipment Code Description Code Description Code Description No Dealer Installed Equipment Available -
I measured the rims, and went to Tractor supply, and compared to the lawnmower and implement wheels they have and found a set that actually fit. I had to buy whole wheel /tire combos, but put them in a hot water bath to soften them up, and dismounted them from their wheels, and mounted them on the trike wheels. Takes a littel prying, but it works. Thanks for the comments! Hopefully the new one will turn out just as well. Though I'm not sure yet if Ill be staying stock with the wheels on the new one! Might put some fatties on the back to give it more of a drag trike feel!
thats what I was hoping. I thought the starter motor might come out and that was the worst of it. thanks for helping, I've been searching almost every keyword into google and it just pissed me off when nothing came about except shopping pages. lol at how old this thread is and the immediate response to my question. :clapping: Yeah, the starter has to come out, sorry, I assumed that would be a given... sorry. And I didnt even notice how old the thread was... don't remember it either.
here's some "adult" tricycle action.... I use the term "adult" loosely. But pretty cool anyways.
The one for the ax5 is not a complete spacer plate, it only covers and bolts to the bottom half. I have one sitting here to look at, though I couldnt tell you right now if youd need to pull the trans to install it. First thing for you will be to find one, then look at everything real good to know if anything has to come out to install it. Edit: After looking at it closer, and putting it up against the trans bellhousing, I would have to say that you won't need to pull the trans. Looks like all its attaching points are seperate from the engine mounting bolts, should just slide in place and bolt up.
I bought another one.... The wife and I are thinking maybe to fix up and donate to her companies fall charity auction. This one is kinda funky too. It was made by Hedstrom in August of 1977.... still has the original build sticker on it, and original seat upholstery, but the axle is bent, and the pedal arm is bent. Looks like one kid may have used it, and it was then stored. Bought it at another antique store while I was at Mazda training in Atlanta, GA. here's the before pics... hopefully it won't be a whole year before I have after pics!
need help finding tie rod end
dasbulliwagen replied to COMANCHERED's topic in MJ Tech: Modification and Repairs
Get pics too of the steering knuckle, if its been swapped too that might be an issue as well. That will at least get us on the right track. :thumbsup: -
Keep it, look for an AX-15 to swap in, and do a bed bob if you like the short bed look, that is if you have enough fabrication skills. Just search bed bob here and youll get the idea. Then youll have what you want, the extra 6 inches or so of wheelbase won't make a difference then.
Yes, 97-06 TJ wrangler front axles are bolt in, just make sure you get the brakes with it too, as they will probably be different than what you currently have and not interchange. You might find a 4:10 in a dana 30 easier by looking at older Cherokees, like 84-86 with a manual.... the V6 5 speeds were 4:10, and the 4 cylinder 5 speeds were 4:10. Might be easier to find one of them, than to find a 4 cylinder manual TJ.
what is the better header for a 2.5
dasbulliwagen replied to cz777's topic in MJ Tech: Modification and Repairs
The 4.0 throttle body mod will only work if you have a 91 or newer port injected 2.5, and removing the cat won't make a difference in the 2.5 powerband. I have a gutted and sleeved cat, flowmaster muffler, removed engine fan and added electric fan, and a high flow air intake tube and filter, and have noticed small power gains with each of them. I have plans for a header in the future, and am hoping to get the Pacesetter. Id like to do a cam too, but finding one has been next to impossible. Mopar used to have one, but is no longer available, and theres a Canadian company outside of Vancouver that used to have a selection of them listed, but their website says they have been temporarily shut down for quite a while now. ......Just rechecked their site, its now back up, and they no longer list a cam for the AMC 2.5. :fs1: Might need to look at companies to do a custom grind. And don't listen to all of the naysayers in regard to 2.5 power mods. If the 2.5 is all you have to work with, then by all means do what you want to. Yes its true that a 4.0 will give you everything you want and more, but if its not feasable to have one installed, then do what you have to do, with what you got. But if you do modify the 2.5, just don't get your hopes up too much. Clifford has a 2.5 intake listed on their website, and Ive wondered about adding it and then modifying a 2bbl TBI injected throttle body from a GM v6 to it to work with the factory wiring and controls. I'm not sure though that the RENIX PCM would be able to have enough power output to control two injectors. The injector is controlled through on off times by the computer through inputs from the 02 sensor, and Throttle position sensor. I would think that if the computer could control both injectors, it would just cut back the on time to compensate for the additional fuel from the second injector to keep air fuel raio where it needs to be. That is assuming that all the sensor parameters between the two styles of throttle bodies are the same or similar. Ive yet to try this, but have been tossing it around in the back of my mind for a while now, and an initial look at the service info finds at least that the TPS voltages seem to be the same. Anyways.... good luck with whatever you come up with....let us know how it works out. -
Its not illegal to run witout doors, as long as you obey your local seatbelt laws.
