Pete M
Administrators
    114
Everything posted by Pete M
  1. have you started a build thread?
  2. if you grab the driveshaft does it wiggle at the t-case end?
  3. dang it! the frame on my trailer stops 8 inches short of that spot.
  4. I've pulled my share of beds and don't remember ever seeing one. though I wasn't looking specifically for it. would be awesome if it was because that would allow me to properly date my MJ trailer.
  5. nothing to lose by fixing the mount and seeing what happens. I mean, it's bad anyways, right?
  6. nice! that's good to know
  7. yup. even 2dr XJs are too small for a resto. but if you're talking about aftermarket bigger flares, the XJ flares seem to also work on MJs.
  8. no Jeep project is ever "finished"
  9. when your camper is the Tardis...
  10. all it takes to bleed the system is a wrench and a helper to push the pedal and sometimes you don't need the helper. once you get it bled and working again, try not to hold down the clutch pedal any more than absolutely necessary (especially at stop lights). pushing on that pedal is what pushes the fluid out so the less you do it, the longer it'll last. then it's a matter of monitoring it and topping it off as needed with more brake fluid.
  11. not yet that I've seen. you could be the first!
  12. Pete M
    New Waggy
    ahh, half right. batting 500
  13. Pete M
    New Waggy
    don't the current 1500s have IRS? or am I misremembering it.
  14. your actual build sheet would be longer, but a lot of info was lost before Chrysler computerized it all. if you go look at a later VIN you'll see what I mean. There's always a chance you can find your original still in the truck. it has been found under benches, behind the rear wall panel, behind a door card or even tucked up in the dash. doesn't seem to be any rhyme or reason behind the various locations.
  15. keep going till it makes a bang sound
  16. found accidentally while talking to a guy on facebook. it's in TX and I'm prodding at the owner to swing by and share more
  17. this might be #25. the interior was redone and the current owner doesn't know what happened to the tag.
  18. I can move it for you. which thread was it supposed to be in?
  19. I moved your thread over to tech for ya. welcome to the addiction! the link in my signature has a ton of good info for ya. also be sure to read this thread:
  20. Pete M
    New Waggy
    meh. I kinda stopped caring about what they put out since I'm apparently no longer the target audience. having said that, I feel it steals too many styling cues from the budget Jeeps, but my guess is that's what they're going for.
  21. some great find in there!
  22. just copy/paste the text into where you want and I'll take care of the rest later.
  23. 90% off?! not too shabby
  24. woohoo! what a milestone!
