dasbulliwagen
    3
  1. Legally pete, but stored and repaired at Correy's... sounds good.
  2. First thing I did was the PS swap. I didnt notice any power drain at all. I noticed a touch of gain with the cold air tube, and a touch of gain with the electric fan, and a lot with the 4:10 gears, but when the AC compressor kicks in you notice a momentary drag on the engine and then back to normal... don't worry about a PS drain, it really only pulls a lot of power when you are turning at slower speeds, going straight it don't matter at all. If you do notice anything, it won't matter because youll be soo happy you don't have to force the wheel anymore!
  3. Search online for chemical supply companies... thats what the Mythbusters do. I have no idea where they found the humungous amount of cornstarch they used that one time, but I think they just searched online.
  4. Sorry, Chrysler don't have much info on the 87 models, you might be able to look up the codes somwhere else. 23583 - LOU'S JEEP-EAGLE INC Sales Type: 1 - DIRECT RETAIL City: GENEVA State/Province: IL Country: USA Telephone: (630)232-4016 Year/Model: 1987 DESC NOT FOUND Last Odometer: 0 Miles on Body Style: MJJL62 In-Service Date: Engine: ERB-DESCRIPTION NOT AVAILABLE In-Service Odometer: 0 Miles Transmission: DGQ-DESCRIPTION NOT AVAILABLE Odometer Type: Miles Color 1: PXF-DESCRIPTION NOT AVAILABLE Car Line: XX Color 2: QXF-DESCRIPTION NOT AVAILABLE Build Date: May 20, 1987 Current Market Register: Hour: 24 *X8 DESCRIPTION NOT AVAILABLE - Q8 DESCRIPTION NOT AVAILABLE AHL DESCRIPTION NOT AVAILABLE APA DESCRIPTION NOT AVAILABLE CAC DESCRIPTION NOT AVAILABLE CGW DESCRIPTION NOT AVAILABLE CKA DESCRIPTION NOT AVAILABLE CLE DESCRIPTION NOT AVAILABLE CUF DESCRIPTION NOT AVAILABLE DGQ DESCRIPTION NOT AVAILABLE DMR DESCRIPTION NOT AVAILABLE ERB DESCRIPTION NOT AVAILABLE GAC DESCRIPTION NOT AVAILABLE GEC DESCRIPTION NOT AVAILABLE GFD DESCRIPTION NOT AVAILABLE GSC DESCRIPTION NOT AVAILABLE HCC DESCRIPTION NOT AVAILABLE JHA DESCRIPTION NOT AVAILABLE JJA DESCRIPTION NOT AVAILABLE LMA DESCRIPTION NOT AVAILABLE MBJ DESCRIPTION NOT AVAILABLE MDA DESCRIPTION NOT AVAILABLE NAA DESCRIPTION NOT AVAILABLE NFA DESCRIPTION NOT AVAILABLE NHM DESCRIPTION NOT AVAILABLE PXF DESCRIPTION NOT AVAILABLE QXF DESCRIPTION NOT AVAILABLE SBA DESCRIPTION NOT AVAILABLE TBB DESCRIPTION NOT AVAILABLE WJD DESCRIPTION NOT AVAILABLE XEA DESCRIPTION NOT AVAILABLE Z1B DESCRIPTION NOT AVAILABLE Special Equipment Code Description Code Description Code Description No Special Equipment Available Dealer Installed Equipment Code Description Code Description Code Description No Dealer Installed Equipment Available
  5. A search on car-part.com the other day showed me to find that 87-89 had 4:56 available... didnt see any of them on any other years. But that don't mean it didnt happen!
