Butchershop
    Cumming, Georgia
2094 profile views
Butchershop's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. http://neworleans.craigslist.org/cto/5830741819.html Truck has run recently. Has a fule pump issue and electrical issues. Selling as a parts truck. Not 4wd. Body in good shape.
  2. Cherokee is gone, UAW pact confirmsToledo plant will add pickup but nothing else, reports sayWrangler Pick-up http://www.toledoblade.com/Automotive/2015/09/18/Cherokee-is-gone-UAW-pact-confirms.html Fiat Chrysler's plan to expand Wrangler production in Toledo, Ohio, not only means a Wrangler-based pickup is on the way, but it makes possible a diesel-powered Wrangler for the U.S. http://www.autonews.com/article/20150907/OEM04/309079949/jeep-pickup-ahead;-diesel-wrangler-possible Automotive News reported last week that FCA will produce a Wrangler-based pickup in its Toledo Assembly Complex after a redesigned Wrangler begins production in 2017. Wrangler production will move from its current line to the other side of the manufacturing complex, where the unibody Jeep Cherokee is now assembled.
  3. Now that would have worked in my driveway. I may have traded out a couple to afford it....
  4. http://atlanta.craigslist.org/atl/cto/5181262169.html A classic, unique and reliable vehicle. Converted a/c, original radio, bed liner, two owners.
  5. http://atlanta.craigslist.org/nat/tag/5142142903.html I'm selling my SCX10 Jeep Comanche. The truck started out as a JK Wrangler but has since been converted. The drive train has been modified as follows: Aluminum Transmission Gears MIP center drive shafts front and rear Axial HD gears front and rear differential 3-Racing HD lockers front and rear Aluminum Knuckles and Hubs front Proline-Shocks Novak Timbuk 2 13.5 Wraith edition brushless motor/esc High torque steering servo Metal end links front and rear, upper and lower New bearings through out RC4wd Mud Slinger 1.55 tires/steel beadlocks. Proline floor panel/wheel wells Proline Jeep Comanche body with JK body cut up for interior and various scale parts The truck runs amazingly, will climb anything and runs forever on a charge. Its a bind and drive truck, I have no remote to include with it so you will need a Spektrum Transmitter. I'm asking 500$ for it.
  6. Rare! RUST FREE MJ Truck! 36x13.50 A/T Tires, Full EXO Skeleton Cage, 2-Sets of Doors, Bulletproof Motor and Transmission / Drivetrain has Been Rebuilt and Gone Through. Lots of Money and Time Invested. 4-Wheel Disc Brakes, Full Size Matching Beadlock Spare Wheel and Tire, Spare Drive Shaft, AM/ FM BlueTooth / iPod AUX Digital Input CD Player with 6x9 Marine-Coated Speaker Pods, Tilt Steering Wheel, Rear Sliding / Locking Window, Front and Rear Fire Extinguishers, Irock Beadlock Wheels, 3Core Radiatior, Inline 6-Cylinder 4.0L Engine, 4.56 Gears, Full Suspension Lift Kit - 7.5 Inch Front and 8 Inch Rear Lift, 9k Self Recovery Winch, Action Packer Artec Truss Axles, Dana 30 RVC Shafts, BTF Diff Cover, QuadraTrac All-Weather Removable Floor-Mat Set, CB Radio with PA Speaker, Set of Factory Full Hard Doors with Roll-up Windows and a Set Half Trail Doors Included, Locking Glovebox, LED Interior Lights, Factory Digital Clock, Center Console with Storage Compartment, Rear Fuel Cell, Walbro Pump, Hydro Assist Steering, Rear Tow Bumper with Stage 3 Tow Hitch and Shackle Mounts, Irock Rock Long Arms, Rock-Slider Rocker Guards, Rustys Engine and Trans Skid Plates, Rustys Upgrade Tow / Track Bar Steering Kit and Brackets, Snorkel, Spring Over Conversion, Upgraded Battery Cables, Upgraded Lower Control Arm Mounts. Ready to Go ANYWHERE! Turn Key ..Truck Drives Great on the Road and Off. More Pics on ad http://atlanta.craigslist.org/nat/cto/5191315213.html
  7. In Cumming area also.
  8. w/ 75K miles http://houston.craigslist.org/cto/4691159233.html
  9. Thanks all. Got them off, greased them up and alls good now.
  10. New discos on an XJ. After I remove the cotter pin, I cannot slide the bottom off the bracket. It's extremely tight. Tried a rubber mallet, but didn't work. I understand it may just take more force, but don't want to bend anything. Any hints?
  11. Saved to the "Comanche" external drive!
  12. I think this is 'flip'. Saw a similar truck (must be the same) on CL about two months ago for about $6K. Clean it up and add wheels/tires, flip for a few grand. Prob work around ATL.
  13. Came through here (ATL) during rush hour(s) traffic. Real life definition of going from bad to worse! Lots of trees down, power lines on the roads and traffic lights not working. Had a rabbit run from the soggy road-side into the lane in front of me. Let's just hope it wasn't the Easter bunny or there'll be lots of disappointed kids next year.... :cry:
  14. Like this one.
  15. The map should be a separate topic .... and sticky! :waving:
