Kickin’Chicken Posted January 8, 2018 Share Posted January 8, 2018 Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted January 8, 2018 Share Posted January 8, 2018 Dunno looks kind of like plate they’d mount a ABS unit to. Not sure on the remix Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
Jeep Driver Posted January 8, 2018 Share Posted January 8, 2018 It's a relay and coil cover for renix XJ MJ don't don't chuckit they're hard to find Link to comment Share on other sites More sharing options...
yellaheep Posted January 8, 2018 Share Posted January 8, 2018 It's the plastic cover for the "power center" where many of your terminals, relays and fuses can be found. It's held in place with two plastic twist-in tabs. Not sure those are being reproduced so you'll want to hit up some of the parts hoarders here, or your local junk yards for those. The thing attached to it is a generic fuse or relay and is for some other aftermarket electrical component added to the truck. I think you have an even more pressing issue though....... dangerous battery cables! Link to comment Share on other sites More sharing options...
NHMJXJ Posted January 8, 2018 Share Posted January 8, 2018 I like big fires. (heavy breathing, heavy breathing) Link to comment Share on other sites More sharing options...
coolwind57 Posted January 8, 2018 Share Posted January 8, 2018 Just recently replace my negative battery cable. It looked bad but once I removed it and could see the whole thing, it looked REALLY BAD. Replace those suckers a.s.a.p., brother. Link to comment Share on other sites More sharing options...
johnj92131 Posted January 8, 2018 Share Posted January 8, 2018 Replace those battery cables ASAP. Do not pass Go, do not collect $200. Comanche Club member mean lemmons will sell you a great set of heavy duty cables. Link to comment Share on other sites More sharing options...
Kickin’Chicken Posted January 8, 2018 Author Share Posted January 8, 2018 50 minutes ago, coolwind57 said: Just recently replace my negative battery cable. It looked bad but once I removed it and could see the whole thing, it looked REALLY BAD. Replace those suckers a.s.a.p., brother. Will do. I meant to get some today when I bought a water pump and fuel filter. Poured a bottle of SeaFoam in the tank and gassed up. Almost immediately started missing and sputtering! Barely got it home! At idle it's not missing but under load it seems like it's running on 4 cylinders. Any suggestions? Link to comment Share on other sites More sharing options...
87MJTIM Posted January 8, 2018 Share Posted January 8, 2018 (edited) Are you pointing to the plastic cover? If so, it's just a cover for the relays in the engine bay. Like Jeep Driver said, keep it. They're rare. Or are you pointing to the wires screwed on to the cover? If so, that is not stock. Trace the wires from one end to the other and see what it connects to. (Might be an HO thing. Ask Don.) Edited January 8, 2018 by 87MJTIM punctuation Link to comment Share on other sites More sharing options...
sinkrun Posted January 8, 2018 Share Posted January 8, 2018 I would be more worried about those battery cables. Link to comment Share on other sites More sharing options...
DesertRat1991 Posted January 8, 2018 Share Posted January 8, 2018 Oh my. The clamp on the battery cable wrapped in electrical tape doesn't even have a nut on it... and that's the better of the two cables! Link to comment Share on other sites More sharing options...
87MJTIM Posted January 8, 2018 Share Posted January 8, 2018 Contact Mean Lemon for the cables. He will set you up with a nice set. Link to comment Share on other sites More sharing options...
Minuit Posted January 8, 2018 Share Posted January 8, 2018 Seems to me like you've got more important things to worry about than a plastic cover. Don't drive that thing until you get some decent cables on it. Whatever is screwed to the cover is a hack modification for...something. The HO system ditched that cover in favor of a fuse box. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted January 9, 2018 Share Posted January 9, 2018 That's a circuit breaker mounted to the top of the relay cover , don't have a clue what it's being used for .... Link to comment Share on other sites More sharing options...
Jeep Driver Posted January 9, 2018 Share Posted January 9, 2018 40 minutes ago, Strokermjcomanche said: That's a circuit breaker mounted to the top of the relay cover , don't have a clue what it's being used for .... It doesn't matter, it needs to be bolted to metal, grounded, for it to function. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted January 9, 2018 Share Posted January 9, 2018 Just now, Jeep Driver said: It doesn't matter, it needs to be bolted to metal, grounded, for it to function. It does matter , because I'm stating what it is . I'm not stating whether it works . Link to comment Share on other sites More sharing options...
Keyav8r Posted January 9, 2018 Share Posted January 9, 2018 Admins - there are two threads on this topic, same title, same OP. Can they be combined? Link to comment Share on other sites More sharing options...
Pete M Posted January 9, 2018 Share Posted January 9, 2018 44 minutes ago, Keyav8r said: Admins - there are two threads on this topic, same title, same OP. Can they be combined? done Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 9, 2018 Share Posted January 9, 2018 1 hour ago, Jeep Driver said: It doesn't matter, it needs to be bolted to metal, grounded, for it to function. Umm, no, not likely. It looks like a fairly standard self resetting thermal style circuit breaker. The feet are to mount it, there's a slightly cheaper version without the feet that typically winds up just being left dangling, or at best zip tied to something, since they're not exactly easy to mount. There's styles with pin or blade contacts to plug into a circuit board or fuse box, again, they are not grounded. It's probably dedicated power for a stereo. Or something else broke and nobody wanted to figure out how to fix it correctly. Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 9, 2018 Share Posted January 9, 2018 1 hour ago, Jeep Driver said: It doesn't matter, it needs to be bolted to metal, grounded, for it to function. 36 minutes ago, DirtyComanche said: Umm, no, not likely. Hey Dirty, maybe it's a switch to ground. Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 9, 2018 Share Posted January 9, 2018 1 minute ago, HOrnbrod said: Hey Dirty, maybe it's a switch to ground. And maybe those screws that are mounting it are actually 5" long and screw right into the fender... Link to comment Share on other sites More sharing options...
Jeep Driver Posted January 9, 2018 Share Posted January 9, 2018 OK, jokes on me. Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 9, 2018 Share Posted January 9, 2018 6 hours ago, Kickin’Chicken said: Poured a bottle of SeaFoam in the tank and gassed up. Almost immediately started missing and sputtering! Barely got it home! At idle it's not missing but under load it seems like it's running on 4 cylinders. Any suggestions? Don't use Seafoam when you're away from home. If you must use it, do it in your driveway. Link to comment Share on other sites More sharing options...
jdwillys Posted January 9, 2018 Share Posted January 9, 2018 Looks like an index finger Link to comment Share on other sites More sharing options...
Kickin’Chicken Posted January 10, 2018 Author Share Posted January 10, 2018 On 1/8/2018 at 7:04 PM, Keyav8r said: Admins - there are two threads on this topic, same title, same OP. Can they be combined? Something screwy happened. I thought I submitted the new thread but it never refreshed my browser. So I clicked it again and next thing ya know.....2 threads. Link to comment Share on other sites More sharing options...
