dasbulliwagen
    3
  1. I agree on the pricing, that if it is truly more of a compact pickup, it should be priced as such.... but knowing Chrysler, and knowing how Jeeps are priced, I pretty much know that this will not happen. And that is what will keep sales low, and what will make Chrysler think that there is no market for such a vehicle. If built it will probably have the 3.8 as they are trying to run out their contract for building that engine so that they can do away with it and put in the new Pentastar engine.... and if tuned like the one Ive driven in the new Grand Cherokee.... its gutless below 3000rpm.... will make it worthless for the trail anyways. So its probably doomed from the start.
  2. Everything will bolt over with a few little mods, but the seat mounts are different. If you have buckets already, the new XJ seats should be able to mount to your MJ seat frames, but if you have a bench it will be a bit more difficult.... but not impossible. The dash harness and HVAC housing will also have to be swapped, and youll need to modify the wiring for the tailights, also need to figure out the fuel sender as the newer ones are backwards of the older ones, and I'm not sure about the pump pressure... you might be OK there. I'm assuming your MJ is a 4.0 already, but if not, then youll also need to swap over the radiator core support assy. And youll want to take advantage of the dual booster brakes and swap out the master/booster assy too. A lot of work, but doable. Good luck!
  3. Why not use an MJ bench?
  4. This would be cool, but I like the Nukizer concept better.... more of a real truck.
  5. I put a whole set of ones that would have gone on a YJ wrangler. The fronts are a lot longer, and the rear is longer too, though maybe not as long as one from a durango. Good luck.
  6. Or you can just ignore it... been that way it whole life! :thumbsup:
  7. In 86 the 2.8 was offered with an auto column shift factory, and all auto column shift trucks got the plate put in the floor factory. The auto in 1986 on the 2.8 should be the A904 or TF904.... basically a lighter duty version of the TF727 that chrysler has used extensively. And it could be either a 2x4 or a 4x4. You might want to look at the rear axle too to see if its a dana 35 or the much sought after corporate 20 which would mean its a metric tonne model. If 4x4 I'm not sure what transfer case would have been put behind the auto. The one on my 86 waggy 2.8 auto is the NP228 selec-trac, but I'm pretty sure they never offered that option on the MJ's. Looks like a nice find, keep us updated!
  8. Re ran the VIN with the 74 instead of 24 and it now works. The code descriptions arent there, but Ill put them up for you anyways... maybe you can get them decoded. Vehicle Sale Information Selling Dealer: 23820 - CLOVERLEAF CHRYSLER DODGE JEEP Sales Type: 1 - DIRECT RETAIL City: DECATUR State/Province: AL Country: USA Telephone: (256)350-3071 Recall Information Incomplete Recall - No Incomplete Recall Information Available Complete Recall Recall Number 561 Description OXYGEN SENSOR Launch Date November 8, 1993 Repair Date July 15, 1994 Vehicle Service Information Year/Model: 1988 DESC NOT FOUND Last Odometer: 0 Miles on Body Style: MJTM61 In-Service Date: Engine: ERB-DESCRIPTION NOT AVAILABLE In-Service Odometer: 0 Miles Transmission: DDJ-DESCRIPTION NOT AVAILABLE Odometer Type: Miles Color 1: PX6-DESCRIPTION NOT AVAILABLE Car Line: XX Color 2: QX6-DESCRIPTION NOT AVAILABLE Build Date: July 11, 1988 Current Market Register: Hour: 24 Book: X Last Known Owner lived in Arab, AL Standard Equipment Code Description Code Description Code Description No Standard Equipment Option Available Optional Equipment Code Description Code Description Code Description *X1 DESCRIPTION NOT AVAILABLE -SA DESCRIPTION NOT AVAILABLE AGJ DESCRIPTION NOT AVAILABLE APA DESCRIPTION NOT AVAILABLE BCQ DESCRIPTION NOT AVAILABLE CBA DESCRIPTION NOT AVAILABLE CGX DESCRIPTION NOT AVAILABLE CKA DESCRIPTION NOT AVAILABLE DDJ DESCRIPTION NOT AVAILABLE ERB DESCRIPTION NOT AVAILABLE GAC DESCRIPTION NOT AVAILABLE GFD DESCRIPTION NOT AVAILABLE GSC DESCRIPTION NOT AVAILABLE HAA DESCRIPTION NOT AVAILABLE JHA DESCRIPTION NOT AVAILABLE JJA DESCRIPTION NOT AVAILABLE K60 DESCRIPTION NOT AVAILABLE LAP DESCRIPTION NOT AVAILABLE LMA DESCRIPTION NOT AVAILABLE MBJ DESCRIPTION NOT AVAILABLE MDA DESCRIPTION NOT AVAILABLE NAA DESCRIPTION NOT AVAILABLE NHQ DESCRIPTION NOT AVAILABLE PX6 DESCRIPTION NOT AVAILABLE QX6 DESCRIPTION NOT AVAILABLE RAB DESCRIPTION NOT AVAILABLE SBA DESCRIPTION NOT AVAILABLE SCE DESCRIPTION NOT AVAILABLE TBG DESCRIPTION NOT AVAILABLE WJD DESCRIPTION NOT AVAILABLE 3LX DESCRIPTION NOT AVAILABLE Special Equipment Code Description Code Description Code Description No Special Equipment Available Dealer Installed Equipment Code Description Code Description Code Description No Dealer Installed Equipment Available
  9. JK wrangler ones will, same diam and similar length, but probably stiffer due to being in a heavier vehicle.
  10. Do one or two more burnouts and you can get rid of your Puegot BA-10/5 transmission weather you want to or not. You might want to start keeping an eye out for an AX-15 to replace it sooner rather than later.
