Location
Southwest Virginia
968 profile views
Fabri-Cobbler's Achievements
Comanche Fan (3/11)
Messed around with a bunch of small stuff today. Some finish welds, painting some parts of the frame. Tail light wiring. Took the flares off and they were rough behind, may patch in the bedsides, may not. I'll weld a tab to the inner bed to brace it for now. Hopefully maybe I'll test drive this thing in the next few days.
Got my conversion joints today and put a Jeep Yoke on this Ford Driveshaft and lo-and-behold it actually fit. Threw up a temporary crossmember just to hold it up there. I'll engineer a drop/open space so I can orient the carrier in the correct position. While trying to tighten the rear up, I snapped a bolt. Nothing can ever go smoothly. Welded on a nut and got it out thankfully. Progress in the right direction, hopefully I can keep the momentum going.
Small bump. Life has unfortunately gotten in the way the past year. The main holdup from getting it on the road was a driveshaft. I wanted a one piece shaft but after talking to numerous shops, I've been steered toward a two-piece. I've ordered a shaft from a 05 F-150 and will have it shorted and swap joints to make it work hopefully. Today I got it fired up and did some body work I'd put off. Hope to have it finally going soon!
