114
Everything posted by Pete M
found a list of junkyard upgrades :)
Pete M replied to Pete M's topic in MJ Tech: Modification and Repairs
that's a tough question to answer since it would vary wildly depending on spring sag. MJs are spring-under and so the leafs have plenty of arch. XJs are spring-over and so their leafs are more or less flat. tired XJ examples can actually be inverted a bit. If I remember right, MJ leafs can give about 3" of lift to an XJ, so I guess the reverse would drop the MJ by the same. Rangers are spring-over. I wonder how flat their packs are... -
I'm sure something will happen this summer.
well, XJ leafs will lower an MJ. (I would retain that main leaf though) -
In my head I was picturing a map, like our new locations google map, but with markers of people who like to meet up and then different markers with who could actually host an event (this could be their actual place if they don't mind 10 trucks all showing up at once or a local place to meet up, like a car show or offroad park). just brain stormin' at the moment. nothing concrete yet.
oh, hell ya that would be awesome! the year it came out we still had a dollar theater in our town. saw it like every day that summer
Original list is here: https://www.jeepforum.com/forum/f11/budget-builds-what-junkyard-parts-will-fit-xj-847303/ it's an XJ list, so keep that in mind. Suspension & Lift: -Front End: 1.ZJ V8 Upcountry Coils = 1-1.5" lift 2.F-150/Bronco Coils ('70s-ish) = 4-4.5" lift 3.Camaro Spring Isolators = 1.5" lift 4.ZJ spring isolators = stronger, metal core, can be stacked 5.Thunderbird Front Coils ('83-97) = 3-4" lift (varies in lift and softness by year and trim package), will need top plate from strut too 6.TJ Lift Coils (front only) = provide 1" less lift on an XJ than on a TJ -Rear End: 1.Bastard Pack: Any 2.5" wide leaf spring can be used between to make a bastard pack (they may differ in stiffness and lift) i.e. S10, Dakota 2.MJ Shackles = 1/2" lift 3.GM fullsize pickup shackles ('95-99) = 1.5" lift, better shackle angle -Misc: 1.JK shocks = slight mod to fit 2-4" lift (must be from JK Rubicon, BPEs are not required, you need to press out the metal sleeves from the JK shocks, and insert the XJ stock bar pins to the axle-side part of the front shocks, and the body-side of the rear shocks.) 2.S10 Shocks (Rear only) = good for the lift you will get when you do a bastard pack 3.Ford Exploder rear sway-bar links = may be good for 3-4" lift 4.WJ rear sway bar end-links = minor fab to fit 3-4" lift 5.WJ LCA's = more tire clearance (some grinding required) 6.WJ rear LCA's = replace XJ front LCA's, 2" longer to accommodate a lift, some grinding required 7.V8 ZJ front sway-bar 8.JK rear UCA = use as XJ LCA, its about 1-2" longer 9.Ford Bronco II (that's the little one like a ranger) Front Swaybar = good for 3-4" lift Brakes: -Booster, MC, etc: 1.WJ brake booster, master cylinder, proportioning valve 2.ZJ brake booster, master cylinder, proportioning valve = may need for disc conversion 3.XJ '95+ brake booster and master cylinder = dual diaphragm, larger bore 4.WJ Rotors/Calipers = bigger brakes and more stopping power (will fit 15" rims) 5.KJ disc brake set-ups can be used for a conversion on your XJ axle -Lines: 1.YJ Brake Lines = 3-4" longer 2.Dakota Rear Softlines ('87-96) = 6" longer 3.GM C/K1500 Front Softlines ('90-95) = 6" longer 4.Dodge Ram Van Brake Lines = 10-12" longer (for big lifts), some dispute 5.5.JK Front Brake Lines = bolt-in and long (can max out 12" shocks and still have slack) Axles: -Bolt-in Swap: 1.XJ C8.25 Rear ('97+) = bolt in and upgrades to 29 spline (strength comparable to D44) 2.XJ D44 Rear = found in some but not all '87-'89 XJ's with Towing Package 3.XJ D30 Front = ('95-'99) non-disconnect, larger u-joints, high pinion 4.XJ I-4 & some V6 = may have 3.73, 4.10, or 4.56 gears may have vacuum discos -Moderate Fab to Fit: 1.Ford 8.8 inch Rear ('97+) = need spring & shock mounts (3.55, 3.73, or 4.10, maybe LSD, Disc Brakes) 2.MJ D44 Rear = need new spring perches and shock mounts 3.MJ AMC 20 Rear = need spring perches and shock mounts 4.Ford HP44/9" Combo = full width, more intense fab -Misc: 1.Lincoln Lockers = welded spider