scguy Posted March 15, 2022 Share Posted March 15, 2022 Sorry to beat a dead horse, but I just can't decide on a rad for my MJ. Mishimoto looks good, but is pricey and I've seen some people having issues or saying they clog easily. I've been thinking about running a coolant filter anyways. Summit 3 row has some good reviews. Mixed reviews on the CSF 3 row Then there's always the Spectre stocker. Some love it, some hate it. I've already got the triple e fans and shroud on an eBay 3 row aluminum that's now leaking. Is there an all around best radiator? Link to comment Share on other sites More sharing options...
89 MJ Posted March 15, 2022 Share Posted March 15, 2022 I’m very much a buy once, cry once type of person. Because of that, I have the Mishimoto in mine. It has been fantastic so far. Link to comment Share on other sites More sharing options...
JMO413 Posted March 15, 2022 Share Posted March 15, 2022 Love my CSF! Link to comment Share on other sites More sharing options...
Minuit Posted March 16, 2022 Share Posted March 16, 2022 My CSF is also doing just fine. But so is the single row Spectra I put in my other truck. Link to comment Share on other sites More sharing options...
cruiser54 Posted March 16, 2022 Share Posted March 16, 2022 I've used the Napa NR2802 in numerous XJs and MJs with no issues. Link to comment Share on other sites More sharing options...
89 MJ Posted March 16, 2022 Share Posted March 16, 2022 FWIW, Mishimoto does have a lifetime warranty. If you never plan on selling your truck, this is a plus. Link to comment Share on other sites More sharing options...
AZJeff Posted March 16, 2022 Share Posted March 16, 2022 I have had several XJ's and now an MJ here in PHX. I have run open cooling systems on all of them. I would guess I probably have the MOST severe cooling requirements of anyone on CC. I have found the CSF radiators with the OEM cooling fan clutch and electric fan to do the job just fine. (Along with the appropriate radiator cap.) Link to comment Share on other sites More sharing options...
75sv1 Posted March 16, 2022 Share Posted March 16, 2022 I also have 2 CFS 3-row all metal radiators. I'm not running in as extremes environments as others. I run about 205 to 210F with a 195F thermostat. The first one did have some damage done to it. I had DW and that took out the motor mounts. Also, the fan was close to the radiator. So, as suggested, use a MOPAR fan clutch if you go with a wider 2 or 3 row radiator. I have run the new one for about 2 years. I had it in my '98 XJ. Now my 2000 XJ. Had issues over the winter as the thermostat malfunctioned. I think a Mr. Gasket. So, I recommend a good quality 195F thermostat. Link to comment Share on other sites More sharing options...
scguy Posted March 16, 2022 Author Share Posted March 16, 2022 I have a Mopar 195F thermostat and efans. I think I've made up my mind. Since my block sat with coolant passages open for several years, it's got some rust in the coolant. I'm going to flush and then install a coolant filter, just keeping this current radiator topped off and give it a while to clean up the coolant before I put a big money radiator in. The current radiator isn't leaking badly, I top it off about once a month. When I do go, it's probably going to be a decision between the CSF and Mishimoto. Link to comment Share on other sites More sharing options...
camjeep3 Posted March 16, 2022 Share Posted March 16, 2022 I can say I don't recommend a 30 yr old crusty stock unit... I need to look in to this upgrade too Link to comment Share on other sites More sharing options...
75sv1 Posted March 17, 2022 Share Posted March 17, 2022 16 hours ago, scguy said: I have a Mopar 195F thermostat and efans. I think I've made up my mind. Since my block sat with coolant passages open for several years, it's got some rust in the coolant. I'm going to flush and then install a coolant filter, just keeping this current radiator topped off and give it a while to clean up the coolant before I put a big money radiator in. The current radiator isn't leaking badly, I top it off about once a month. When I do go, it's probably going to be a decision between the CSF and Mishimoto. Curious about the e-fans. I do have a set of SPALs to install with the Dirt Bound shroud. How are the temps? I think with the SPALs I'll have about 2400 CFM. Most want 3000 CFM. I am looking into using the stock electric fan, then add a RHD electric fan and something in the middle. I did order some Nickintime E-fan controllers. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted March 18, 2022 Share Posted March 18, 2022 Mishimoto hands down. Worth the money. Also, a 7 blade mech fan and the 10 blade curved oem late model XJ fan. If the system is clean, it will eliminate heating issues on a hood engine. Novak also makes a very heavy duty unit. Another option is cold case. Slightly cheaper than mishimoto but a very similar design. Link to comment Share on other sites More sharing options...
Parei_doll_ia Posted March 18, 2022 Share Posted March 18, 2022 I like my CSF. It didn't have the bung for the fan switch (96 XJ version) so I've been using my REM to control the fan. Runs 195-205 all day long, it was running 220+ before Link to comment Share on other sites More sharing options...
big66440 Posted March 22, 2022 Share Posted March 22, 2022 Mishimoto gets my vote as well, on top of making a great radiator their customer service is top notch. Link to comment Share on other sites More sharing options...
87MJJeep Posted April 13, 2022 Share Posted April 13, 2022 On 3/16/2022 at 7:15 AM, cruiser54 said: I've used the Napa NR2802 in numerous XJs and MJs with no issues. From my reading here, I know that is a unit to use to convert to an open system. If I search NAPA's site for NR2802, nothing appears. If I remove the NR, a radiator that is ATM2802 is listed, a match for a 96 XJ. Does not show compatible to a 92 MJ. This ATM2802 is out of stock. Current price is $415. Description shows manufacturer is CSF. Do you think ATM2802 is the same as NR2802? There is a RNR NR1193A radiator available for a 92 Comanche, $165. It has plastic tanks while the ATM2802 is listed to be all metal. I guess that explains the price difference. Link to comment Share on other sites More sharing options...
KBRAY88MJ Posted April 13, 2022 Share Posted April 13, 2022 A good affordable radiator that I’ve dropped in my 88 Comanche, a 92 Cherokee and a 97 Cherokee is spectra. Link to comment Share on other sites More sharing options...
87MJJeep Posted April 14, 2022 Share Posted April 14, 2022 14 hours ago, KBRAY88MJ said: A good affordable radiator that I’ve dropped in my 88 Comanche, a 92 Cherokee and a 97 Cherokee is spectra. From my quick reading, the 1193 at NAPA and Autozone is Spectra. I didn't see a warranty listed at NAPA, so for the same price I got one from AZ with lifetime warranty. Will be a big relief to get it installed and switched to an open system and have the heater control valve removed. Link to comment Share on other sites More sharing options...
Fryedaddy Posted April 27, 2022 Share Posted April 27, 2022 I used the Alloyworks brand from Amazon for a 1991-2001 Cherokee ($160). Most aftermarket radiators won't fit because they have a filler neck on the drivers side that stick into the radiator support. I used a hole saw and cut half of a 3" circle out for the neck on mine with no issues. I've had no trouble, had the radiator in and out atleast three times due to other issues and it cools very well. Link to comment Share on other sites More sharing options...
Muncher Posted April 27, 2022 Share Posted April 27, 2022 I've got some random Amazon 3 row. Problems are is its too short and the top bolts don't match up at all. Works great though Link to comment Share on other sites More sharing options...
