28
Everything posted by HOrnbrod
Do what they say and quit complaining. Of course if this happens to me later on I'll be complaining worse than you. : /
Backwards Math - How Much Lift?
HOrnbrod replied to lil_loco's topic in MJ Tech: Modification and Repairs
Your drive shaft is too short. It either needs to be lengthened by a shop for more slip yoke spline engagement, or you can replace the slip yoke with a longer GM yoke. http://www.ebay.com/itm/GM-Turbo-350-Extra-Long-Racing-Slip-Yoke-700R4-7-5-1310-Style-Precision-369-/251547475996?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a9165e01c&vxp=mtr -
Autometer 15211 (single gauge) and 15210 (double gauge) fit great on the 96 and below.
Georgia's 4Wd Conversion On Hold: Kid Playing With Cell Phone
HOrnbrod replied to 1987Comanche's topic in The Pub
Condolences on your good-looking Olds mate, and glad you are okay. Hope it's fixable - looks very possible. And hopefully the little twerp that rear-ended you is walking now, not driving. -
Always pin to pin when eliminating a harness connector to maintain continuity. Wire color has nothing to do with it. When splicing a connector into a harness, then maintain wire color to wire color through the connector.
Jesus, what a kludge system. :shake: For those who don't know the definition of kludge:
Air Conditioning Problems 87 Comanche
HOrnbrod replied to 19comanche87's topic in MJ Tech: Modification and Repairs
On my 91, the valve opens by turning it clockwise, just the opposite of most valves. -
New Member, Electrical Questions
HOrnbrod replied to MJ's_MJ's topic in MJ Tech: Modification and Repairs
Usually when the blower resistor fails it defaults to the HI speed. IF the blower motor itself is good. Pull the motor and do a bench test of the motor with a 12V source (or hot wire it) to see if the motor is functioning. -
Start by performing the pertinent topics in the link below since it's been setting for years. http://comancheclub.com/topic/36382-cruisers-renix-tips/ Also you would be wise to invest in a set of Factory Service Manuals for your model year so you can troubleshoot intelligently. -
Used to fish in that area quite a bit at Lake Drummond when I lived up there. Getting to the lake via the canal and locks was half the fun. Monster black crappie in that lake. :yes:
Sure the casting number isn't 3239448? That number shows up in the below, 1983-88: Jeep Block Casting Numbers Source page for the data in this table MAKE AND YEAR C.I.D. LITRE BORE CYL. DESCRIPTION BLOCK CASTING NUMBER HEAD CASTING NUMBER CRANK CASTING NUMBER AMC 1983-88 150 2.5 3.875 L-4 Eagle, 7/16" 3239448 3244893 3239611 AMC 1988-71 150 2.5 3.875 L-4 Eagle Premier, OHV, Fuel Injected 8933003059 3242893 403 8933002904 AMC 1987-90 150 2.5 3.875 L-4 Fuel Inj., 2.06" Crank Neck, 7/16" Head Bolts, Wrangler 8933004200 408 8933002904 AMC 1986-90 150 2.5 3.875 L-4 Carb., 1/2" Head Bolts, 2.06" Crank Neck, Wrangler 53005532 . 8933002904 AMC 1991-92 150 2.5 3.875 L-4 Fuel Injected, 7/16" Head Bolts, Wrangler 63008403 117 8933002904 AMC 1970-72 232 3.8 3.75 L-6 W/Rocker Shaft, Spec. Flat Back or Flanged Style Crank 3199962 3218618 3189886 3170717 3211040 3172216 3172218 3188947 3204904 AMC 1972-74 232 3.8 3.75 L-6 W/Rocker Shaft, Spec. Flat Back or Flanged Style Crank 3213867 3218618 3222380 3710717 3189886 3211040 3213809 3224490 3214722 AMC 1975-79 232 3.8 3.75 L-6 3224098 3227445 3227258 3241722 AMC 1987-90 241 4.0 3.875 L-6 53005535 8933002665 2686 3003453 AMC 1991-93 241 4.0 3.875 L-6 53008405 7120 3003453 AMC 1970-72 258 4.2 3.75 L-6 W/Rocker Shaft, Spec. Flat Back or Flanged Style Crank 3199962 3211040 3170717 3189886 3199798 RD67703 AMC 1970-72 258 4.2 3.75 L-6 W/Rocker Shaft 3218618 3222380 3213867 3211040 3170717 3214723 AMC 1975-79 258 4.2 3.75 L-6 Spec. Location of Temp. Send. Unit, 1/2" Head Bolts 3227445 3224098 3227258 3214723 AMC 1980 258 4.2 3.75 L-6 Temp. Send. Unit at Top Rear of Head 3235077 3227258 3214723 AMC 1981-85 258 4.2 3.75 L-6 7/16" Head Bolts 3235444 3933000 3224480 3241656 3235477 AMC 1986 258 4.2 3.75 L-6 1/2" Head Bolts 3235444 3933002 3235477 AMC 1987-89 258 4.2 3.75 L-6 2.06" Crank Neck, Spec. if Alum. or Plastic Valve Cover, 1/2" Head Bolts 3235444 3661 3727 AMC 1970-79 304 5.0 3.75 V-8 3195527 3212990 3218086 3233324 RD51261 4487237 3195292 3214724 AMC 1970-78 360 5.9 4.08 V-8 Spec. Stud Type or Bolt Down Rocker Cyl. Heads. Must Have Head Cast # 3195528 3196291 3220502 3231475 3216090 3219993 3233344 RD51261 4487237 3195292 3214724 3214754 AMC 1971-76 401 6.6 4.165 V-8 Spec. Stud Type or Bolt Down Rocker Cyl. Heads. Must Have Head Cast # 3198951 3196291 3219993 3216090 3220502 3231475 3190079 3196921 3214725 3220411 3199842 The stamped date mfg. decoder is also in this link: http://www.jeepforum.com/forum/f8/identify-your-engine-1383352/