  11. Sorry. Must be that Chrysler thinks that your jeep doesnt exist. They have the VIN to my 87, but no build info, can't beleive they don't show yours. There is a site through Chrysler that you can email for a build sheet, but I think they go to the same VIN check that I do. Maybe someone here has a link. Might be worth a try.
  12. The "J" would make it an 88, but after studying the last 6 of the VIN, the serial number part... none of the ones on the registry go over 219000. So I'm wondering if the 4 needs to be a 1???
  13. Re check the VIN, its coming up as not found..... yes I can still get a build for it, even though some of the codes have changed, it will give you a real good idea.
  14. What is the approximate milage?
  15. Arcs like sparking? Electrically, or like metal to metal contact casuing a spark from friction? Sounds weird!
  16. dasbulliwagen
    New guy
    Or you can Waggy your MJ to make a matched set....like mine!
  17. dasbulliwagen
    New guy
    31"s will fit with no lift, and rub on the lower control arms, but if you replace them with WJ Grand Cherokee lower control arms you will do away with that problem, they are also stronger peices. But a 2" front spring spacer, and maybe some Chevy drop shackles for the rear springs and youll be right where you want to be. Nice truck, and nice waggy. Keep us updated!
  18. This article was just posted today at www.allpar.com telling of a dealer meeting showing upcoming vehicles. Pay special attention to the LAST paragraph. http://www.allpar.com/news/index.php/20 ... to-dealers Two Allpar readers at the national dealer meeting reported on the cars shown: The big news is the new Dodge Viper, driven in to the amazement of everyone there. It is apparently a big styling change and people raved about it. The looks are more upscale, and word is that the product committee took just five minutes to unanimously approve the car. The Chrysler 300 was shown, and is as beautiful as they claim. They claim to have spent $1 billion dollars on the development and used the BMW 5-series (starting at $44,000) as a benchmark. The interior is incredibly impressive, with hand-sanded wood accents. With the optional eight-speed automatic, it can get 30 mpg. The Chrysler 200 looks good overall and is a vast improvement over the Sebring. The pillars are all that remain the same. With the six-speed dual-clutch automatic, engineered by both Chrysler and Fiat (both had dual-clutch designs at the time of the deal), it reportedly hits 29 mpg. The Chrysler 200 will see showrooms in November. The minivan looks even better in person, and the interior is truly impressive especially on the Limited. The Dodge Caravan has also been greatly improved inside, with a sportier exterior; the suspension has reportedly been tuned for a more sporty feel (as in years before 2008), and the “man van” has been confirmed as a limited edition version. The Dodge Challenger V6 is rated at 305 horsepower, (as at least one other web site reported). The 6.4 liter Hemi will be called the 392, as previously reported The Dodge Charger was shown and it is a vast improvement, especially the interior. The Ram 3500 Longhorn package was impressive in luxury and had a badge in the floor mat that could be worn as a belt buckle. It will appear at the Texas State Fair soon. The Ram 2500 and 3500 will have RamBox optional next year. The new Dodge Journey was shown, with one of the best looking interiors there; even Ralph Gilles was gushing about it. Dodge Avenger, is an Avenger. New powertrain, basically, with most of the changes going into the Chrysler 200. They showed the new small Dodge pickup truck (possibly still called Dakota). Jeep Compass really does look like a baby Grand Cherokee. At the end of the Jeep show, Mike Manley started to leave but (in a Steve Jobs-like move) a door opened and a Jeep pickup truck drove in. It was similar to the Jeep Gladiator concept, big tire on the side and all. Manley shrugged, said, “Hey, you never know,” and walked off.
  19. Technically I think thats called a heads up display. Our Jeeps were way ahead of their time you know!
  20. Youd better run this by Pete! After all he is the owner. But a shirt would be cool!
  21. Pass me some of what youve been smokin! :chillin:
  22. Before winter I will be buying a set of the Geolander A/T's for my Hyundai Tuscon. Ive always had good luck with Yokohamas. They are always rated real good too... especially for the price. If the Yoks work out good, I may consider them as the next set for the MJ.
  23. Besides being a Chry Jeep Dodge dealer, we are also a Mazda dealer, of which I am recently certified.... anyways, the Mazda version of the Escape is the Tribute. We have several that come through the dealer on a regular basis, and I havent noticed any major issues with them. 99% of them are 3.0 V6 autos, and yeah the interior seems cheapy, but if I had to take one and rely on it I would.
  24. Sounds pretty good..... can't go wrong with BFG AT's. I have them on mine (because they were free) and have had good wear and theyre staying pretty quiet. Many will say they arent that great but thats not my experience.
  25. http://www.tirerack.com/tires/TireSearc ... 5&x=80&y=9