I was unable to find a stock resevior for my conversion, so I adapted one from another vehicle and made a mounting bracket for it.
Nobody makes a kit because it is compltely unnecessary. The stock system does exactly the same thing, and is set up the same as an MSD system, as all modern engines are. You would only benefit from the MSD system if you were changing from a points system, or were building a buggy or truck from the ground up, and needed an easilly adaptable stand alone high energy ignition, for use with a carburator, or other stand alone fuel injection system. Just make sure your original parts are good, and thats all you need to be equivalent to the MSD system.
Vehicle Service Information Year/Model: 1990 JEEP CHEROKEE Last Odometer: 66,925 Miles on December 2, 1993 Body Style: XJJL72 In-Service Date: June 30, 1990 Engine: ERB-DESCRIPTION NOT AVAILABLE In-Service Odometer: 0 Miles Transmission: DGS-4-Speed Automatic AW4 Transmission Odometer Type: Miles Color 1: PX8-Black Clear Coat Car Line: S Color 2: QX8-Black Clear Coat Build Date: June 25, 1990 Current Market Register: U Hour: 06 Recall Information Incomplete Recall Recall Number 733 Description BRAKE PEDAL SHIFT INTERLOCK Part Number CFXT7334 Launch Date September 8, 1997 Complete Recall Recall Number 301T Description THROTTLE POSITION SENSOR Launch Date March 7, 1991 Repair Date June 14, 2004 Recall Number 561 Description OXYGEN SENSOR Launch Date November 8, 1993 Repair Date January 18, 1994 Vehicle Sale Information Selling Dealer: 23727 - CAIN'S, INCORPORATED Sales Type: 1 - DIRECT RETAIL City: MURRAY State/Province: KY Country: USA Telephone: (270)753-6448 Standard Equipment Code Description Code Description Code Description APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes CFMS Rear Fold w/Removable Cushion Seat CSRS Passenger Assist Handles DGSS 4-Speed Automatic AW4 Transmission DHSS Floor Mount Automatic Shift Lever DJHS Dana M30/181MM Front Axle DMDS 3.55 Rear Axle Ratio DRJS 175MM Rear Axle GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEDS Tinted Rr Drs/Qtr/Liftgate Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror JCAS 85 MPH Primary Speedometer JJAS Cigar Lighter K3ZS DESCRIPTION NOT AVAILABLE LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MB5S Black Rear Bumper MFFS Black Grille MMCS Upper Door Frame Moldings MMGS Belt Moldings MTAS Bright Liftgate Applique NAAS Federal Emissions NBKS EVAP Control System NFAS 20 Gallon Fuel Tank QX8S Black Clear Coat SBAS Power Steering SCBS 2-Spoke Steering Wheel SFAS Standard Duty Shock Absorbers SGAS Rear Shock Absorbers TBCS Compact Spare Tire TBLS Inside Mounted Spare Tire YAAS Build To U.S. Mkt. Specifications Z5AS GVW Rating - 4850# 1AAS U.S. Dealer Retail 154S Zone 54-St Louis 3YJS Wheel and Tire Discount Optional Equipment Code Description Code Description Code Description *X7 Cloth Low-Back Bucket Seats -SA DESCRIPTION NOT AVAILABLE AGGA Sport Group ALA SE Decor Group ALM Liberty Jet Group AWJ Visibility / Protection Group BAYP 105 Amp Alternator BCYP DESCRIPTION NOT AVAILABLE CACP Low Back Bucket Seats CDBP Reclining Front Seats CKAP Carpets - Floor and Cargo Area CKNP Cargo Compartment Carpet CKTP Cargo Tie Down Loops CSAA Spare Tire Cover CUFA Full Length Floor Console DGB All 4-Speed Automatic Transmissions DHP Selec-Trac Full Time 4WD System ERB DESCRIPTION NOT AVAILABLE GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZP Power Mirrors, Fold-Away HAA Air Conditioning JAYA Instrument Cluster w/Tach JGBP Digital Clock JHAP Var Intermittent Windshield Wipers KDKP DESCRIPTION NOT AVAILABLE MHAP Black Windshield Moldings MMKP Body Color Drip Trough Molding MWA Roof Rack NHM Speed Control PX8 Black Clear Coat RAAC All Radio Equipped Vehicles RAFA AM/FM Cassette Radio RCDP 4 Speakers TAAC All Tires TRNA P225/75R15 OWL Wrangler AT Tires WJHP 15X7 Aluminum Wheels WLZC All Aluminum Wheels YGGA 9 Additional Gallons of Gas Z01P Rear Spring Group I Z58P Left Front Spring Group Viii Z78P Right Front Spring Group VIII 4EA Sold Vehicle 4HC Special Scheduling Condition III 5KMA AMES Department Stores
