manimal
manimal's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. did anyone get the rear dana 44 from the one at ecology?
  2. There is a 1987 Comanche @ Ecology on Santa Ana and Riverside Dr. in Colton w/ a Dana 44 non LS. Saw it there this morning.
  3. THANK YOU! Got it all taken out and the XJ prop valve back in. Thanks again
  4. I have read MANY threads on the rear load sensing valve. I am unclear as to which line I can leave/use,and which to remove to eliminate the valve. I am installing an XJ prop valve in place of the distribution block, and want to get rid of the NON functioning load sensing valve. My brake lines are in GREAT shape so I don't feel I need to run a NEW line. Thanks
  5. Well, I have decided to sell it to get a Grand Wagoneer(FSJ). Actually it's one that I previously owned. So I can take my whole family out. Check out the classifieds..great deal for someone!
  6. Cool, thank you very much. Looks like I will be building a new headlight harness and using the existing wires as triggers. Thanks again -Lance
  7. manimal
    nice jeep ad
    http://www.youtube.com/watch?v=ImHMpnKL ... re=related :D :banana:
  8. I am getting ready to wire in headlight relays and was wondering if anyone knows the gage wire the headlights are? Thanks BTW I have looked at an FSM and it does not list it. Thanks -Lance
  9. My thoughts exactly! I was thinking of using 31x10.5x15 on 15x8 US slot mags when I convert my 2wd to 4wd.
  10. Anyone here running old aluminum slot mags? If so can you post up pics? Thanks
  11. Well, it's on the road. Got it smogged and registered today! I had the head rebuilt,new injector,fuel pump sock. Purrs like a sewing machine now! Plans are to convert it to 4x4,just need to know what trans will bolt up to the 2.5. I want to stay with the manual trans for ease of install. Then I will put in a FORD 8.8 disc brake rear axle w/4.11's and build a D30 to match. I LOVE this truck. BTW, the interior is dark blue.
  12. Well, it turned out to be a bad ground. I put a new sock on it and it works perfect. Thanks for the help. -Lance
  13. Ok, I replaced my injector with a new one. I pulled the fuel pump out and found the rubber grommets around the pump were all gummy. Where is the best place to get a pump with all the right rubber grommets? Thanks -Lance I have done some searching,but have not found the info I am looking for. Thanks again. BTW It's and '88 MJ 2.5 TBI,4spd 2wd.
  14. I just found this guy on the internet. I was looking for an injector for my 88 MJ 2.5 TBI. His price for a NEW injector was 49.99! Check him out.http://www.injectors4u.com/fuel_injectors.htm
