88WISHLIST
    Arizona
1186 profile views
88WISHLIST's Achievements
  1. How do I add to Registry? 88 Pioneer, I think. 1JTMP65P5JT041275
  2. Thanks Pete. I wasn't a huge fan of the mirrors at first. But they work great for rock crawling; watching the rear end
  3. This is Wish List 88 MJ Bought it stock in 2016. Since then.... • 8.25 Chrysler rear axel swap • New Renix Reman motor swap • Front Spartan Locker • 3 inch lift in the front • Running 33x12.5r15 • Welded on frame stiffeners • Aluminum 3 core radiator • Trim fenders
  4. This tax season I'm looking to lift my long bed. I would like a 6.5 long arm kit. I'm also gonna upgrade to a 1 ton steering. I can't afford Rubicon Express. 😥 What other kits would you guys recommend or have experience with. Thanks in advance.
  5. So I'm gonna do the 1 piece axel conversion. My question is that, after all the research I've done, I'm seeing different sizes on the seals. Does anyone know the exact size I need? Best place to get the seal or the kit? Any part numbers? 1988 Dana 30, 27 spline. I do have a Spartan Locker installed, if that matters or not. Thanks in advance.
  6. What leafs are compatible with the long bed. I know xj leafs are to short. Or are long bed MJ leafs there own length?? I don't have coil spacers.
  7. I offroad/rock crawl frequently. Right now I have a 4 inch short arm lift. Already did a spring over in the rear when I put in an 8.25 Chrysler.
  8. What is the best/most compatible lift kit to get for the long bed? Looking for a 6.5-8 inch lift
  9. I'm looking for a replacement rear drive shaft for my 1988 MJ Long Bed. Looking for on that is 48.5 inches. U joint broke and dented old shaft when it fell off. I'm in Phoenix, AZ. Anyone know where I could find one?
  10. I want to put a bigger engine in my '88 MJ. Right now I have a 4.0 inline 6. 4x4. Automatic transmission. What would you guyssuggest?
  11. I want to put a bigger engine in my 88 MJ. What do you guys suggest I use?