ford 9" rear brake system
dasbulliwagen replied to comanche12's topic in MJ Tech: Modification and Repairs
You can add a brake line pressure lock inline to the rear brakes. You can get them through several different places such as Summit, or Jegs, places like that. You press the brake pedal, hit the line lock, and it will hold pressure in the brake line to hold the brakes until you relaese it. Just an option, though some people say this will cause premature seal damage to the calipers, might be worth it though if it is easier to make everything work. -
A good working OEM ignition will do just as good, though you might be able to add a hotter coil , but you probably won't notice any difference.
Vehicle Service Information Year/Model: 1995 JEEP CHEROKEE Last Odometer: 35,881 Miles on September 9, 1997 Body Style: XJTL74 In-Service Date: September 29, 1994 Engine: ERH-4.0L I6 Power Tech Engine In-Service Odometer: 2 Miles Transmission: DGS-4-Speed Automatic AW4 Transmission Odometer Type: Miles Color 1: PJN-Moss Green Pearl Coat Car Line: S Color 2: QS7-Dark Silver Metallic Clear Coat Build Date: August 15, 1994 Current Market Register: U Hour: 14 Recall Information Incomplete Recall Recall Number 733 Description BRAKE PEDAL SHIFT INTERLOCK Part Number CFL27332 Launch Date September 8, 1997 Complete Recall Recall Number639 Description DRIVER AIRBAG Launch Date April 21, 1995 Repair Date February 4, 1997 Vehicle Sale Information Selling Dealer: 23869 - CHUCK NASH JEEP EAGLE Sales Type: 1 - DIRECT RETAIL City: SAN MARCOS State/Province: TX Country: USA Telephone: (512)477-3236 Standard Equipment Code Description Code Description Code Description BGAS Power Front Disc/Rear Drum Brakes CFMS Rear Fold w/Removable Cushion Seat CGTS Driver Air Bag Only CKAS Carpets - Floor and Cargo Area CKNS Cargo Compartment Carpet CSRS Passenger Assist Handles DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DHSS Floor Mount Automatic Shift Lever DMDS 3.55 Rear Axle Ratio DRAS Corporate 8.25 Rear Axle GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass JCAS 85 MPH Primary Speedometer JJAS Cigar Lighter JJBS Dual Note Electric Horns K3DS DESCRIPTION NOT AVAILABLE LAJS Headlamps On Warning Chimes LBCS Glove Box Lamp LMAS Halogen Headlamps LPSS CHMSL Lamp MHAS Black Windshield Moldings MMCS Upper Door Frame Moldings MMGS Belt Moldings MMKS Body Color Drip Trough Molding MUKS Silver/Chrome Badging NAAS Federal Emissions NBKS EVAP Control System NFAS 20 Gallon Fuel Tank RDDS Fixed Long Mast Antenna SBAS Power Steering SDAS Normal Duty Suspension SHAS Front Stabilizer Bar SHCS Rear Stabilizer Bar TBCS Compact Spare Tire TBLS Inside Mounted Spare Tire YAAS Build To U.S. Mkt. Specifications Z1BS GVW Rating - 4600# 1AAS U.S. Dealer Retail 162S Zone 62-Houston 644S Texas State Code 944S Texas State Code Optional Equipment Code Description Code Description Code Description *R7 Cloth Low-Back Bucket Seats -SA DESCRIPTION NOT AVAILABLE ADAP Light Group AED Chrome Appearance Group APCP Center Band Two Tone Paint ARXP Country Decor Group AWH Power Equipment Group AWJP Visibility / Protection Group BARP 90 Amp Alternator