SouthShore440
SouthShore440's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. I have the seat tracks if you need
  2. I have the bucket seat tracks if you need
  3. They are out there...i sold one compete for 400.....still have the drive shaft for swb if you need
  4. I have this part if you still need
  5. Check to see if your balancer is hitting the fan. I had similar symptoms.....
  6. For that kind of money you can put a 9inch under it.
  7. I have a real nice set...pm me your email and I will get you pics. 75 plus ship
  8. I have the tail light in fair_good condition. 30 each plus 15shipping for one or both
  9. Rock auto....get it new they are cheap
  10. I went with the dorman balancer from auto zone with tax it was 45 and lifetime warrantee. No issues so far but I was skeptical of the china quality. what have you read?
  11. Or in my case go forward and hit the fan making an awesome clanging noise
  12. Pp Agreed, except I wish I got to it when it looked like that...in my case the center hub was free from the rubber ring and the outer part was moving back and forth about a quarter of an inch
  13. Seal is press fit and if you do it right you don't even touch the cover when you install it. Plus seals wear out so this is worth the effort to replace while is all apart. If the truck makes it to 200k ill do the chain....right now it just needs to make it to the train station
  14. ? clutch ... no bleeding required, just pump it up. its not like your brake system.
  15. ? clutch ... no bleeding required, just pump it up. its not like your brake system.
