cz777
cz777's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. thank you you all .....jeep and me are best friends .....its rough when she goes down
  2. OUCH !!!
  3. cz777
    bad day !
    for some time now all was good with MJ ! Monday last week a big puff of white smoke came out exhaust pipe .....what the heck now ??/ pull head off and clean up things found between 2/3 head gasket was char out -still in shape ,the worst part was #2 piston has a hole right to the top ring with groove on cylinder wall -all in same area showing broken ring etc well at 270,000 miles ok overhaul time ......wow MJ is one tough old girl .......on the lighter side of things rob who sold her to me in '06 ....said this to me .....if you get sick or jeep breaks down, which one will gets it next ?you two are too alike .... last year i was out of commission due to two heart attacks and gull blatter infection ,she sat up for almost 6 months.... now MJ is sick... damn strange .......one for the book now !!!
  4. i am dumping all the bolts to studs[grade 8] high heat steel with brass nuts with holding washers ........other thing is the use of copper rtv very thin on the gasket .....
  5. i have been down since june because 2 heart attacks and emergency gull blatter removal .......So poor MJ has been sit up ....and she is real pissed off a bad water pump and water found in #3 on the plug .....and water in the oil aka milk shake of doom .....well damn !!!
  6. well i need front brake discs and pads for my MJ ...she is a '89 2 wheel ...where and who to het on brkaes etc ....Thank You All
  7. i went with #40 ...and got a pacesetter header too now this is a lot nicer sound not so load ....works well but cleaned off the paint and used 2000* paint for two months now staying well painted black
  8. a word to note stay from all advance ...this is crap http://shop.advanceautoparts.com/p/perfection-clutch-technovation-clutch-master-cylinder-39645/3655105-P?searchTerm=clutch+master so please don't buy ..it will leak !!
  9. ok but which brand of Clutch Master Cylinder best ....or stores sells the best ??
  10. maybe flow is not good ...welding on flanges inside ''leaking '' and o2 maybe bad
  11. The three puller holes were completely plugged with dirt and grime, had to be first found because it was not obvious they were even there, then chased with a Tap to clean them out. i put flanged bolts in with anti-seize .....just to keep them clean for pulling
  12. well i had other Critters had overheat troubles, water pump can have bad impellers like rusted apart /falling apart etc bad radiator plugged up /bad cap /bad hoses coolant bring bad .. .....its a flow pattern follow the flow from radiator to engine and back
  13. holy spaghetti ....and the fun starts ......
  14. i believe to build for the worst case, no matter what ! the pay back is in the longer life ,now add in the kind of grease bringing used as well ...the care of your parts too ....just the moog for me .....
  15. forget the rest, Bosch pumps are the best hands down ...costly but work great http://shop.advanceautoparts.com/p/bosch-electrical-fuel-pump-kit-69302/20770761-P?navigationPath=L1*14932%7CL2*14986%7CL3*15378 i have pull a few of china made crap out for this kit ......look and see if this will work for you