BCDP 500 Amp Maintenance Free Battery CACP Low Back Bucket Seats CBZP Prem Vinyl Door Trim w/Map Pocket CDBP Reclining Front Seats CKTP Cargo Tie Down Loops CKVP MOPAR Third Row Cargo Bins w/Table CKWP Carpeted Liftgate Trim Panel CLCP Front Floor Mats CSAP Spare Tire Cover CUFP Full Length Floor Console CUN Overhead Console DGB All 4-Speed Automatic Transmissions EAAC All Engines ERH 4.0L I6 Power Tech Engine GAL Deep Tint Sunscreen Glass GNCP Sun Visors w/Illum Vanity Mirrors GRJP Left Power Chrome Mirror GSJP Right Power Chrome Mirror GTJP Power Mirrors GVBC All Vehicles W/Power Mirrors GXMP Remote Keyless Entry HAAP Air Conditioning HGDP Deluxe Insulation Group JAYP Instrument Cluster w/Tach JBGP Instrument Panel Woodgrain Bezel JHAP Var Intermittent Windshield Wipers JHBP Rear Window Wiper/Washer JPAP Power Windows JPBP Power Locks KCPP DESCRIPTION NOT AVAILABLE KSDP DESCRIPTION NOT AVAILABLE K4DP DESCRIPTION NOT AVAILABLE LBBP Courtesy Lamps LBDP Ash Tray Lamp LBEP Cigar Lighter LDAP Underhood Lamp LDBP Cargo Compartment Lamp LHDP Headlamp Off Time Delay MB3P Bright/Body Color Front Bumper MB7P Bright/Gray Mist Rear Bumper MCAP Front Bumper Guards MDAP Front License Plate Bracket MFMP Black/Bright Grille MNCP Bright Door Handles MWGP Roof Rack NHMP Speed Control PJN Moss Green Pearl Coat QS7P Dark Silver Metallic Clear Coat RAAC All Radio Equipped Vehicles RAFP AM/FM Cassette Radio RCDP 4 Speakers SCGP Leather Wrapped Steering Wheel SUAP Tilt Steering Column TRVP P225/70R15 Eagle GA OWL AS Tires TZAP Goodyear Brand Tires WJGP 15 Aluminum Wheels WLZC All Aluminum Wheels YGGA 9 Additional Gallons of Gas ZFHP Spring - Left Front ZFTP Spring - Left Rear ZUHP Spring - Right Front ZUTP Spring - Right Rear 2THA Customer Preferred Package 2TH 26H Customer Preferred Package 26H 3VUA Customer Preferred Discount Special Equipment Code Description Code Description Code Description No Special Equipment Available Dealer Installed Equipment Code Description Code Description Code Description No Dealer Installed Equipment Available
I had a set of free JK wrangler bumpers that I wanted to adapt to the MJ way back when, but even they are way too wide to fit and look right.
Yookohama Geolander AT/S is also good value for the money... go to www.tirerack.com , and you can look up your size and get track and customer reviews for most tires. I research all my purchases there before buying... even bought my last set from them, as it was, with shipping, from them was cheaper than getting them through the dealer I work for at emplyee discount.
CARS 2 from Disney PIXAR. I stumbles on the trailer for it tonight, and saw at least one Pacer, and one Gremlin.... who knows what else might be in the movie.... Though I'm sure they just featured those cars because of their reputation as wierd and or ugly.
I don't have a measurment, but I think it would hang over each end by almost a foot! Dem trucks is BIG
Did you say that you miss cable clutches???? REALLY??? In my experience I can't say that cable clutches are more reliable than hydraulic. Ive had too many cables break to make a call like that, but as I think about it, if youre on the trail, and it breaks, might be easier to repair one of those than a hydraulic fault. I guess if thats what youre going for, that might be better.
maybe it's me... now: one step forward, two steps back...
dasbulliwagen replied to Pete M's topic in The Pub
I thought about doing this on my Hyundai Tucson, but chickened out, as the car is still too new, though I did mount a set of Yokohama Geolander AT's in stock size. Maybe next time.... after the warranty lapses.