gears, operates like a spool, must be a GOOD welder 2.G80 LSD locker from '90s Turbo Volvo with D30 rear for XJ front D30 (beware with larger tires) 3.Homebrew posi-locks for '84-90 vacuum disconnect D30s, eliminates vacuum actuation 4. ZJ D30 CV shafts can be used in place of XJ u-joint shafts in '92+ D30's Steering: 1.ZJ V8 Tierods = beefier & bolt in 2.WJ Knuckles/Tierods/Draglinks = beefier and crossover steering 3.Durango Steering Box = beefier 4.GM 2wd fullsize truck steering box = beefy, helps for wb stretch 5.Astro Van steering box = good for long wb stretch 6.ZJ pitman arm = 1 inch drop over stock 7.WJ power steering pump (fits '96+, plug return hole, and use XJ pulley) Engine: -Performance: 1.Newer XJ intakes (may require some modification) 2.Mustang 5.0 Injectors = near bolt in (have 4 holes instead of 1, more fuel, better spray) 3.Dodge Neon Injectors = better throttle response 4. Stroker Motor......SEARCH -Alternator: 1.Mopar 136Amp Alternator, bolt it (slight grinding required) found in: 97-98 Dodge Full Size Van, 97-1998 Dodge Dakota, 97-98 Dodge Durango, 97-98 Dodge Ram, 97-98Jeep Grand Cherokee 2. Dakota (2.5L I-4) Alternator = bolt in, upgrades to 117A -Cooling: 1.Ford Electric Fan ('90-95 3.8L Taurus, '87-93 5.0L Mustang) = replaces mechanical fan, more cooling (8C607) 2.Hoodvents (i.e. Lebaron, Laser, Turbo Thunderbird etc.) = help keep ur 4.0 cool at low speeds 3.You can convert the closed system to open without replacing your radiator by using the fill cap from a 4.7 durango or dakota, cutting it into your upper hose, and replace your bottle with an MJ overflow tank or any that fit. Then cap off or eliminate the T'ed lines in the heater core. -Swaps: 1.For '84-'86 XJ with 2.8L GM V6 only! you can swap in any 60* GM V6 engine, they use the same motor mounts and bellhousings, engine options include 3.1L, and 3.4L etc, but DOES NOT INCLUDE 90* GM V6 engines such as the 4.3L!!! this swap will allow you to gain horsepower, torque, and fuel injection Transmission: 1.ZJ and WJ stock tranny coolers with stacked plates (even an upgrade for us with the stock fin style) 2.'94+ V6 Dakota AX-15 = bolt in (but must use XJ bellhousing), good upgrade from AX-5 3. Renix Transmission (swap electric speedo to t-case) Transfer Case: 1.'89+ AX-15 5spd crossmembers give 3/4 inch t-case drop on autos with no loss in ground clearance 2.Homebrew Slip Yoke Eliminator (use search function) 3.NV241-OR (from TJ Rubicon only) = near bolt in, 4:1 low range 4.Doubler Options : NP231/NP231, NP231/D300 Body/Exterior/Armor: 1.XJ '97+ doors onto older cherokees = one piece windows and better mirrors 2.’97+ mirrors are direct bolt in to older XJ's and allow you to fold them in on tight trails. 3.GM power antennas replace your broken XJ's with little modification 4.'96-00 Ford Explorer hatch shocks = lift your hatch about 3" lower but are beef (ever see one that doesn't work?) need modification for '97+ 5.TJ Fender Flares (front and rear or rear all the way around) 6.Wheels from XJ, ZJ, TJ, YJ, Explorer, Magnum Steelies (17x7) (any with 5x4.5 bolt pattern) will fit....CJ, WJ, WK, KK, JK, Full-Size Ford 5 bolt rims will NOT fit 7.OEM swing-out tire carriers, get the bumper with it, found mainly on '84-'90 XJ's 8.ZJ skid plates = require slight modification, but can be made to work 9.OEM skid plates (Front, Tranny, T-case, gas tank, found on "up-country" package XJ's not the same as a Country Edition) 10.YJ/TJ Mirrors = bigger, fold in, look cool 11. Ford Windstar Hatch Struts = lift high and strong 12. Bronco II swing out tire carrier - slight mod to fit via S10 Shackles (see post 418 orhttp://i51.tinypic.com/2uhpso4.jpg) Interior: 1.MJ/2 Door XJ Bucket seats = tilt forward, near bolt in 2.XJ overhead console = most commonly found in '00-01 or higher trim level, provides space for switches etc. 3.'97+ center console = can be made to fit '96 and older, gives you cupholders 4.Grand Cherokee center console lid = sits higher, but gives rear passengers cupholders 5.ZJ and WJ Seats - get brackets too, may require some drilling but gives you leather :-) 6. ZJ shift knob, direct replacement for XJ knob
yeah, once you know specifics it'll narrow down what you need.
