Pants
Pants's Achievements
  1. That was one of the main reasons why. If It breaks I can use a set of vice grips and washers to get me going... yes. I deserve that one.
  2. I originally started to post this on my local forum, but I remembered the great minds and how much time I spend reading over here... www.jeepkings.ca/forums/showthread.php? ... he-on-tons -- original thread I'll post the major cliff notes and what pictures I have access to right now Comanche 90’s 4.0l Wheeled the snot out of it for a few years stock on 31” Baja Claws Motor was knocking so I parked it almost 2 years ago and got a new truck Collected and “seasoned” most parts over the years and figured it’s finally time to actually do something. Plans 4.7l stroker Fuel -- Propane Pistons -- IC945 .040 over Crank -- 12cw Cam -- COMP 68-232-4 Lifters -- COMP Rods -- 4.0L Oil Pump -- Hi vol melling Lifters – stock Push Rods -- ??? Head Gasket -- ??? 0.043 Timing Chain – Comp COC3127 Cubic Inches: 281.33 Liters: 4.61 Static Compression Ratio: 10.89:1 Dynamic Compression Ratio: 9.32:1 Quench: .043 Intake Valve Closing Angle: 55 Sm465 np231 / d300 doubler D60 front 14b rear Brace / reinforce frame Skid plates Bumpers Keeping bed / tailgate I’ll figure out tires as I get there leafs in rear possibly leafs in the front or may do long arm, still reading on how best to accomplish Started tearing apart drive lines and working on getting my own together 4.7L (stroked 4.0L) SM465 231 / D300 doubler After some reading it looks like the SM465 shares the same size and spline input shaft minus 1" of the stick out. easy enough The bell housing just needs to be marked and drilled BUT I need one from a 1980 - 1986 CJ and the throwout arm. Dang, Off to search I do think Its pretty sweet that I get to go back to cable clutch though... I do miss it over hydraulic. I did see the conversion kits, from full hydraulic throwout bearings to hydraulic slave retro fits, If anyone has any input on this please let me know. There is also the bearing retainer to be modified, but I can ask around to see who has a machine shop I can borrow. and now, PICTURE OVERLOAD!!!!! ..... or not.....