  6. Is that 3:56 gears, or 4:56 gears???
  7. If this truck is not what you were expecting, then get rid of it.... meaning sell it to someone who does think its worth it.... and get something else, because frankly, I'm tired of hearing you say youre going to scrap it. Youre obviously not happy with it and I don't think you ever will be. You havent had it that long either... not much time to fix it up to give it that wow factor youre looking for. Ive had mine almost three years now starting out with a $250 truck that was caked with an inch of tree sap and ran like crap. But after three years and not much if any of a budget, it is getting to that point. You can't expect miracles, especially if you can't spend much money on it. You have the first step beat... getting it running good. Now its time to add your personal touch to it by fixing it up cosmetically and making upgrades... just don't get pissed about it if it don't happen overnight! After three years I have mine running good, Ive made a few upgrades, and have more on the backburner. I got it running good first, and justdrove it for a while till I discovered this site... since then Ive bought a second Comanche parts truck with 5 speed trans and 4:10 gears and 4x4... which is all getting swapped into mine, Ive added cold air intake, flowmaster exhaust, electric cooling fan, Ive added a Waggoneer grille, and have ready to install power window and lock doors with movable vent windows. I also swapped the power steering and AC from the donor truck, made custom rear bumper brackets to install a cherokee rear bumper, and I'm in the process of making a rear hitch for it. There are a million things you can do to make it your own if you want to. Just quit bitchin about it or sell it to someone who treat it the way it deserves!
  8. Ill take one in a 7 7/8 or 8 please!
  9. Chrysler says build date April 7th, 1992. Originally sold at KERN MOTOR COMPANY INC City: WINCHESTER, VA In service date of April 27th, 1992 Options: APAS Monotone Paint BAPS 75 Amp Alternator BCCS 430 Amp Maintenance Free Battery BGAS Power Front Disc/Rear Drum Brakes DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DHNS Command-Trac Part Time 4WD System DJHS Dana M30/181MM Front Axle DMDS 3.55 Rear Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass HCDS Heater w/Instrument Pnl Ventilation JAZS Analog Instrument Cluster JCAS 85 MPH Primary Speedometer KWRS DESCRIPTION NOT AVAILABLE K3ZS DESCRIPTION NOT AVAILABLE LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MMCS Upper Door Frame Moldings MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF5S DESCRIPTION NOT AVAILABLE QW7S Bright White Clear Coat SBAS Power Rack and Pinion Steering SFAS Standard Duty Shock Absorbers SGAS Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 135S Zone 35-Washington Optional Equipment Code Description Code Description Code Description *C1 DESCRIPTION NOT AVAILABLE - H9 DESCRIPTION NOT AVAILABLE ALAP SE Decor Group CBAP Straight Back Bench Seat CKAP Carpets - Floor and Cargo Area DGB All 4-Speed Automatic Transmissions DHTP Elec,Shift-on-the-Fly,P/Time T/Case ERH 4.0L I6 Power Tech Engine GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZP Manual Remote Mirrors JHAP Var Intermittent Windshield Wipers JJAP Cigar Lighter KERP DESCRIPTION NOT AVAILABLE MBJP Black Front Bumper MDAP Front License Plate Bracket MHAP Black Windshield Moldings MMKP Body Color Drip Trough Molding PW7 Bright White Clear Coat RAAC All Radio Equipped Vehicles RAFP AM/FM Cassette Radio RCDP 4 Speakers SCGP Leather Wrapped Steering Wheel TMWP P215/75R15 OWL All Terrain Tires TZAP Goodyear Brand Tires WJNP 15 Aluminum Wheels WLZC All Aluminum Wheels YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z66P Left Front Group XV Z85P Right Front Spring Group XIV 2TCA Customer Preferred Package 2TC 26C Customer Preferred Package 26C 3VNA Customer Preferred Discount 4EA Sold Vehicle 4HA Special Scheduling Condition I 4M1P Retail to Bid Diversion Tracking 4UA SCA Tissue North America LLC Special Equipment Code Description Code Description Code Description No Special Equipment Available Dealer Installed Equipment Code Description Code Description Code Description No Dealer Installed Equipment Available
  10. What do you mean "When TV's came out?" Theyve been around forever havent they? :hmm:
  11. I wish I could do that, but the dealer near me closed. The next closest is about 45 mins away and they close during the week before I can get there. Credit cards will take care of that.... Call, pay and have them leave it outside where you can get it!!! CW Sales dept stays late every day, have the parts guy leave it with sales manager, and pick it up from them after parts hours!
