3
Everything posted by A-man930
Beautiful work! Very inspiring! Someday mine can be pretty again too!
TDi update: THIS HANGS TOO LOW A/C bracket and compressor from an '04 Passat 1.8T gasser fit onto my 2000 Jetta ALH. Had to open up an un-used bolt boss and clearance it a bit to fit. Couldn't manage to break the crank bolt loose in the junkyard so I can't confirm it all will line up. High hopes of leaving the Jetta's accessory drive alone and using it's A/C compressor for on-board air.
Noticed the banner change to Don's rig but just now realized why RIP Don.
1988 "lowmanche"
A-man930 replied to Awinski's topic in MJ Hardcore Tech: Epic Journeys to Greatness
This is cool. Following! -
That pretty well sums it up. Search "SOA" on here or otherwise and start reading. Look at my build thread linked in my sig and you'll see what my results look like.
- 59 replies
- leaf spring
- bushing
(and 2 more)
Tagged with:
Mnkyboys 89 Comanche project
A-man930 replied to mnkyboy's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Gotta love having a lathe! One of the best garage investments I've ever made; right on par with a welder. More pics of that sector shaft support when you have it off please!- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Not priming/painting them first was indeed a mistake; they're rusty, rusty, rusty! But otherwise it was well worth the effort. They're quiet and ride nice.
- 59 replies
- leaf spring
- bushing
(and 2 more)
Tagged with:
What Minuit knows about stock Jeep radios
A-man930 replied to Minuit's topic in MJ Tech: DIY Projects and Write-Ups
I say post it. But I'm a nerd -
Looks super cool! I've heard of MegaSquirt, but not this! Looks very flexible- 798 replies
- 2.5l
- supercharged
- (and 7 more)
I stay away from analogies when it comes to electrical theory... the more I teach this stuff the more they seem to confuse a clear understanding of it. Measuring current would indeed reveal an under-performing circuit, but measuring voltage (assuming you understand what's supposed to be going on) is almost always the better/faster route to diagnosis. If he was measuring more available voltage at the headlamp connector(s) when they were on (current flowing), then that indicates the upgrade harness has offered up less resistance in the circuit and the lamp assemblies are now closer to being the only resistors in the circuit. Circuit resistance (wherever it happens to come from) and applied voltage is what determines current flow. LEDs demand far less current than conventional lighting, meaning the shortcomings of the stock harness are just about negated; which, if I understand correctly, is why the OP didn't notice much of an improvement with the Putco harness upgrade. Edit: Just re-read that conversation and realized DesertRat1991 is still running the stock headlamps... means his stock harness was healthy!
valve adjusment too tight / too loose
A-man930 replied to omega_rugal's topic in MJ Tech: Modification and Repairs
Yes, you might have fixed a compression leak by opening up to appropriate valve clearance (lash). This is a Honda, right? -
86 Diesel MJ to VW TDI conversion
A-man930 replied to johnj92131's topic in MJ Hardcore Tech: Epic Journeys to Greatness
I also have an ALH. Thanks again for the info! -
I definitely want that turbo up and well out of harms way. -
Gorgeous
- 30 replies
- 5.3l chevy v8
- 4l60
(and 4 more)
Tagged with:
Oh man! -
My '89 Comanche - Getting an LS2
A-man930 replied to Korsch_RS's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Gorgeous pics, that must have been a blast!- 117 replies
- 6.0 ls2 chevy v8
- 4l70e
(and 3 more)
Tagged with:
Project Dirty Deeds: 4.0 SUPERCHARGED
A-man930 replied to DirtyDeeds's topic in MJ Hardcore Tech: Epic Journeys to Greatness
How's it run? Interesting to see those silicone elbows balloon up like that... -
Comanche rebuild. . . again
A-man930 replied to Rokstomper's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Thanks for the background story. Cool to see a switch back to street duty!- 2 replies
- race truck
- roll cage
(and 1 more)
Tagged with:
Picked up an AR7753 from JRE (Minuit here on CC) and installed it today. It looks and sounds great! Dash looks much better now.
