HOrnbrod
Moderators
    28
Everything posted by HOrnbrod
  1. Has anyone tried the Addco Rear Sway Bar Kit or the one from JC Whitney to reduce body roll when driving on the highway? Did a search, no luck. Thanks; Don
  2. Looks good! How much lift diid you gain w. the SOA? Also, I don't see it or is your e-brake cable hidden behind the spring?
  3. BlueComanche - are you asking about rear disks on a D35 or D44 rear? If it's a D35, no need to swap out either the front prop valve or the rear load leveling prop, if they are working okay now with your drums.
  4. If your "sacrifical 88 Xj " was a 4-door, you will have some wiring issues, because the driver master control switches are for all 4 doors, and the associated wiring. Will work if you snip off the drivers door harness for the 2 rear doors, but then you will have a drivers master control with 2 dummy switches for the rear doors. The best/easiest way is to find a 2-door XJ power window harness (or MJ power window harness - lots of luck), which includes the power door locks. You'll also have to get the drivers side master control switches from the 2 door XJ. The passenger door switches are the same.
  5. Silver, NO rollbar