Front End Clunk, Rattle Etc. Solved
HOrnbrod replied to ParadiseMJ's topic in MJ Tech: Modification and Repairs
:thumbsup: -
Want To Put 23.5 Gal In My 87 Mj Long Bed
HOrnbrod replied to Jeepstertracey's topic in MJ Tech: Modification and Repairs
Same size? Looks like the 23.5 is 36 1/2 in. x 17 1/4 in. x 13 5/8 in. -
I ran the Addco 1-1/8" front sway bar on my MJ for awhile - didn't like it at all, way too stiff. I traded it in for a factory XJ 1-1/8" front, and it was perfect, not nearly as rigid. As for the rear, I originally fitted a stock 9/16" WJ bar on. It was much better than it was w/o a rear sway bar, but I thought it could be better. Found a good deal on a 7/8" Addco rear WJ bar, and swapped it in. It now rides great and remains flat turning at speed w/o any wheel hop. Different animals the MJ and XJ are I know, but these two bars seem to compliment each other for excellent handling and good under vs. over steer characteristics. I think the rear Addco 7/8" bar with the factory 1-1/8" front bar combo will be great on the XJ too. Go for it matey. :thumbsup:
It should swap over okay, but it may not indicate correctly. As in below, there were four different fuel gauge sending units used in the longbeds with the difference being the depth and travel of the float arm. So how accurate it will indicate is unknown until you try it. SENDING UNIT, Fuel *** 52003671, w/16 Gal. Tank - Carbureted Eng. - 7 Ft. Box - 1988 52003644, w/18 Gal. Tank - Carbureted Eng. - 7 Ft. Box 52003652, w/23.5 Gal. Tank - Carbureted Eng. - 7 Ft. Box 52003644, w/23.5 Gal. Tank - Diesel Eng. - 7 Ft. Box -
You might have compressed them down too much when you installed the poly bushings. I usually just snug them down just enough to start them spreading, then use double nuts at the top end link stubs. They for last years doing it this way. What means "offset mounting hole at the top"? :hmm: -
You have voltage at the pump and the pump doesn't run probably because you checked voltage using a chassis ground point instead of the ground wire under the left tail lamp. Agree - test for ground under the tail lamp and at the pump connector.
Memorial Day, celebrated every year on the last Monday of May, was formerly known as Decoration Day. It originated after the US Civil War to commemorate the Union and Confederate soldiers who died in the war. To honor the dead, citizens would "decorate" the graves in military cemeteries with flowers, primarily poppies. By the 20th century, Decoration Day was changed to Memorial Day and had been extended to honor all Americans who have died while in the military service. But the original meaning and purpose for Memorial day, as well as for most other national holidays, has been lost over the years to most Americans due to media and corporate greed. Memorial Day has become the benchmark for "the beginning of summer", and as such is celebrated by a long nauseating weekend of gigantic retail sales across the country. Such is life now............... :shake:
- 5 replies
- memorial day
- soldiers
- (and 6 more)
She's a very tough lady Fred. Was her mobility pretty good before the accident at church today?
Need Help Wheels Cambered Out!
HOrnbrod replied to Jacob Ochs's topic in MJ Tech: Modification and Repairs
Huh? Please explain how you determined the camber before the lift. -
Ring Gear And Pinion, 2007 Jeep
HOrnbrod replied to jimoshel's topic in MJ Tech: Modification and Repairs
Dane p/n's all in this .pdf. Super D44 4.10 gears. http://www.tomsdifferentials.com/2011catalog/Pages89-94.pdf -
Comanche Rear Sway Bar, Long Box
HOrnbrod replied to HOrnbrod's topic in MJ Tech: DIY Projects and Write-Ups
Your sway bar look like the below? If so, then it's an Addco. -
^^ Good advice. I picked up one a few years ago from a 96 ZJ w. 80K on it. The gear box itself was clean and dry. Installed it and it was tight with no play but had slight weeping at the output shaft at first. Tried some Lucas 10008 power steering stop leak and after about 100 miles or so the weeping stopped with no ill effects. It's still clean and dry after 2+ years. Guess I was lucky.