  12. Good trade for a running truck! Once you get it home, go over everything, cap, rotor, plugs, wires, good gas..... youll be suprised what a difference they can make. Mine was like that when I got it... had been basically sitting for 4 years, but the owner started it every week and made sure it was still running, but it ran like crap after sitting that long and neglected, wouldnt idle. I tuned it up, put good gas in it, and I got it to idle and started driving it, the more I drove it the better it ran, up to a point, it would still buck and miss quite a bit, so then I replaced the O2 sensor and its run perfectly ever since. That engine is just about indestructable, so check it over and I'm sure youll be fine.
  13. If you order from the dealer before 2 pm, you can usually have them next day at the dealer. NO SHIPPING COST!
  14. Ive done a bunch of those mods on my 2.5 already... the cold air intake, electric fan, gutted cat converter, and a flowmaster 50 series muffler. I have an extra 2.5 that I plan to rebuild with ported head, cam, and a header, I'm not sure on the intake yet as I don't know if I want to stay with the injection or go with the clifford intake and put on a 390 cfm holley 4 barrel. Ive been wondering though lately if a 2bbl injector from chevy pickup could be modified on to the clifford intake and tied into the factory harness..... I have some research to do! There a few of us 2.5 lovers on here, so don't get too discouraged by all the yelling voices that say to swap a 4.0. Good luck!
  15. Yeah JBHILL... he's still working on it.
  16. Seems like just about every Cherokee I see around here that has ANY kind of lift is dogtracking really bad.... looks stupid to me. They all need an adjustable track bar and professional alignment, which most of these guys just don't do because all they want is the lift right off and don't think it all through to make it right. And most adjustable bars Ive seen only have the adjustment on one end, so the bar needs to be taken loose in order to adjust it, theyre not usually like a tie rod where you loosen the adjuster and then turn it. It would be nice if they were, but they probably wouldnt be as strong that way.
  17. The new Patriots and Compass, caliber have rims that are the right bolt pattern too. and the current libbys and Nitros too.
  18. You can buy anything that isnt the engine or complete vehicle, that means you can buy the bed, trans, axles or anything else, you just can't buy it whole and re title it, or buy the engine.
  19. 05 and newer Chrysler 300, Dodge Magnum, Charger and Challenger have 17" steel wheels and the cop cars have 18" steel wheels that really arent bad looking if you can find them. The 17", 18", 20" are also available in aluminums, but like the other guy said, check the backspacing, I know that the lugs and the hub centers are right, but I'm not sure about the backspacing. There was a set of 17" steelies sitting here at work for awhile and I put one up to my Comanche parts truck while the wheels were off to just see if it would bolt up but didnt think to look at the inner clearance. I think another employee made them disappear before he quit to put on his Ford Galaxie. Id like to have a set of the 18" cop wheels for my 86 build when and if I ever get around to it...
  20. I don't care for the idea of DBW either, but being a current Chysler tech, Ive yet to see any problems ... at least with the Chrysler systems, and have only seen 2, in 4 years of working with them, that have failed in safe mode. They are installing them to keep throttle opening and closing speeds at levels that the computer system can keep up with to control emissions. Thats the same reason they want to do away with manual transmissions too. There is already too much of that happening already with the ever growing laziness of the american public. Dealers just don't want to carry manuals because they sit on the lot too long before being sold. Its just sad. :(
  21. Looks like a Challenger with a slightly different nose and a fastback.... wouldnt be much of a stretch to build one... though I don't see it happening...... Wasnt that an April fools article from hot rod last year?
  22. WOW! I hate it when that happens. Looks like his Last visited: Mon Jan 11, 2010 10:46 pm Maybe he'll update us if he catches it.
  23. Yes 4cyl auto from 87 to 89.... at least thats what I found on www.car-part.com . There is only a handful of them around the country... at least with those that list on that website. Price from $250 to $400. There were others listed there too that I'm pretty sure werent 4:56 geared though so youll have to call the yard to confirm anything. Good luck!
