Pete M
Administrators
    114
Everything posted by Pete M
  1. if any of the bolt is exposed, you can tack weld a nut to it.
  2. the cupholders are worth even more than the storage space in a truck that came with none.
  3. Pete M
    1J7FT66L9LL288882
    how is that even possible?
  4. always great to see the old iron out and about.
  5. I guess it all depends on what you main goal is for it. protection? hold up some lights? look cool and impress the ladies?
  6. a tie rod end is a tie rod end. I don't remember anything but "the cure" for tie rod movement.
  7. that's a happy dude
  8. Pete M
    CC cookbook
    I seriously need to get into smoking meats.
  9. confirm that the rod that runs from the multifunction stalk down the column to the hibeam switch is there and engaging the switch. I've had them get out of alignment before. you can also check for power there. @cruiser54 any ideas?
  10. I'm not really sure how to prove a negative.
  11. do you hear a clicking noise further down the column when you engage the brights?
  12. sounds like it's time to pull the harness off the headlight switch and inspect for melting too. checking all the high-amp connectors is part of regular maintenance on our old trucks. (hvac, steering column, blower motor, blower resistor pack, etc)
  13. the 8th digit in the VIN in a 1 so that indicates a base model.
  14. what year is it?
  15. now's the time to think about replacing those ujoints straps with ubolts
  16. mine is definitely 35 years old, so it might match better? also, taking pictures of chrome things hasn't gotten any easier.
  17. Pete M
    Tool Talk
    I didn't even think about rivets! I'll toss it in my junkyard bag and see if it's helpful pulling KJ stuff.
  18. when you edit, you need to delete the photo in the text, but then also delete the photo from the group of them below the text box.
  19. Pete M
    Tool Talk
    the front and rear are attached by a spring. put the skinny end on the bottom of the door hinge pin, pull back and let go and it hammers the pin up.
  20. Pete M
    Tool Talk
    bought a door hinge popper. where has this been my whole life!!!
  21. I'd say that depends on how it's done...
  22. it's only 6" in front and 6" in back of the rear tire. you'll never notice the change (until you're loading stuff in the bed and find out it holds 16% more. )
