buffalob Posted December 10, 2012 Share Posted December 10, 2012 Called and spoke with the paint shop dude ...found out all the body work and paint prep is complete and they hope to shoot it by the weekend. I get my truck back next week :banana: :banana: :banana: :banana: :banana: Link to comment Share on other sites More sharing options...
88MJNC Posted December 11, 2012 Share Posted December 11, 2012 Changed the fuel regulator updated the ground wires and cleaned truck up and sat on my porch and watched another great day end. If I could only figure out how to post pictures Link to comment Share on other sites More sharing options...
88blackpearl Posted December 11, 2012 Share Posted December 11, 2012 I had mine towed home................ Link to comment Share on other sites More sharing options...
justnate Posted December 11, 2012 Share Posted December 11, 2012 i finished welding in my floor pan i made. Link to comment Share on other sites More sharing options...
deziped Posted December 14, 2012 Share Posted December 14, 2012 Bolted in steering box brace from Kevin's Off Road. Easy install. It connects frame rail to frame rail and clamps to steering box. More solidification for the weak MJ uni-frame on my 4.0. Difference in steering was noticeable. Link to comment Share on other sites More sharing options...
mvusse Posted December 14, 2012 Share Posted December 14, 2012 Installed new rear main seal. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted December 15, 2012 Share Posted December 15, 2012 I washed it and waxed it. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted December 15, 2012 Share Posted December 15, 2012 Put the headliner back into dads MJ, and installed a new rear view mirror with map lights Link to comment Share on other sites More sharing options...
Goose Posted December 15, 2012 Share Posted December 15, 2012 Today I used my mj to paint a few trees....by rubbing it against them. Link to comment Share on other sites More sharing options...
AZRick Posted December 16, 2012 Share Posted December 16, 2012 Pulled old bumper, removed spare tire winch, plotted/planned fabrication of new bumper and tube tailgate/spare tire carrier... Link to comment Share on other sites More sharing options...
Butchershop Posted December 16, 2012 Share Posted December 16, 2012 finished sanding the floorboards, coated with rust converter, primed removed front bumper, disassembled the XJ replacement, started prepping it for paint picked up a tailgate from Andy Link to comment Share on other sites More sharing options...
cody4359 Posted December 16, 2012 Share Posted December 16, 2012 New yoke, pinion seal and diff gasket yesterday. Soddered in the pigtail for the dakota tank today Link to comment Share on other sites More sharing options...
MiNi Beast Posted December 16, 2012 Share Posted December 16, 2012 Installed new set of lift shackles. Link to comment Share on other sites More sharing options...
jpdriver1 Posted December 18, 2012 Share Posted December 18, 2012 hauled tables and chairs to and from grandson's bday party Link to comment Share on other sites More sharing options...
mvusse Posted December 19, 2012 Share Posted December 19, 2012 Wilbur: Reinstalled oil pan, changed filter, filled with oil, installed starter, hook up battery, started it. Good -> no oil leak (yet) Bad -> permanent hearing damage from open header. Purple People Eater: New distributor cap, rotor, plug wires and plugs. Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted December 19, 2012 Share Posted December 19, 2012 Put 2 bags of sand in the bed for winter along with a home-built wooden box frame made of 2x4s so the sand doesn't slide forward and remains centered between wheel arches. Link to comment Share on other sites More sharing options...
mvusse Posted December 19, 2012 Share Posted December 19, 2012 Reinstalled front pipe and "muffler", ditto bellhousing inspection cover, swapped play tires out for 29" stockers (looks funny as all can be) and took it for a drive. Holy smokes! The brakes actually work now!!!! I must have set the record for taking longest to replace a rear main seal. I think it was over a month ago when I started on it. Link to comment Share on other sites More sharing options...
johnnyc Posted December 22, 2012 Share Posted December 22, 2012 Used the truck to go to UPS and pick up an Xmas present from BFG. The four 245/75/16s are going on the MJ when I downsize. I went straight to a tire shop to mount these on some Moab wheels. The other two tires - 35x12.5x15s - I'll probably sell. Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted December 28, 2012 Share Posted December 28, 2012 Installed a freshly rebuilt steering column after the previous column's tilt had failed. Link to comment Share on other sites More sharing options...
relyt120 Posted December 28, 2012 Share Posted December 28, 2012 Hydroplaned like you wouldn't believe! less than year old tires and I swear it can't go a day in the rain without sliding. Need to put some weight in the bed... Link to comment Share on other sites More sharing options...
Goose Posted December 28, 2012 Share Posted December 28, 2012 Replaced door locks, installed my cb, installed 5 power outlets, and my new optimal red top. Link to comment Share on other sites More sharing options...
relyt120 Posted December 29, 2012 Share Posted December 29, 2012 Picked up another bed my family thinks I have an obsession..and i think they are right! :rotf: surprised I didn't get pulled over on the way home, luckily it is only like 3 miles. Picked it up for 150 + tax at my pnp, they made me pay extra for the bedliner that was in it though, another $20, worth it. Its a duraliner and I love the way it mounts in there! No holes anywhere and its tight. This bed is destined to be on the bumblebee and in the mean time before I can finish painting Clair-E I will put the bumblebee's bed onto her. Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 18, 2013 Share Posted January 18, 2013 I checked the ball joints..... This was yesterday... :-( Link to comment Share on other sites More sharing options...
gogmorgo Posted January 18, 2013 Share Posted January 18, 2013 Camera man knows that was his ride out... Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 21, 2013 Share Posted January 21, 2013 Swapped the front axle on my MJ, and replaced a u-joint on the front drive shaft. My Comanche is a 4wd MJ again! I set the 242 to 4wd Full time. I still need to get the shifter handle hooked up, after I make a ax-15 linkage mount... Link to comment Share on other sites More sharing options...