The loss of Don was a huge blow to our little community. Many of us called him friend and all of us saw him as a wise sage and Jeep mentor. But even now as I fight back tears, this post is about the more practical aspect of no longer having him around. He was a prolific poster, loved to engage new members, and he answered every question he could. He knew a lot, he posted a lot, and his absence from the forums is palpable. Even if you didn't know him personally, something probably feels... off compared to a couple months ago. I've been trying to step up my game and fill the gap, but my poor brain simply cannot do what Don's could. I need help. None of you should feel like they have to do it all, but if each member made a point to maybe check in Tech an extra time each day, or chat up something in the pub, or maybe comment on the MJ builders' threads a bit more, it'd be a huge help. Engagement, communication and having fun are the keys to keeping this place from becoming just a library of MJ data, and I can't do it alone. and speaking of our library, we could always use some new DIY threads! another thing I've been dwelling on is we need more get-togethers. actually seeing the people we chat with each day. It'll forever be one of my biggest regrets not driving out to see Don. I plan on traveling out to Colorado this spring or early summer and it'd be nice to have a meetup or 2 along the way plus a big one in Pueblo CO to help Jim's widow, Katie, with tearing down that old trailer by the road and maybe finishing the fence so her chickens can help with grasshopper control on the "lawn". (some years it's like a biblical locust swarm!) We need to do some wheelin' in the mountains for sure. Not sure if I can also do Moab like my big trip in '06 (that's another 14 hour round trip from Pueblo on top of the 20+ hrs just to get to there), but... I dunno. maybe if I break it up sufficiently I won't exhaust my body too much. gotta dream big, right?
are you using a phone or laptop?
If you could have all memories of it, it's ending, anything that came after it (or before it as in my first example) erased from your memory so you could see it from scratch, what would it be? I just watched Rogue One again. It's definitely in the top 10. it's not a perfect movie by far, but I'd love to watch it without knowing anything about Vadar or other star wars movies. the original Die Hard would be sweet too. or maybe the last Avengers movie without any knowledge of Marvel stuff or knowing that a lot of the dusted members have movies coming up
DrComanches Project "Frankenstein"
Pete M replied to drcomanche's topic in MJ Hardcore Tech: Epic Journeys to Greatness
wow, you've been busy! looks good!- 146 replies
beat me to it! I bet it's like a v8 powered gocart
you can easily and safely try it with the peel-off sprays. just do it in light coats and stop when you're happy.
Comanche of the month, Sep 2011 --- DRAHCIR495's 1989
Pete M replied to Automan2164's topic in Comanche of the Month (MJOTM)
nice I still have mine too. I even hang it now and again (opened to my truck's month of course ) -
that worked, though the words are smooshed with the pics, or at least that's what I see on my screen.
excellent! The old wiring is notorious for issues. Vigilance is key! After I loss my brake lights due to corrosion in that connector, I made it a point to check them every day (it was my daily driver at the time).
yeah, bots are fascinating creatures. I almost want to trap it in a small glass container and see what it does next. our anti-bot software is near 100% with preventing them from ever getting this far.
I also installed the '02 center trim with the double outlets. unfortunately I didn't think to snip off a plug for that second outlet, so I only have one for now. I've also somehow misplaced the little hvac light bulbs I snagged, sooooo.... also shown is the black trim to the right of the steering wheel I got because it's fancier than the plain green that was there before .
old vs new. I can't figure out how to adapt the power tracks to the new seat so I'm just going to have it manual until more 2nd gen Libs show up in the yards. the lower right bracket is the weird spot. had to trim the pass seat, but the drivers seat squished the carpet just fine with no trimming required.
Eliminator Street MJ Look Alike
Pete M replied to Dzimm's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
usually if someone says "it's not worth that much", it's because the price is being compared to other similar trucks. but it's the sad truth that you'll almost never get back what you put in. -
yeah, hawaii will be there next year. this probably won't. -
true. title changed.
I have a feeling that this is one of those tools that once you have it, you will find more and more excuses to use it.
yes, but which is more strange... the fact that someone thought we could diagnose a hacked up wire harness over the internet or that a 1 post member responded to a 1 post member from 2 years ago and included a weird embedded google maps link.
when you absolutely, positively have to attract all the attention. the 3rd axle is just a dummy axle. https://www.ebay.com/itm/273693188905?_trksid=p11021.c100851.m5053&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20170803121420%26meid%3D78bb2a4011394347b7625a00d4e6e0e1%26pid%3D100851%26rk%3D1%26rkt%3D4%26b%3D1%26sd%3D183677194303%26itm%3D273693188905&ul_noapp=true
